Question about HP Office Equipment & Supplies
No print cartridge in hp laserjet 3050 when there is plenty of toner inside it.after resetting i am not able to solve the problem
SOURCE: HP Laserjet 1100
Had the same problem with my HP 1100 printer. It was a faulty laser unit. Replaced the laser unit and the printer was fine.
Posted on Nov 10, 2007
SOURCE: low memory on HP Laserjet 3050
low memory error on my hp laserjet 3050
can anyone help
Posted on Jan 12, 2008
  • 85 Answers
SOURCE: HP Laserjet 3050, need to press ok each time printing
did it work before? check paper size for trays - suspect it is set for a4, change to letter size
Posted on Mar 13, 2009
SOURCE: HP Laserjet 3050 No paper pickup
it could be of dust particals on printer's plastic kind of thing looks like xray paper just clean this and restart your printer - it works
Posted on Nov 18, 2009
SOURCE: Replacing Print Cartridge
how to remove control panel pcb
Posted on May 22, 2010
I cannot get my HP 3050 printer working. I have reinstalled it and still nothing.
According to you I don't get exact problem of your printer. If you can't turn it on then first check the electric outlet where you plugged your printer. Check also the power cord of the printer. If it turned on but you can't print then first check you have connect the USB cable properly with your system. Make sure that the driver is installed properly. Check if the cartridge of toner is not empty or get damp. Clean the cartridge and toner drum, make the toner dry or change the toner. Make sure the cartridge and the roller are working properly. If everything OK, then open the printer properties and reset the settings properly. Double click on the printer and delete the entire print queue. Then reboot the printer and the system also. After rebooting, try to print a document. It will help you.
Jun 13, 2011 | HP LaserJet 3050 All-In-One Printer
When copying or printing, there is a whitish strip down the center where the rollers are. Print in this area is very faint. Thank you for any advice.
Remove the toner cartridge and while keeping relatively level, shake it from side to side. Re-install and try a test print. If the light band has gone away then problem solved. It does mean that your toner crtridge is probably starting to get low on toner. 90% of the time, print quality issues on HP lasers are toner cartridge related.
Good Luck and Thank You for using Fixya.
Aug 05, 2010 | HP LaserJet 3050 All-In-One Printer
Two printers print only black
Swap all toner carts on both machines. Sounds like a toner cart problem
Jan 30, 2009 | HP LaserJet 2500 Printer
HP Laserjet 3050 blank print
Have you tried a new toner cartridge? Usually blank pages are due to a missing bias voltage to, or in the cartridge.
Aug 11, 2008 | HP LaserJet 3050 All-In-One Printer
Lines in print page
replace toner cartridge if this is the original toner or a rebuilt.
the starter toners are notorious for going bad in the wiper area
Jun 03, 2008 | HP LaserJet 3050 All-In-One Printer
Turns out there was an easy solution. I filed a support case and had an answer in half a day:
"Often this issue is caused by a sensor. â Therefore the first thing we should do is try to trigger the sensor.
1 Turn off the HP LaserJet 3050
2 Remove the toner cartridge from the HP LaserJet 3050
3 Remove all of the paper in the paper tray
4 Check the entire paper path for any obstructions
5 Reseat the toner cartridge and paper
6 Power on the HP LaserJet 3050
If the issue is still not resolved we will need to try some resets on the HP LaserJet 3050.
1. The first reset we can try is a soft reset, it is done by pressing the MENU key then holding *# together. â This will bring you into a Developers Menu. â Scroll through the options until you find reinit FFS and then press the ENTER key.
2. If this reset doesn't clear the issue we can try a harder reset. â We can do this by pressing MENU, scrolling over to SERVICE, pressing ENTER, scrolling over to RESTORE DEFAULTS and pressing ENTER to restore the defaults and ENTER to confirm.
WARNING: Restoring the defaults will clear your fax settings, phonebook numbers and headers so you may want to print a phonebook report and Config Report first. â We can do this by accessing the Reports menu.
3. If these two resets do not help there is a third reset we can try.This reset will completely put the HP LaserJet 3050 back to factory defaults.WARNING: Before doing this reset we will need to disconnect the power cord, the phone cable, and the USB cable from the back of the HP LaserJet 3050.We can do this reset by unplugging the power cord from the back of the HP LaserJet 3050 then holding down the MENU/ENTER key and * symbol at the same time,then powering the HP LaserJet 3050 back on with the keys compressed.We will release the keys as soon as PERMANENT STORAGE INIT appears on the display screen."
I tried all the steps in sequence; it took #3 to fix it. Fortunately I didn't have a big fax address book or custom settings, so a factory defaults reset didn't cause any extra problems. It retained the time and date, and now it works fine.
Mar 12, 2008 | HP LaserJet 3050 All-In-One Printer
HP 3050
Try cleaning of the connectors inside of the printer. Also, try turning off the printer for a few minutes and restart it being sure all doors are fully closed.
Jan 16, 2008 | HP LaserJet 3050 All-In-One Printer
27 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
