Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
How do you refit a pump on a wd640? - Hotpoint Aquarius WD640 Front Load Washer/Dryer
  • 2,510 Answers
Unplug the machine from the wall outlet,
Remove lower rear panel of washer. Locate the pump, remove the hoses onto the pump and disconnect the pump from the machine. Refit in the reverse order removal, making sure that all bolts, clamps and screws are tight. Check for leaks before refitting the cover.
Posted on Mar 13, 2011
Machine not spinning or draining water
Machine has to pump out before it can spin.So if not pumping out it is either blocked up somewhere or the pump is jammed.If pump is on the r/h/s behind the plastic plinth try to undo filter (obviously having bailed the machine out as much as you can before hand otherwise you`ll get a triffle moist!) undo filter and clean it out and dry around so that when you refit the filter it will not leak+get a torch and look into the pump chamber you should see a white four bladed impellor-have a damn good look and see if there is anything jamming this impellor,if so remove it carefully without breaking the impellor.See if this is the problem and or before you do this ,if your outlet pipe pushes to the nozzle under the sink rather than down a down pipe,check here for blockages too as very common on the washer dryers.
Dec 29, 2010 | Hotpoint Aquarius WD640 Front Load...
MY Hotpoint WD 640 washing machine is not drying clothes is there a filter to clean or a reset
Power off the mains. The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. Drain out all the water. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. Inside is a white molded cone and a big white ball which floats. You will find a lot of junk here, clean out thoroughly. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the gator to the pump unit and tighten the plastic clip. Check out the pump too before reconnecting.
And rate me nice pl for the free help!
Feb 15, 2010 | Hotpoint Aquarius WD640 Front Load...
Wd640 problem not pumping out f-05
Error code means pressure switch jammed on full.
Remove large black hose fastened to bottom of drum
Remove and clean filter inside hose.
Remove hose on to pump and check for blockage or obstruction here as well
Please rate my solution.
Thankyou.
Jan 28, 2010 | Hotpoint Aquarius WD640 Front Load...
Fix main bearing
On every front-loading washing machine which I've replaced the main bearing on, it's normally removed and refitted using a suitable sized drift and a club hammer. Most of the time i find a trusty one foot length of scaffold tube which is in my toolbox does the trick.
If the washing machine has a polypropylene outer drum rather than a steel one then it's rare that the drum doesn't break whilst attempting the repair. On these types I've usually fitted a used drum from a scrapped machine, or more frequently just replaced the entire machine with another used machine which has been thrown away with a silly little problem like a blocked or broken pump.
Jul 02, 2009 | Hotpoint Aquarius WD640 Front Load...
Will not pump out
Remove lower rear panel of washer. Lay the drain hose down into a bucket or bowl, and drain all the water out, so you do not have a flood when you remove the hose.
Locate, and remove large black hose on bottom of tub. Remove plastic filter inside, and clean. Check pump also. Refit filter and hose.
Plz rate if helped.
Apr 04, 2009 | Hotpoint Aquarius WD640 Front Load...
Drum keeps filling with water even in dryer mode
Open up the top of the machine. Plug off the wall mains. Turn off the wall faucet. How is the wire connection for the inlet valve, the water inlet. Fine? If not unscrew the inlet valve from the corner of the machine after disconnecting the hoses, & dismantle to clean it up, re-assemble, refit back to machine.
Mar 27, 2009 | Hotpoint Aquarius WD640 Front Load...
F 18
Plz rate if helped.
Mar 25, 2009 | Hotpoint Aquarius WD640 Front Load...
Wd 640
Error code F05 indicates that the water level switch is stuck in the closed position, this is probablly due to a blocked filter or pump.
To gain access to the pump and filter, remove the lower rear panel of washer, locate and remove large black hose fastened to the bottom of tub.
Remove filter inside hose and clean, check inside pump for any blockage or restriction, and make sure the plastic chamber is clean where the small plastic hose is fastened to, as this goes up to the water level switch, and can sometimes get blocked.
Refit filter and hose, making sure it is securely on and fastened, and test, if fault still persists, then you will probably neeed to fit a new water level switch, or preesure switch as it is usually called.
Please rate my solution to your problem.
Thankyou.
Jan 27, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint wd640 code f05
The filter is located at the rear of the m/c behind the removable panel at bottom of m/c.
Remove lower panel and locate the large black hose at the right side, undo the fixing clip, and remove hose, be careful as there will be some water run out.
You will see the filter inside the hose, remove and clean, check pump is clear, refit hose, make sure you get it on properly,,and test for leaks.
Plz rate my solution.Thanks, and a merry xmas.
Dec 23, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wd640 f-05 and f-11 error codes washer does not empty
f05 say pump blocked or pressure switch fault. whereas f11 say pump cannot be activated... so either an open circuit pump or fauty pcb..
Oct 14, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
21 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
