Question about Haier Dishwashers
Hi, My haier dishwasher is getting stuck mid cycle. Could you tell me why this keeps happening. It gets stuck mid cycle after the wash and rinse and then it wont drain or dry dishes properly. It has never been used before. Please help. Kind regard Katie Hopkins.
SOURCE: HOTPOINT DISHWASHER FDW60
I have just had my dishwasher fixed by Hotpoint, as the heater was working and the dishwasher only stopped with the fast and delicate lights just before the drying process he replaced the main control board. This has solved the problem, I suspected the fault to be the thermistor as the heater seemed to be getting to hot but I had no idea where it was.
It turns out the thermistor is attached to the main control board and hangs down behind the front door that gives just a rough temperature level for the main control board.
As it's soldered directly onto the control board I would suggest replacing the whole control pcb for anyone with this fault unless you can find any spec details for the thermistor.
Posted on Mar 23, 2008
bigg t
  • 640 Answers
SOURCE: Stuck on wash cycle
Do you set your cycles by a manual timer or do you have a digital display?If a timer then it most likley bad or its stuck---if thats the case try wd40 behind it and see if it loosens,If your unit is digital then the control board is most likley bad,let me know.
Posted on Aug 06, 2008
  • 338 Answers
SOURCE: Kenmore Ultrawash QuietGuard 3 Dishwasher not draining or rinsing
Not draining may either need new drain motor. or something is blocking the drain pipe.
Spots on dishes means you are using to much detergent or the wrong kind of detergent.
Your owners manuel should tell you what type to use.
Posted on Nov 25, 2008
larryyb
  • 291 Answers
SOURCE: soap build up on dishwasher. Dries white and stays on dishes.
the spray arms is eather bad or the wash motor ,,,,, it isn't spraying water onto the dishes with any force.
Larry
SOURCE: pump not draining - Haier portable dishwasher
purchase new pump at www.partsquick.com/haier
about 33 shiped must be able to replace if they sell the pump i have the same problem looking for a diagram to replace pump
Posted on Jan 05, 2009
Haier dishwasher HDW9WHT beeps 5 times and won't wash what is wrong with it can I fix it or should I get someone in
7 results (0.54 seconds) Search Results
    Haier HDW100WH / HDW100SS - ProductReview.com.au
    www.productreview.com.au > ... > Dishwashers > Freestanding > Haier
    Rating: 1.7 - ‎30 votes
    Haier HDW100WH / HDW100SS: 30 customer reviews on Australia's largest ... 1.7 out of 5 stars for Haier HDW100WH / HDW100SS in Freestanding Dishwashers. ... I putthis review in to do my part for what I think is a great consumer service you ... it it keeps beeping 10 times telling me doors open??and won't begin cycle.
    Haier Dishwasher Error Fault Codes - Lights Flashing ...
    removeandreplace.com/.../haier-dishwasher-error-fault-codes-lights-flash...
    Dec 21, 2015 - Haier dishwasher error codes - flashing lights - beeping ...Dishwasher keep filling water and draining at the same time ... Fix Washing Machine That Won't Drain - Washer Not Draining Water .... 2015; Samsung Galaxy Note 5 Quick Users Guide September 25, 2015; My Freezer Is Cold But The Refrigerator ...
    Dishwasher Has Beeping Sounds Blinking Lights - How To ...
    removeandreplace.com/.../dishwasher-has-beeping-sounds-blinking-light...
    Dec 21, 2015 - At times your dishwasher may need to be reset. ... Haier DishwasherError Fault Codes - Lights Flashing Beeping Sounds My Haier ... Fix WashingMachine That Won't Drain - Washer Not Draining Water .... 2015; Samsung Galaxy Note5 Quick Users Guide September 25, 2015; My Freezer Is Cold But The ...
    How to Troubleshoot & Repair a Dishwasher ' HomeTips
    www.hometips.com/repair-fix/dishwasher.html
Jan 19, 2016 | Haier Dishwashers
DD603 top draw cycle getting stuck on 73min??????
Normally if you started the rinse cycle with water already in the base of the dishwasher it will immediately go into circulating the water through the wash arms. Do you hear the wash arms running when the washer is stuck at 11mins? Also when the washer is stuck at 73 mins are the wash arms running all the time or do you hear the pump operate at some stage?
If you have the dishwasher manual available make sure the water pressure setting is at HI or LO depending on your rated mains water pressure.
Apr 30, 2013 | Fisher and Paykel 24 in. DD603H W Built-in...
My top dishwasher drawer won't finish through the cycle. It runs fine on rinse only but not any of the wash cycles. It stops mid cycles, beeps like it has been paused, then tries to start again
Try to feel the temperature of water inside the dishwasher. If it is normal room temperature for the hot wash cycles then it is likely the heater is faulty.
It is not easy to replace unless you have good experience with repairing dishwashers.
Jan 17, 2013 | Fisher and Paykel 23 in. DD-603 Built-in...
Dishwasher Stuck Mid Cycle
Jiggle the water level float sensor .It is stuck .
May 14, 2012 | Maytag Dishwashers
Dishwasher stuck in cycle
Hi
I have a similar problem, did you find the cause of the problem?
Geoff
Jan 13, 2010 | Dishwashers
My Haier HW-C1460TVE-U washing m/c keeps giving (CLrF) ERROR Code
Anyway, my machine shows an error code "clrf". I just spoke to someone at Comet, and apparently this means there is too much foam in the machine. The machine will then refill with water and try to rinse it out, but if after that the machine still has too much foam in, then it will stop the cycle. Hence why my clothes are still wet (although I'd not realised they weren't rinsed properly either!).
I have not been using excessive amounts of washing powder, and usually use powder tablets or the liquid tablet sort, so they are a set amount and I don't do anything daft like stick 6 tablets in! I find it ridiculous that this would cause a problem with the washing machine, as I've used them perfectly fine with other washing machines.
Anyway, the advice from Comet was to keep trying different washing powders until i find one that foams less.
Jan 07, 2010 | Haier Washing Machines
S5N27B keeps stopping mid cycle
If the cycle doesn't complete, check these:---
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows: On some units, the pause is timed and the unit continues after the allotted time. On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too. Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Dec 28, 2009 | Bosch Dishwashers
Rinse cycle not happening
CHANGE THE LID SWITCH AND OR TIMER
Apr 08, 2009 | Haier XQJ50-31 Top Load Washer
Dishwasher not working
sounds like the heater is not working. it's washing while waiting for it to heat to correct temperature.
if you are not electrically minded i'd get an engineer out or ring one for a quote.
Jan 27, 2009 | Dishwashers
Dishwashers Logo
46 people viewed this question
Top Haier Dishwashers Experts
Tim Doolittle
Tim Doolittle
Tom Chichester
Are you a Haier Dishwasher Expert? Answer questions, earn points and help others
