I have a samaung pc/tv monitor,i use for pc and tv use,i have external speakers for the pc and would like to connect them also for the tv as the sound as is not very good,putting the tv menu in external speaker mode and connecting up (i tried using a splitter on the back of the tv with a red and white terminal connection on the back of the monitor, does'nt work,any suggestions.
    Brigadier General:
  • 8,546 Answers
Some actual model numbers would make this conversation more relevant.
If your PC speakers are self-powered they should accept the RCA output from any device that provides headphone or Line Level audio.
Where is the TV audio actually coming FROM? Maybe a Cable Box? THAT is where the PC speaker should tap in.
Many TV's have a Fixed or variable audio output. Fixed allows for disabing the TV speakers or turning its volume down without affecting the audio out to other devices.
Posted on Mar 13, 2011
HOW DO I CONNECT A GATEWAY LP2207 TO GET THE AUDIO TO WORK?
Some monitors do not have speakers (my HP monitor does not). The sound has come out of some external speakers attached to the tower. Or maybe you need to access the monitors on-screen menu to turn the speakers on (if they have speakers). Or maybe you can access the monitor speaker control through the PCs Device Manager option (this is where all external components attache to the PC can be viewed, and sometimes changed).
Aug 13, 2014 | Gateway LP2207 LCD Monitor
Connecting external speakers
Hi ,
go into your settings on the tv and see if there is a section on speakers and try to set it to external speackers ,,,,,,,,,,,,,good luck Roy
Feb 18, 2012 | Computers & Internet
Got a 19" LG LCD
To convert a LCD Monitor into a TV
Instructions
    • 1
      Compare internal and external TV tuners that are designed for use with computers. See if the tuner supports HD, DVI, component video, S-video, stereo, surround sound or other features you might like to use. Ensure that any internal devices will work with the expansion slots in your computer.
    • 2
      Purchase a regular TV tuner if your monitor has S-video, coaxial or RCA inputs. These can be seen at the back of the monitor. S-video should be clearly marked; coaxial is a large round port, and RCA inputs are typically smaller and brightly colored. If your monitor does not have these inputs, purchase a special TV tuner designed just for computer monitors. If you would like to use the tuner with your computer and monitor, choose an internal TV tuner. If you're using your computer monitor as a television on its own, select a stand-alone external tuner. Install the internal TV in your computer, if applicable.
    • 3
      Connect the TV tuner to the monitor with the proper cable. Select S-video as the connection option if both your tuner and monitor support it. Choose RCA component video as your next option. Use coaxial only if your monitor and tuner do not have the aforementioned connections. If your monitor has none of these connections, use a standard VGA cable to connect the tuner and monitor.
    • 4
      Connect the tuner's audio outputs to your monitor's speakers. If your monitor has no speakers directly attached, connect external speakers to the TV tuner. This can usually be achieved using regular audio or RCA cable.
    • 5
      Install an HD antenna high on a wall if you will be picking up free over-the-air television signals with your monitor. If you will be using satellite or cable TV with your monitor, simply plug the satellite or cable set top box into the tuner using RCA or coaxial cables. Then connect the tuner directly to the monitor.
    • 6
      Set your tuner to the channel you use to pick up television stations. If you receive free over-the-air television, this channel will be 3 or 4. If you have satellite or cable TV, this station is determined by your television service provider. Check the documentation that came with your system to determine which channel to set the tuner on. You will probably need to change channels using the satellite or cable box rather than the TV tuner.
May 09, 2011 | Televison & Video
My TV (42" Full HD
Yes you can - but not with a USB cable. USB is only for data (file) transfer.
What you are attempting to do is use your TV as a PC monitor, therefore it needs to be connected to your TV using a PC monitor cable (15-pin D-SUB/VGA). You will also need a separate audio cable from your PC to your TV if you want to use the TV speakers for audio. If you are using a receiver or amplifier with external speakers, you can connect the audio out from the PC directly to the amplifier/receiver.
It is also possible to connect the PC to the TV with an HDMI cable if your PC has an HDMI out port. However, some TVs wont accept an HDMI signal from a PC and this method of connection can cause other issues, so I would recommend using the PC monitor cable method.
Please let me know if you need further assistance.
Regards,
BElectric
Jan 08, 2011 | Element Electronics FLX-3211B 32 in. LCD...
My view sonic monitor has no sound
Troubleshooting Sound Issues Verify that the audio cable is connected to the AUDIO OUT or LINE OUT output on the Sound Card and plugged into the AUDIO IN or LINE IN of the Monitor.   Make sure there are no cables connected to the Headphone Jack (located next to the AUDIO IN port) on the monitor. If there is, please disconnect that cable and try the speakers again. Connecting a cable to the Headphone Jack disables the speakers. If there is no cable connected into the Headphone Jack, test a pair of headphones into that jack to see if you can hear sound out of the headphones. If you are able to hear sound out of the headphones, disconnect the headphones and try the speakers again.   Verify that the Mute on the monitor is not on or the Volume is not turned down.    Verify that the Mute on the computer is not on or the Volume is not turned down.<    If there is still no audio from the monitor's speakers, connect the Audio cable to another audio source like a portable CD player or tape player headphone output. If audio can be heard through the monitor's speakers, then there may be an issue with the computers sound card.    Connect another set of computer speakers (if available) or headphones to the AUDIO OUT or LINE OUT output on the Sound Card. If NO audio can be heard then there is an issue with the sound card. Verify with the computer's manufacturer for additional assistance.   LCD TVs Troubleshooting No Sound from a LCD TV No Sound when using RGB (when connected to a PC) Confirm the audio cable is plugged into the Audio in on the LCD TV and the audio out on the computer. Note: On the N1700W use the GREEN mini-jack; on this model Audio is SHARED between DVI and RGB, there is only 1 audio channel for data connections. The N1700w is designed to take a 1.0v RMS audio signal for optimal sound quality.   Confirm that both the LCD TV Mute and Windows Mute are off. A general message will be displayed on screen to indicate status of Mute (On or Off).   Press the Volume Up Button on the monitor or remote to confirm the Volume is not set to zero.   Confirm that PC volume is sufficient by using Windows/Macintosh Volume adjustment settings.   Try plugging another audio source such as a CD or Cassette Player directly into the Audio port on the LCD TV to confirm the speakers work, or try plugging headphones or external speakers into the sound card on the Computer. If the Headphones or External Speakers do not work, contact the manufacturer of your Computer for further support. No Sound when using S-Video/Composite/ Component Video Confirm the audio cable is plugged into the Audio in on the LCD TV and the audio out on the S-Video, Composite, or Component Video device.   Confirm Mute is off. A general message will be displayed on screen to indicate status of Mute (On or Off).   Press the Volume Up Button on the LCD TV or Remote to confirm the Volume is not set to zero.   Try plugging headphones or external speakers into the audio port on the S-Video, Composite, or Component Video device. If the Headphones or External Speakers do not work, contact the manufacturer of your S-Video, Composite, or Component Video device.   Note: Some ViewSonic monitors do not include speakers.
Nov 23, 2010 | ViewSonic E70f 17" CRT Monitor
I am trying to connect my LCD Hi-def television to my computer so I can watch internet on my tv. The tv is showing "invalid signal". What is this and how do I fix it? I have the dynex DVI-D to...
You can only use your TV for viewing internet from your computer by using the TV as a PC monitor. To do this you should connect your computer to your TV using a standard VGA cable - the same as you would use to connect your computer to any other external monitor. You should note that this cable doesn't carry a sound signal so you can't use the TV speakers for sound output.
However, you can connect an HDMI cable from your computer to your TV to play media files or DVDs. This cable does carry a sound signal so you will be able to use your TV speakers here. This cable cannot be used for turning your TV into a PC monitor.
And all of above shouldn't be confused with "Internet TV". This is something totally different and requires your TV to be connected directly to the internet.
Hope this helps.
BElectric
Nov 07, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
I'm using the tv as a monitor for my pc. How come I can't get my headphones for my pc to work when plugged into the back of the tv?
This is because the cable you are using to connect your PC to your TV does not carry a sound signal, only picture. To play sound you will need to connect a pair of external speakers to your PC, or if you want to listen on headphones, connect the headphones to the PC instead of the TV.
Oct 23, 2010 | Venturer PLV36220S1 22 in. LCD TV
Speaker connection for LG W2053TX monitor
This model of monitor does not come with speakers. In fact very monitors have speakers. You will need separate speakers for sound. Some monitors do come with external speakers which hook onto the monitor at the sides but they are still connected to the PC via a lead with a 2.5mm stereo plug into the sound output..
Dec 12, 2009 | Computers & Internet
No speaker output from television input. Other inputs (DVD, CD) work fine.
Check to make sure you have the TV input connections in the correct
slots. Sometimes there are two possible inputs for a TV. One being a monitor 1 and the other a monitor 2. There could also be speaker select buttons on the receiver that correspond to each.
Also check the TV audio settings to make sure the output connections are sending an audio signal, also known as external speakers.
Jul 29, 2009 | Denon AVR-1082 Receiver
How do u connect dighitall box to samaung syncmaster 320p with no scat input ?
Hi.
This is A monitor so it has no scart.
If it has (Component, composite, S-Video)
Providing your digi box has these connections you can connect using one of these but Im not sure if the monitor has any speakers so the audio connections Red phono & white phono will need to be plumbed in to audio amplifier.
http://dysonmanuals.llc.nu/
Jun 22, 2008 | Samsung Televison & Video
49 people viewed this question
 Grubhead
Grubhead
