I inserted recharged batteries, which I have tested and are OK, and the machinewould not play. The visual panel showed charged batteries and no timing in the brackets. The brackets rotated and eventually the panel showed "no disc". There was quite a loud clicking noise from the machine during all this time. Machine has not been dropped or otherwise maltreated..
My ipod is not working my mobile no +91 9881616618 call me
Posted on Mar 13, 2011
CAMERA WILL NOT POWER UP EVEN WITH FULLY CHARGED BATTRIES
Try non-rechargeable batteries, and try testing your rechargeable batteries because they do wear out.
Sep 19, 2014 | Cameras
Battery exhausted even after charging.
There are two possibilities. First, rechargeable batteries do not last forever. Take out your rechargeable batteries and replace them with non-rechargeable ones for test purposes. If your camera works ok, it may be that the camera's charger circuit has gone bad. Try charging your batteries on an external charger. If they charge, it is your camera's charger, if they do not hold a charge, it is probably time for new rechargeable batteries.
Sep 11, 2013 | Nikon Coolpix 3200 Digital Camera
My Samsung galaxy tablet 7.0 died out while im playing a game, when I tried to recharge it a battery icon with caution sign show up. It does not recharge anymore. Tried another charger of my other Samsung...
Connection on tablet from charger to battery is not being made and that is why it is not charging in one unit but charging in other. Till problem is resolved charge battery in other working unit.
Aug 28, 2017 | Tablets & eReaders
My rca mp3 player says its charged and then only plays for 5 to 10 minutes
If the laptop rechargeable is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Apr 02, 2013 | RCA Audio Players & Recorders
I have charged my batteries for about 4 hrs and inserted into camera but after few minutes it indicates low battery signal
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Oct 29, 2012 | Canon PowerShot A470 Digital Camera
My epson camera cp-800s showing red light & i can't take photo
New batteries? Fresh re-charge? Fresh battery pack if not responding to recharge? Is charger OK?
Check card is inserted properly?
Dropped it recently or ever?
Sep 24, 2011 | Epson PhotoPC 800 Digital Camera
My sky caddie sg5 wont charge
If you follow these instructions which I think you know how to, it will recharge. If not the rechargeable battery needs to be replaced
To charge the battery, simply follow the steps below:
  1. Gently pull back the rubber cover to gain access to the mini-USB port located at the bottom of the SkyCaddie. Insert the mini-USB connector of the supplied wall charger into the mini-USB slot.
  2. Plug the wall charger into the AC wall outlet. While charging, the charging indicator in the upper left-hand side of the SkyCaddie will show red. The charging indicator will switch to green when fully charged. You may also notice the unit's screen turn on and off periodically.
The battery will charge, even with the SkyCaddie turned off. A full battery charge may take 4 hours. Once fully charged, expect 36 holes of continuous play.
Warning!Always connect the cable to the SkyCaddie first before connecting to AC power or PC USB.
Jul 16, 2011 | GPS
Battre low problam
When your phone comes up with a battery low information, then it means you need to recharge the battery using the charger of the phone. If recharging using your charger does not help, then i will advice you get to insert the battery in another phone to try to charge there, it is definitely going to charge, when it charges fully, leave it in the phone phone and try to monitor the hours the battery lasts, if it last long, the the battery is okay, but if it does not, then it means the battery is weak bad need to be replaced.
Also test the phone by inserting a well tested battery that is fully charged into the phone and monitor how long it will last in the phone. if it last long, then the phone is okay, but if it drains off fast, then it means the phone is draining the battery, and that is the problem from the phones terminal head.
Also try to pad the battery in the phone with a folded paper so as to tighten the battery and make good connection with the phones terminal.
Also check the phones connection port.
Thank you for using fixya
Caseytech
Jun 29, 2011 | Nokia 6300 Cell Phone
16 people viewed this question
 Grubhead
Grubhead
