Question about Apple (Z0FU01) 133 in Mac Notebook
On opening the screen fragments but can be restored by adjusting the angle. What is the problem?
  • Adam Murray
    Adam Murray Mar 13, 2011
    Are you referring to the physical LCD screen itself or within the operating system?
Sounds like it's a faulty connection. Go to the shop you bought it from, with the computer and your receipt/warranty, and ask them to repair or replace it is your best bet.
Posted on Mar 29, 2011
What is the dwell angle on a 3f engine if point gap is 18 thou
dwell angle is the no of degrees rotation between points closed and points open and for example on a 4 cylinder engine ( 4 lobes =90 degrees the dwell would be around 45 degrees available
there is an adverse relationship between point gap and dwell angle
the closer the points the bigger the dwell and conversely the bigger the gap the smaller the dwell angle
in a distributor the point gap of 18 would have a large dwell angle and that affects ignition timing
in your workshop manual there will be a dwell angle specification and if you set the points at .020 " that will put you close to the dwell angle specification
from there you adjust the gap to obtain the dwell setting
after yo have the dwell set , adjust the ignition timing
there is plenty of information on dwell angle, /point gap if you type in ---dwell angle to point gap relationship--
Aug 16, 2016 | Cars & Trucks
Help? My screen flickers constantly and is driving me bananas! When I adjust it to certain angle, it will stop for a bit, but then the next time I open it to use it....same deal. Everytime I'm trying to...
sounds like your screen may be earthing out some were.
iam sure if you press on the sides of the screen it stops.
make sure all the screws are fitting ok around the screen.tighten them up if thay need it,
somthing is lose some were on your screen.
one other thing it could be is what thay call the inverter that sits behind the screen is faulty.
Aug 11, 2013 | Microsoft HP Pavilion DV6276US Notebook PC
When i turn on the computer the windows xp load screen comes up as always but this time it keeps freezing so i cant get into my computer
Try to boot in safe mode and check wether its entering in the windows, if its work then choose privious restore point & restore your pc. also remove any unwated software, keep the HDD free from excessive fragmentation, as this may help prevent startup problems, freezeups, crashes etc.
Jul 20, 2010 | Computers & Internet
Screen is staticy and jumpy
Loose or broken cable inside the unit would cause this issue. This will need to be opened up to examine the cause of this issue its with the lcd and nothing else here. So if the lcd still works it sounds like a signal cable being pulled on or has a short what have you but it needs to be checked.
thanks for visiting fixya.com please do leave your postive ratings.
Dec 11, 2009 | Compaq Presario M2000 Notebook
Laptop Screen Freezes and turns black When Adjusted angle.
It is possible that the video cable is chafing in the point where it passes through the hinge assembly. Try reseating the video cable, if that doesn't help, the replacing the LCD cable assembly is the likely fix.
Dec 05, 2009 | Dell XPS M1530 Notebook
When I open my macbook, the screen will be dark, and I have to adjust the lid to just the right angle, and the screen will then come on - when it's at the right angle there are no problems, no dead spots...
It's a problem with the lcd video cable.
It only works when you hit the right spot because the wires aren't getting enough contact.
I'd recommend getting it fixed by a local Mac tech off craigslist. It's not difficult for a tech, but for a novice it's a bit tough.
Jun 13, 2009 | Apple MacBook Mac Notebook
Fragments appear on my computer screen almost like they are paint
I would have to bet, it sounds like overheating or not enough power to the graphics card. If you have a 500watt+ you should b fine on power. If the PSU is big enouh then its overheating get a better cooler like a zalman VGA cooler w/ zalman video ram heaetsinks. Hope this helps.
Mar 14, 2009 | Computers & Internet
Adjusting the angle of the screen
at the back u will find two screws to support the stand, take them out adjust the screen accordingly and put the screws back in
Feb 28, 2009 | Sanyo DP19648 19 in. LCD TV
Screen Tilt
Mine did the same thing. If it is not aligned properly this will happen. Take the kit off from around the unit. Then tell it to go to what ever screen setting you want. If it works with the kit removed this is your problem.
Jan 20, 2008 | Kenwood DNX7100 Car Video Player
Faceplate Malfunction
i had this same problem at first you have to manually adjust the angle with the remote control to fix this.
May 12, 2007 | Jensen VM9020TS Car DVD Player
Apple (Z0FU01) 133 in Mac Notebook Logo
35 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
