Question about Plantronics Explorer 330 Headset
Connect Plantronics Explorer 330 to Verizon Moto W755 Cellphone
I am not able to connect my Plantronics Explorer 330 Bluetooth to my Verizon Moto W755 Cellphone. Please tell me how to proceed?
  • Anonymous Jan 23, 2009
    help
    Prodigy:
    An expert who has answered 500 questions.
  • 537 Answers
See page 6 of the Explorer 330 user guide for the correct pairing instructions. Link included below.
Plantronics Explorer 330 User's Guide
Good luck from Headsets DIrect!
Posted on Nov 03, 2011
Plantronics 330 unable to get the bluetooth in discovery mode
Once you make your cell phone discoverable, then put the Plantronics Explorer 330 headset into pairing mode by holding the call control button until the headset flashes red and blue. Click on the link below for the Explorer 330 user guide with the pairing instructions.
Good luck from Headsets Direct!
Jan 05, 2011 | Plantronics Explorer 330 Headset
How to connect plantronics 330 bluetooth headset with my iphone 4
When joining (or pairing) a Plantronics bluetooth headset to another device a lot depends on the other device. Assuming that you know the necessary steps of your phone or PC for connecting a bluetooth device, all Plantronics headsets pretty much follow a set pairing procedure for connectivity. This one is for the Discovery 975:
1 Turn on the Bluetooth feature on your phone.
2 Turn the earpiece on. Press and hold the call control button until the indicator flashes red/white.
3 Use the commands on your phone to locate and select your earpiece. 9xx Plantronics.
4 If prompted for the PIN code or Passkey, enter 0000.
Pairing is successful when the indicator on your earpiece flashes white.
Note If your phone supports Secure Simple Pairing (SSP), you will not need to enter a PIN code or Passkey.
Jul 20, 2010 | Plantronics Explorer 330 Headset
Need to reset plantronics explorer 330 because it might to connected to a phone i no longer have and im trying to connect it to a new phon. or, if there is an alternate solution to this problem, any advice...
This is probably far too late now, but I'll post it for future reference. You first shut off your 330 then restart it, but continue holding it for around 8-10 seconds (usually it takes less than that) and the headset will start flashing blue and red.
You are now in Pairing mode a.k.a. reset mode. While it is flashing, tell your phone to start looking for Bluetooth devices and when it displays "3XX-Plantronics" (or something similar), you know you have the right thing.
Simply select that and enter the default factory code: 0000 and you now reset and paired the headset!
Jul 12, 2009 | Plantronics Explorer 330 Headset
I cannot connect my 330 bluetooth to my phone, and I also cannot
Once you make your cell phone discoverable, then put the Plantronics Explorer 330 into pairing mode by holding the call control button until the headset flashes red and blue. Here is the link below for the Explorer 320 user guide which has the pairing instructions, it will be the same for the 330.
Plantronics Explorer 320
Jan 10, 2009 | Plantronics Explorer 330 Headset
Music
The Plantronics Explorer 330 doesn't have the A2DP technology (Advanced Audio Distribution Profile) for streaming music, you need to look for a headset that has the A2DP Bluetooth profile built in like the new Plantronics M50. The Plantronics M50 is a new model which is now available and is in the $47 range.
Below is a link to the M50.
Plantronics M50
Oct 06, 2008 | Plantronics Explorer 330 Headset
How do i listen to music on my plantronics bluetooth that is connect to my samsung blackjack
The Plantronics Explorer 330 doesn't have the A2DP technology (Advanced Audio Distribution Profile) for streaming music, you need to look for a headset that has the A2DP Bluetooth profile built in like the Plantronics Voyager Pro+ and the new Plantronics M50. The Plantronics M50 is a new model which is now available. For more information these two new models, please see the links below.
Plantronics M50
Aug 17, 2008 | Plantronics Explorer 330 Headset
Connecting bluetooth plantronics 330 headset to nokia cell phone
Here is a link to an Explorer 320 User's Guide, that will help you with your connecting to the phone. The instructions for pairing would be the same for the 320.
Plantronics Explorer 320 User's Guide
Aug 09, 2008 | Plantronics Explorer 330 Headset
Troubleshooting?lost manual
Begin with headset turned off.
1. Press call control button for
6 seconds. Release button when
indicator light flashes blue and
red. Headset is ready to pair with
Bluetooth device.
NOTE The headset can pair to
multiple Bluetooth devices, but
will only connect to one device
at a time. The headset will automatically
connect to the last
device to which it was connected.
2. While the headset is flashing red
and blue, use the phone menu
to search for Bluetooth devices
and select “3XXPlantronics”.
3. When prompted for passkey enter
0000. Headset will flash blue when
paired successfully.
Apr 15, 2008 | Plantronics Explorer 330 Headset
Plantronics explorer 330
I just figured out how to reset the 3XXPlatronics 330. The guest might of of made it a little confusing for some:
1) TURN OFF bluetooth head set by holding the volume control button for about a few seconds until it flashes blue.
2) Make sure your phone's bluetooth is on and on discover mode.
3) Turn on the blue tooth head set (NOTE: HOLD DOWN THE VOLUME BUTTON UNTIL IT FLASHES BLUE AND RED)
4) Lastly, go into your search menu to find new bluetooth devices. The device should show up as "3XXPlantronics" (PASSKEY IS 0000).
P.S. Keep in mind this worked for me, but if it doesn't work feel free to email me at; cispy006@yahoo.com
Mar 15, 2008 | Plantronics Explorer 330 Headset
Plantronics Explorer  330 Headset Logo
211 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
