Question about ASUS Computers & Internet
My pc dont open just the black appearing in may monitor???what should i do???
  • 1,381 Answers
Hi jheca_28
It could be the fuse of the power unit . Check that first .
Check all power and/or connecting cables .
If you have the install disc , launch it just to see wat happens . If it's starting normally , let it run untill you need to select an operation . Choose repair .
If something is going wrong , you'll get a warning message . Probably your HDD is dead .
You will need to test it on another healthy computer .
Good luck !
Fanaudi .
Posted on Mar 13, 2011
My pc cant start after lightning cause blackout,then i change new power supply..but it still can start. i hope you can settle this problem..
Posted on May 17, 2011
When i turn on my dell vostro a860 the screen is black.When I plug in external monitor shows pictures on both (monitor and laptop).When I disconnect external monitor the laptop works fine.The trouble is...
Windows Vista® 1 Right-click an open area of the desktop. 2 Click Personalize. The Personalize appearance and sounds window appears. 3 Click Display Settings. 4 Select the external LCD monitor in the drop-down menu.Monitors and Displays 51 5 In the Display Settings window, move the Resolution slider bar to the left or right to select a screen resolution that matches the native resolution of the external LCD monitor. 6 Click OK. Windows® XP 1 Right-click an open area of the desktop. 2 Click Properties. The Display Properties window appears. 3 Select the Settings tab. 4 Select the external LCD monitor in the Display drop-down menu. 5 Under the Screen resolution section, move the slide bar to the left or right to select a screen resolution that matches the native resolution of the external LCD monitor. 6 Click OK.
Jan 02, 2011 | Computers & Internet
Monitor goes black after a moment
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Apr 17, 2010 | Sceptre X 7 Komodo II 17 in. Flat Panel...
Power and nothing appear in the monitor
Is it the same with the battery removed and power supply plugged in??
If so charger may be faulty, get it checked.
Mar 24, 2010 | HP Pavilion dv2000t Notebook
Laptop screen is black
i suspected your laptop screen is faulty because there's no problem when you connect it on external monitor. you might need to replace it. if it is under warranty there's no need to pay for the part.
May 29, 2009 | HP Compaq Pavilion dv5000z Notebook
Keeps beeping has black screen
hi there,
this kind of sound on computer related to a hardware problem.unplug your computer if you can open the cover of your computer and try to disconnect the i.d.e cable of your hardisk,floopy and cd room,try to plug in and switch on your pc,
if the screen open,or the star up open ,either hardisk,cd room and floopy is defective.if still black screen is on your screen,you should have spare of video card and memory card,or put your memory card to other pc if your memory card is defective or good,also with your video card,or if you have spare of video card and memory card
put on to your pc have it installed and plug in then switch on if screen appear on your monitor,either video or memory card is defective.try to isolate w/c is defective.but if still black screen appear on your monitor after having replace a good video and memory cardyou have,defective mother board.
well isolate patrs of your pc defectiveness using other pc or using spare of part of pc you can trouble shoot and detect what causes your pc shutdown.if you can't do this call service technician to do this job near your location.have a nice day and don't forget to rate me.thank's
Apr 25, 2009 | HP Compaq Presario SR1920NX PC Desktop
PC Screen Went Black, Nothing Appears
try to restart holding down F8 this puts you in safe mode then erase program and use yourestore to earlier date
Apr 05, 2009 | HP w1907 LCD Monitor
Where Dell Flat screen 15" monitor has not been used for a period of time or on boot up the screen displays for a seond then goes black (although in a certain light you can see the icons and programs...
You most likely have a bad connection inside the unit. Specifically, there are a couple of "backlights" that provide the light that will pass thru the LCD panel. If you can open up the unit, with the screen facing up, there should be a small PC board on the right. Check the connections on that board. Be careful as there is high voltage there.
Keep us posted.
Dan
Apr 08, 2008 | Computers & Internet
Display
Sounds like your builtin graphics controller went bad.
Dec 05, 2007 | HP Compaq Presario R4000 Notebook
Mitsubishi monitor is distorting the picture
well first af all ,you never find this "loose wire" because it is a mith. what you have is a "cold solder" in the vertical IC, if you have a solder iron , and the ability to open it (without scratching), and then take off all the shields (without cutting your fingers), and get the solder area (without breaking the Tube). at this time ,it take you 1 minute to solve...!!! iF not... leave it to the repairman!!!.
Sep 15, 2007 | Mitsubishi Diamond Plus 73 17" CRT Monitor
Computers & Internet Logo
110 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
