Question about Canon I990 InkJet Photo Printer
I need to know how i can manually clean the print head of my canon 1p4500.
  • 435 Answers
Please click the below mentioned link to download a word document containing clean print head procedure:
Canon iP4500- Clean Print Head
Thank you
Posted on Jan 07, 2009
  • Narmada Anand
    Narmada Anand Feb 21, 2009
    Was this solution inappropriate?
Remove print head without power from Canon IP4500
If you have no intention of 'fixing' the one that does not power on, then just dissasemble it. If you take it apart, chances are that something will not line-up correctly when trying to re-assemble it.
To troubleshoot the power issue: I would fisrt suspect that the wall power is not getting to the power module, since, I assume, when you say both work it means you used both to run the printer with the bad print head. The power module should be deistributing the power to the rest of the printer. There will be a main circuit board that is the brains of the printer. That will need power in order to drive the print head to center when you open the top.
Dec 18, 2014 | Canon Pixma iP4500 InkJet Printer
My printer sends through blank pages
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Feb 17, 2013 | Canon Pixma iP4500 InkJet Printer
Not print black colour
You may have blocked print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the printthen a new print head is required.
A new print head maybe expensive and it maybe more cost effective to purchase anew printer.
Jul 08, 2012 | Canon Pixma iP4500 InkJet Printer
Alarm / Power light flashes orange 5 times consecutively (Print Head / Cartridge Error) What can I do?
Refer to Canon documentation
Five flashes: Print Head is not installed./ Print Head is defective
please check correct placement with your cartridge, maybe it's not installed properly
May 09, 2011 | Canon Pixma iP4500 InkJet Printer
Service error 6A00
Hello thanks for using fixya.
The 6A00 is a Canon generic code for paper path jam.Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code.As a Canon technology,I usually find the code almost 90% of the time it is related to the purge unit being jammed with something and not being able to move.Moving the print head assembly will not clear a purge unit if its jammed with paper,paper clips,push pins,screws,cookie crisp,flower bud pods etc.
I have found all those things in a purge unit.The offending item needs to be removed or the purge unit needs replacement.A
Canon Pixma iP4500 InkJet Printer would still be under Canon warranty, get it into a shop and save yourself the hassel.
Incidentally, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model & its always a paper path error or purge unit
I forget myself so here goes, the purge unit,called a spittoon assembly in an HP,lexmark & other ink jet printers,is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.That is why you 'll find the print head assembly parked on top of it. It also has a an electrical pump to milk the print heads and test for ink flow
See my this "Solution" same as your's & 3 people thought that it was helpful for them
I hope this solution will also helpful 4 u
Please don't forget to click on Four thumbs which are given below if it is helpful
THANKS & Keep Using fixya
Jan 14, 2011 | Canon Pixma iP4500 InkJet Printer
Canon ip 4500 error code 6502
Hi,it needs new print head. The print head is not functioning right. I have the same problem, the funny thing is, a new printer cheaper than the print head and a set of ink cartridges .
Hope it helps..
Nov 06, 2010 | Canon Pixma iP4500 InkJet Printer
Yellow not printing on test print -
You either have a leaking cart or the print head has become cross contaminated. Remove all the carts and check the feed hole under each of them. Make sure they are the color of the ink in the cart. Remove the print head and, using a damp cotton bud (water ONLY!) give the print head a clean. DO NOT use the same cotton bud for all sponges.
If that doesn't solve it then take the print head to a re-inking firm and have it cleaned professionally. Won't cost much and will hopefully solve the problem.
Sep 14, 2009 | Canon Pixma iP4500 InkJet Printer
A horizontal line appears on prints every 9/32 of an inch, especially on lighter prints
The following a step by step instructions for the printer issue:
Confirm the ink tank(s) are properly installed
Perform print head alignment
Perform Print Head Cleaning - iP4500
If the prints are faint or streaks are printed, the print head nozzles may be clogged. Those phenomena can be improved by performing print head cleaning or print head deep cleaning. Also, you can check the cleaning results by printing the Nozzle Check Pattern after cleaning.
Remove tape from the ink tank and make sure the air hole is clear
Your feedback is very important to us, please do not forget to rate my service for the site to continue helping everyone and improve on it.
I thank you for the opportunity to help and please do not hesitate in contacting me for any further questions…god bless
Aug 09, 2009 | Canon Pixma iP4500 InkJet Printer
Canon iP4500 not printing yellow
take the print head with all the cartridges still installed out of the printer. take a soft microfiber cloth and gently wipe the exposed surface on the bottom of the printhead. You should get some ink to wipe off the printhead.. reinstall and retry your printing.
May 31, 2009 | Canon Pixma iP4500 InkJet Printer
Canon pixma ip4500 print head problem 5 lights flashing. Reinstalling print head does not solve problem.
Printhead can be washed under running hot tap to flush all the old ink away. I did mine and it didn't affect performance after drying it overnight in a warm area. Re-fitted it and away it went. Don't worry about getting connector board wet at the back.
Apr 17, 2008 | Office Equipment & Supplies
Canon I990 InkJet Photo Printer Logo
2,933 people viewed this question
old marine
old marine
