Question about InFocus ScreenPlay 5700 Multimedia Projector
My projector has only 900 hours and the Replace Lamp indicator is showing up on the screen. How do I reset the indicator without replacing the globe.
  • 442 Answers
To reset the lamp age, simultaneously hold down the two Brightness buttons
on the projector's keypad for 10 seconds
Posted on Mar 14, 2011
I have a acer projector ph110, it telling me to replace the globe. Change the globe but can't get into the menu screen to reset globe hours. Try pressing the menu botton but it stll have the warning...
Hi, I had the same problem all you have to do is connect something to the projector like a laptop or dvd player so it has a signal. Once the picture comes up of what you are projecting from the laptop or dvd player you can enter the menu and reset the lamp hours. Hope this works for you if not please let me know.
Mar 30, 2011 | Acer PH110 Multimedia Projector
My lamp light is yellow green? what could be the cause?
hi ,
Do one thing just reset the lamp hour of your projector. For resetting the lamp hour do the following.
While simultaneously holding down the Right arrow ( >) button and Auto sync button on the projector press Power ON button and Left arrow ( button . The lamp hour will indicate zero.
If doesn't work you have to replace the lamp.
Remember on thing Lamp hour reset is recommended only after the lamp replaced. so try to replace the lamp if it work after the resetting procedure.
ok
Mar 27, 2011 | Sharp Notevision PG-B10S Multimedia...
Projector sharp XR-H325SA indicating lamp I replace tha new lamp but still indicating ineed to reset lamp timer but how?
hi,
for resetting the lamp hour do the following
1. Plug the power cord into the AC socket of the projector.
2. While simultaneously holding down MENU/HELP, ENTER and DOWN ARROW button on the projector, press STANDBY/ON on the projector.
3. "LAMP 0000H" is displayed, indicating that the lamp timer is reset.
ok
Jan 24, 2011 | Sharp XR-10X Multimedia Projector
Canon LV-S3 how to check hours on the lamp? do I have to have unit hooked up to an input source?
Lamp Replace Counter
Be sure to reset the lamp replace counter after Lamp Assembly is replaced. When the lamp replace counter is reset, the LAMP REPLACE Indicator stops lighting.
Note : Do not reset the Lamp Replace Counter until after the projection lamp is replaced.
1. Turn projector on, press MENU button to display the On-Screen Menu. Press Point left or right button(s) to move the red frame pointer to the Setting Menu icon.
2. Press Point down button to move the red frame pointer to "Lamp counter reset" and then press SET button. The message " Lamp replace counter reset? " is displayed.
Move the pointer to [Yes] and then press SET button.
3. Another confirmation dialog box appears and select [Yes] to
reset the lamp replace counter.
This projector uses a high-pressure lamp which must be handled carefully and properly. Improper handling may result in accidents, injury, or create a fire hazard.
 Lamp life may differ from lamp to lamp and according to the environment of use. There is no guarantee of the same lifetime for each lamp. Some lamps may fail or terminate their life in a shorter period of time than other similar lamps.
 If the projector indicates that the lamp should be replaced, i.e., if the LAMP REPLACE INDICATOR lights up, replace the lamp with a new one IMMEDIATELY after the projector has cooled down.
( Follow carefully the instructions in the LAMP REPLACEMENT section of this manual. ) Continuous use of the lamp with the LAMP REPLACE INDICATOR lighted may increase the risk of lamp explosion.
 A Lamp may explode as a result of vibration, shock or degradation as a result of hours of use as its lifetime draws to an end. Risk of explosion may differ according to the environment or conditions in which the projector and
lamp are being used.
IF A LAMP EXPLODES, THE FOLLOWING SAFETY PRECAUTIONS SHOULD BE TAKEN.
If a lamp explodes, disconnect the projector's AC plug from the AC outlet immediately. Contact an authorized service station for a checkup of the unit and replacement of the lamp. Additionally, check carefully to ensure that
there are no broken shards or pieces of glass around the projector or coming out from the cooling air circulation holes. Any broken shards found should be cleaned up carefully. No one should check the inside of the projector
except those who are authorized trained technicians and who are familiar with projector service. Inappropriate attempts to service the unit by anyone, especially those who are not appropriately trained to do so, may result in an
accident or injury caused by pieces of broken glass.
Dec 24, 2010 | Canon LV S3 Lamp
I have a Sony VPL es2 projector and the message keeps coming up, "replace the globe" how long have I got b 4 it dies on me?
May be you have couple of weeks time to replace lamp in projector and don't forget to reset lamp timer hours as procedure would be mentioned in user manual.
Oct 14, 2010 | Sony VPL-ES2 Multimedia Projector
After a few seconds the lamp light began to blink red, its a panasonic pt-lb10svu, show no pic at all has a new lamp
Hi, Replacing the lamp in a Sharp LCD projector requires the lamp indicator to be reset. When the lamp needs to be replaced, the indicator becomes red. Resetting the counter for the lamp hours to zero will also reset the indicator to green.
  • Attach the power cord to the projector and plug it into an electrical outlet.
  • Step 2Locate the buttons on the top of the projector and simultaneously hold down the "Enter", "Menu" and "down arrow" buttons, then press the "Standby/On" button.
  • Step 3Continue holding all four buttons depressed until the lamp indicator light begins flashing green.The counter is now reset. Zero hours will now be displayed on the screen.
  • Aug 03, 2010 | Panasonic PT-LB10SVU Multimedia Projector
    Sanyo plc-xp46 lcd projector
    In the on-screen menu...
    Press MENU, go to SETTINGS ICON, Move to Lamp Reset
    Also, to see lamp hours used, press and hold the UP ARROW (on the unit, not on the remote) for 30 seconds while projector is on
    Feb 10, 2009 | Sanyo Projector Lamp for PLC-XU100,...
    Infocus LP725 Replacement Bulb
    if you don't know exactly how many hours are on the new lamp, you can't be sure it works. since it's a mercury lamp, there will be no contenuity. check the lamp for cracks or clouding, not just burn marks.if the lamp is actually good, you may have a ballast issue.
    Nov 02, 2008 | InFocus LP725 and LP735 Replacement...
    Also, to see lamp hours used, press and hold the UP ARROW (on the unit, not on the remote) for 30 seconds while projector is on.
    Aug 04, 2008 | Office Equipment & Supplies
    Replaced Lamp and warning is still on screen
    This work´d great
    the "please replace the lamp" text disappeared but the lamp timer is still on the same, but i am still satisfied that the big red text on the screen is gone :P
    /Newton from Sweden
    Feb 29, 2008 | Sony VPL CS5 Multimedia Projector
    InFocus ScreenPlay 5700 Multimedia Projector Logo
    67 people viewed this question
    Top InFocus Office Equipment & Supplies Experts
    jasbo
    jasbo
    Electro Med Services...
    Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
