Ihave a hdr1600t i want some help to record one chanel and at the same time how to record the 2nd chanel. please send us easy to understand information thank you
  • timbojohnsto Sep 21, 2008
    To playback a recorded file on the hdr1600t is says to push the OK button to play. When I do this, it just closes the menu and goes back to the tv. What do I do?
  • TEAVPVR Jan 28, 2009
    I am having problems with the recoding function. I schedule the unit to record a program and I can see the red icon flashing while its recording, but when I go to retrieve the recorded file, its not there.
    Similarly, when I set it to record overnight, the next morning I can't see that it has recorded anything.
1. Just tune to the 2nd channel you like and press red (record) button. You'll see rec sign on top left.
Do not move to other channel.
2. Press List and scroll up and down to select the record in the list and press OK.
Posted on Oct 08, 2008
Dishwasher door will not close properly
usually d/w doors are fine for long time.
1. check if anything blocks it to close securely e.g. the cutlery basket or the dish racks not fully sliding in or may be off track/chanel.
2. try running a cycle empty and see if it closes after doing #1.
Jul 25, 2013 | Neff S51M53X0 24 in. Built-in Dishwasher
Ihave Bushldc 26" T.V. and
The most common cause of that is signal break up causing firstly "blocking" of the picture and audio drop out. Heavy clouds can also cause signal deteriation as does heavy rain.
Hope that helps.
Jan 18, 2011 | Televison & Video
The ant light and the other light light up red when i key the kic
the tx/rx liight is green when your radio is recieving signals and turns red when you are sending signals. the ANT light is red when your SWR is too high (over 3)
1. turn the knob labeled swr cal all the way counter clockwise
2. set the rf swr cal switch to the CAL position
3 key up the mic and hold it while you rotate the swr cal knob until the needle reaches the swr cal postition
4. set the swr cal rf switch to the swr position
5. key up the mic while on chanel one (record the the number)
6. switch to chanel 40 key up the mic (record the number)
if the number on chanel one is lower than the number on chanel 40 then your antenna is too long.
Sep 14, 2009 | Cobra 29 LTD CB Radio
No Center Channel on STR-DA5200ES
Da 5200es. Workiig only two Chanel i need five chanel. ihave no remot
Aug 04, 2009 | Sony STR-DA5200ES Receiver
I can't record normal tv progrma from HD tv
My dear friend where you connect the antenna source to the dvd or to the vcr or tv because ,if you wanna record anything you need to connect the antenna source to the dvd and put the channel you wanna record on him
Jul 25, 2009 | Televison & Video
Satelite tv through my dvr-550h
satellite tuners and DVDs have different remote,unless your using a universal remote with satellite tuner command available.to program recording, you'll need to program the time especially the allotment.then make sure you sat tuner is tuned to the station you want to record.after setting the time and station, its all set.you don't need the DVD's remote to change the channel.
May 27, 2009 | Pioneer DVR-550HS HDD Recorder
When i hook up dvd/ps2 i cant get it to show up on the screen
You have to have a remote control to set the chanel to 00. You cannot set the chanel to 00 with the chanel buttons on the front of the tv.
Jan 02, 2008 | RCA F20352SF TV
Televison & Video Logo
74 people viewed this question
Top Televison & Video Experts
