WHERE IS THE "WIDE" CONTROL
  • 23 Answers
Sometimes it is called Aspect or Size depending on the manufacturer.
Posted on Mar 13, 2011
What does "T" stand for in "f/2.8(W) - f/4.9(T)?"
Telephoto. The designation indicates that the maximum aperture of the lens is f/2.8 at the wide end of the zoom range and f/4.9 at the long (telephoto) end of the range.
Oct 27, 2011 | Cameras
Tip
How to Troubleshoot Vertical Lines on an LCD TV Screen
<p>There are two prevalent formats for video programming: full screen and wide screen. LCD TVs are designed to show a wide screen picture to go with high-definition (HD) programming. When standard-definition (SD) programming is watched on an LCD HDTV in its default settings mode, there will be two vertical lines on the right and left sides of the picture. You need to go into your TV settings menu to troubleshoot this issue.<br /> jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); <span><br /></span> <span>Instructions</span> <ol> <li> 1 Press the "Menu" button on your remote control and open the "Picture Settings" sub-menu.<br /> </li> <li> 2 Select "View" from the list of options.<br /> </li> <li> 3 Choose a viewing mode that will eliminate the vertical lines. Select "Zoom" to crop the on-screen image to fit the screen. Select "Wide/Widescreen" to stretch the on-screen image to fit the screen, or select "Panoramic/Panorama" to stretch the sides of the onscreen image to fit the screen (recommended).<br /> </li></ol>
on Dec 27, 2010 | Televison & Video
The code on the control panel says "F1". What should I do
Hi
Error code F1 means that an error with the keypad has occurred. Usually it happens due to loose ribbon cable on the keypad or the electronic control assembly itself going bad. To resolve this issue first, disconnect the power to unit and then gain access to the back of the clock assembly (Electronic Range Control/ERC). Now unplug the touch pad ribbon connector from the ERC, it would be a flat wire approx. 1 1/2" to 2" wide and make sure that the cable is not broken and nothing is shorted on the keypad. After this is done insert the cable back and then plug the unit back to check. If the error is still there then the electronic control board should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 31, 2011 | Amana Ovens
Tengo un ploter hp designjet T1100ps, en el panel de control dice: reinicie la makina, y nada sale "X" 47:01
This is an issue with your starwheel motor. you need to check the cable and functionality. If you open the cover and look down you will see the star wheels and a 2" wide strip of aluminum that is the width of the paper path...it is to the left of that right below the ink supply station.
Aug 13, 2011 | HP Designjet T1100ps Printer
1994 s-10 4.3 auto will not shift in auto
sounds like somone needs a free quote from AAMCO country wide and best of all free quotes
Jan 10, 2010 | 1994 Chevrolet S-10
Error 1920 installing Mcafee 8.5
Good morning! If you receive a "1920" error regarding failure to start a McAfee Service when trying to update or install Mcafee VirusScan, follow the instructions below.
WARNING: This procedure involves editing the Windows Registry. Using Registry Editor incorrectly can cause serious, system-wide problems that may require you to re-install Windows to correct them. Use this tool at your own risk.
Solution
  1. Uninstall McAfee VirusScan Enterprise using the "Add/Remove Programs" option in the Control Panel.
  2. If present, delete c:\Program Files\Network Associates and c:\Program Files\Common Files\Network Associates
  3. Go to the Start menu, select Run, and type regedit .
  4. Find and delete the registry key HKEY_LOCAL_MACHINE\SOFTWARE\Network Associates.
  5. Restart the computer.
  6. Install McAfee VirusScan Enterprise and update the software.
Best regards
May 07, 2009 | Computers & Internet
I can't get my screen to view properly. It's a wide screen, and it's stretching my images to fit the screen. It used to display properly, but somehow it got shifted to this new "stretched" view....
  • Move to the control panel.
  • Click the display button.
  • Then choose the right order of the screen, visual display.
  • If then also u counter a problem then u need 2 move 2 d screen, thn right click.
  • After this go to the display tab and check ur visualization & your color bit tabs.
May 21, 2008 | Toshiba Computers & Internet
Televison & Video Logo
11 people viewed this question
Top Televison & Video Experts
