Question about Panasonic Televison & Video
I have a panasonic tv model TC-21FJ30P channel 2 and preset menu was accidentally child lock, can't unlock it. The remote control is busted so i can't use it. Been trying to go back to Features which has child lock command on it but can't access it because it was skipped. How can I unlock it?
5 Suggested Answers
  • 166 Answers
SOURCE: child lock to unlock
YOU WILL NEED THE DEDICATED REMOTE CONTROL
Posted on Jun 13, 2008
  • 4234 Answers
SOURCE: shorted zener diodes in primary, needs exact values!!
There should be a circuit designation printed on the board. Can you poat that here please? I should be able to get the part number from that. It will be CRxx or Dxx.
Thankis,
Dan
Posted on Jan 28, 2009
SOURCE: Un lock child Lock.
HAL DIE EPROME YT SIT AN TV VIR EEN SEC EN SIT EPROM TRIG EN SIT TV AN
Posted on Jan 31, 2009
unvme
  • 266 Answers
SOURCE: RESISTOR BUSTED R817 POWER SUPPLY
if you have a risistor busted on the board.... you might have other hidden issues, cried contacts, cracked or burnt board, easy fix is to replace the board
Posted on Jan 19, 2011
I have a Panasonic Plasma HDTV Model TC-P42C1 how to reset the child lock on the TV with no remote? Thanks Oscar,
There are some things that can only be done with a remote and you have found one of them.
Manual and Support are here. Try the Live Chat
http://shop.panasonic.com/support-only/TC-P42C1.html
May 18, 2018 | Panasonic Televison & Video
Tip
Polaroid LCD TV Parental lock/unlock
Program Lock
Input the default password of 1235, the submenu
of Parent will display if the password is correct.
(a) When changing the password, the changed
password will be updated after four digits are input.
The word "ok" appears after you input the same
number twice, if the two passwords are different the
word "Failure" will appear.
(b) When All Clear is selected, all programs are unlocked.
(c) After you exit from the Program Lock menu and switch to a locked channel, the picture and
sound will be locked unless you input the correct password. The channel will remain unlocked
until the TV is turned off. After the TV is turned on again, the password must be re-entered to
view the locked channels again.
(d) If your program is locked, input the correct password to enter the Auto Search submenu.
Operating Auto Search will cancel the locked status.
(e) The default password is always effective.
(f) Entering the default password allows you to go to the Program Lock menu, then change the
password while the default password is still effective. This branch menu cannot be entered if a
wrong password is keyed in, In this case, press MENU to return to the previous menu.
(g) There will be slight delays while using the Lock All and Clear All functions.
● Child Lock
In Child Lock On mode, the buttons on the TV do not work. A prompt "Panel buttons are being
locked" will be displayed. However, the remote control buttons will still function. When the TV is
on and the Child Lock is on, a prompt "Locked, power off after 6s" will appear. Use the remote
control to control the TV. Otherwise, the TV will automatically enter into Standby mode.
Having trouble with setting your Parental Controls (V-Chip)?
The factory preset password is 0000. This password must be used first before setting your own personal password. It is recommended that you keep your personal password in a safe place and away from children. In the event you loose your personal password the master password is 8202. The master password overrides all passwords. The master password can't be changed and should be kept in a safe place away from children.
on Aug 17, 2010 | Televison & Video
Tip
How to Unlock Your Apex TV When Screen is Locked
If you find that your Apex TV is showing a blank screen with a red key on the bottom left then the Screen Lock otherwise known as Child Lock or Parental Control has been accidentally activated and your TV will not respond to commands from the remote control.
To resolve this and reactivate the TV simply press the (function or F) button and hold down the mute button on the remote at the same time for around 10 seconds. This will unlock the screen and allow you to view the channel as desired.
If your TV asks for a 4-digit code or password please enter 3308 or 6688 to unlock the screen or to reset any preset rating levels.
This extract is taken from an Apex Manual specific to the child lock function;
The Childlock function is designed to prevent chiIdren from watching TV. To activate: HoId down the F button and then press the MUTE button until the symboI “ ” appears on the screen. The TV will enter the Childlock mode.
Except for the “ ” symbol the screen becomes blue or black . To unlock the TV hoId down the F button and then press the MUTE button again.
Please Note:
The Childlock can be set or cancelIed only by the remote controI. After setting Childlock, secure the remote control in a safe place.
If this Tip has helped please do take time to indicate this by using the rating buttons on the page below.
Many thanks for using FixYa.
on Dec 17, 2009 | Televison & Video
How to unlock without remote
RCA TruFlat 27F520T 27" TV Unlock without remote ... - Fixya
www.fixya.com > ... > RCA > RCA TruFlat 27F520T 27" TV
Question about Apex Digital Standard (CRT) Televisions. 1 Answer ... unlock key lg lcd tv without remote how do I unlock an lg tv without using the remote?
unlock child lock tv without remote Questions & Answers ...
www.fixya.com > Forum > Tags
Find solutions to your unlock child lock tv without remote question. Get free help, tips ... How to off child lock off in my panasonic tv without a remote? ... tv without aremote? iv ... Are you a Standard (CRT) Televisions Expert? Answer questions ...
How to Unlock a TV Without a Remote ' eHow
www.ehow.com > Tech
How to Unlock a TV Without a Remote. In life, simple yet unexpected events take place, such as the loss or an accidental breakage of the television remote.
How to unlock without remote control model - Standard (CRT)
Jan 20, 2016 | Televison & Video
Our old model Prima tv won't turn on after i accidentally pressed the child lock please help me
Do you have the remote control for this TV? If so, you should be able to access the menu to disable the child lock. If you don't have the original remote, you may be able to use a universal remote to access the TV's menu.
Dec 05, 2015 | Prima Televison & Video
How to unlock the child lock for panasonic tv tc 20lchow to unlock the child lock for a panasonic tv model tc 20lc
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Unlock procedure and to override the password lock to many popular brand TVs are given.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 02, 2015 | Panasonic TC-20LA2 20-Inch Flat Panel LCD...
Want to reset the v-chip on my 2001orion tv model # 1933
Omni TVs have a child lock that allows parents to prevent children from watching specific channels or television shows with certain ratings. To activate or deactivate the controls, you need the four digit pass code. If you forget the pass code or if the lock gets set accidentally, you can still unlock the TV.
• Use the original Omni remote control to turn on the TV. You need the original remote to bypass the child lock. A universal remote won't work.
Check the screen. If you see a blank screen with a red key on it, press the "Function" and "Mute" buttons at the same time. This unlocks only the channel that is on the TV. All the other channels will remain locked and the TV will lock again when it is turned off.
• Unlock all of the channels on the TV by entering "6688," which is the factory reset code. This code resets the TV to original factory settings. Once this is done, you will have to go through the initial setup.
• Call Omni technical support at (416) 260-0047. A technician can help you troubleshoot the television as the problem may not be the child lock. You'll need to know the model number and serial number of the TV.
•Take your television to a TV repair shop if you are still unable to unlock the TV. The problem may be with the wiring, so the repairman may have to rewire the TV
Aug 12, 2012 | Televison & Video
Un lock child Lock.
Jun 13, 2008 | Akira EPM-420A 42 in. Plasma Television
Turn off child lock
To unlock the Panel Lock, Parent Lock, or Child Lock, follow these steps:
  1. Turn on your TV.
  2. On the remote, press the Menu button. The Set-Up Menu appears.
  3. Scroll to the Key Lock function and set function to Off.
  4. Press the Exit button to exit.
Note: If you don't have a remote, you may be able to do the same thing by pressing the Menu button on the front or side panel of your TV and using the volume or channel up and down buttons on the TV to scroll to the Key Lock function and set it to Off.
Oct 02, 2007 | Televison & Video
Televison & Video Logo
59 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
