Question about AudioBahn A2300HCT Car Audio Amplifier
How can I keep this thing cool at one ohm - AudioBahn A2300HCT Car Audio Amplifier
  • 23 Answers
It will never work at 1 ohm for more than a few minutes. you may be able to run it at 2 ohms stereo and 4 ohms Mono but 1 ohms stereo may be too much for the amp to handle no matter what you do to cool it.
Posted on Mar 13, 2011
Why does the fridge stay fine, but the front panel will read 52 degrees when it is 39 degrees on the thermometer inside, and the freezer keeps warming up to 32-40 degrees?
FREEZER /FRIDGE NOT COOLING: Optimum refrigerator temperature at or below40° F(4° C). The freezer temperature should be0° F(-18° C). Check temperatures periodically. Appliance thermometers are the best way of knowing these
Check ur cold control thermostat, ur thermistors in both fridge and freezer ( they should be checked for both ohms and for amount of current being put out as per ur model ), ur air flow vent from freezer to fridge.( to make sure it opens and closes without any restrictions) On thermistors check for A close circuit and amount of ohms not just an Ohm reading. As per ur model. Most should atleast show 1200 ohms. Also Check door seals for leakage.
Evaporator coils
Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
FAN check to see if it is operating or restricted A fan that is not blowing or restricted will not circulate the cold air properly.
Often, the first thing that folks do when their refrigerator starts to feel warm is turn both controls on the coldest settings.This is exactly the WRONG thing to do.Turning the cold control to the coldest settingwillkeep the compressor running longer and make lots of cold air.
But turning the air door to the coldest settingclosesthe airway to the food section. Lots of cold air is made, but most of it stays in the freezer section, and the food section actually getswarmer.
Condenser
Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
May also need to check the defrost timer, u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next.
Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance..
THE COMPRESSOR:
If you hear a clicking sound coming from the back of your refrigerator/freezer, then the problem is most likely the compressor, relay and or capacitor is overheating or not getting proper power and will not start.The compressor is the component on your refrigerator that allows your refrigerator to cool. If this component is not working properly your refrigerator will stop cooling. Most of the time the compressor is not the component that has failed.
To check ur compressor with multi meter:
Disconnect and remove the relay and capacitor from compressor, some located next to compressor in a casing.
You wills see 3 prongs coming out of compressor. 1 goes to ur start winding, 1 goes to ur run winding and the center goes to ur ground.
Place ur meter connector or prong on the start prong and the other on the ground (center prong) take note of the reading in OHMS for example 5 ohms.
Next place meter prong on run prong and the center ground prong agin. Take note of the reading in OHMS. Example 4 ohms
Next place meter prong on the start prong and the other on the run prong, now take note of the reading example 9 ohms. Now match the total of this ohms test with the total of ur two separate test. 9 ohms, if they match ur ok give or take 5 percent plus or minus. One more test to make to test of there is a short in compressor attach meter prong to ground prong and rub the other end of meter prong to metal ( scrape the metal clean of paint and test on metal surface not painted surface. If it shows continuity or ohms , u have a short in ur compressor. It should show infinity
TO REPLACE RELAY AND CAPACITOR WITH A HARDSTART KIT YOU CAN USE
A 3 in 1 start kit for compressors sizes 1/4 through 1/3 HP. And a 5 in 1 for higher H.P. (BE SURE TO MATCH WITH UR COMPRESSOR MODEL NUMBER AND TYPE) The kit includes relay, capacitor, and overload device, pre-wired. The kit will replace all 3 electrical components on capillary refrigeration systems. For newer systems with a run capacitor use proper kit. For smaller horsepower compressors useTJ90RCO810.
The wire set up is as follows the red wire goes to the right side of compressor prong, the white wire to the left side prong, the black wire to the center prong, and the 2 other black wires go to the power and the ground connection
Lastly you should also check ur THERMISTORS in the freezer and fridge section for continuity OHMS and for amount of OHMS current being put out. In most models around 13000 ( give or take 150 ohms) ohms is required.
1-3 TEMPERATURE CONTROL
As the food in the fridge gets colder, it gives off less heat, and the air inside the fridge will remain colder. A thermostat called aCOLD CONTROLwill cycle the cooling system on and off to keep the temperature inside your fridge within a certain range. You can adjust that range using one of the dials within your fridge.
On most fridges, all the cold air for both the food compartment and the freezer compartment is produced in one evaporator. Since the freezer is so much colder than the food compartment, most of the cold air that is produced circulates to the freezer compartment. Only a small amount is needed in the food compartment to keep it down to the proper temperature. This amount is adjusted by a smallAIR DOORin the duct between the evaporator and the food compartment. The control for this air door is the other of the two dials within your fridge.
If you hear your compressor "short-cycling" (starting and stopping at short intervals) try jumping across the two leads of the cold control thermostat ( in the fridge compartment) with an alligator jumper. You can also check both for live voltage current and ohms- If there is a greenthirdlead, ignore it for this test; it is the ground wire. If the fridge starts running constantly, the cold control is bad. Replace it.
To test or change the cold control, first Pull the knob off it and remove any plastic cover plate or housing from it.
You will see two wires leading to it. There will also be a thick, stiffCAPILLARY TUBEattached. The capillary tube is the liquid-filled temperature-sensing element of the cold control, and operates in the same manner as a thermometer
Read more:
http://removeandreplace.com/2013/10/31/fix-refrigerator-freezer-wont-cool-freeze/#ixzz3WDEo5NDJ
http://www.appliancerepair.net/refrigerator-repair-1.html
https://www.youtube.com/watch?v=KqXN-ZCuptk THIRMISTOR CHECK
https://www.youtube.com/watch?v=53ZFeiWgtuk
REMEMBER GOD IS THE REASON FOR GOOD ADVICE"
Top Freezer Thermistor Testing Replacement Troubleshooting Thermistor Problems in Refrigerators Refrigerator Is Not Cooling What To Check And How To Fix Refrigeration System Basics Chapter 1
Jan 30, 2017 | Samsung Refrigerators
The frigerator is not working every thing is getting warm
Evaporator coils
Condenser
THE COMPRESSOR:
You wills see 3 prongs coming out of compressor. 1 goes to ur srtart winding, 1 goes to ur run winding and the center goes to ur ground.
Read more:http://removeandreplace.com/2013/10/31/fix-refrigerator-freezer-wont-cool-freeze/#ixzz3WDEo5NDJ
Jun 22, 2015 | Refrigerators
The fridge is not freezing. screen mode is showing silent.
sounds like a circulation issue but see the following FREEZER /FRIDGE NOT COOLING: Optimum refrigerator temperature at or below40° F(4° C). The freezer temperature should be0° F(-18° C). Check temperatures periodically. Appliance thermometers are the best way of knowing these
Evaporator coils
Condenser
THE COMPRESSOR:
Jun 17, 2015 | Refrigerators
Why isn't Kitchenaid Superba refrigerator cooling? Lights are on, power is on.
Evaporator coils
Condenser
THE COMPRESSOR:
Disconnect and remove the relay and capacitor from compressor, somes located next to compressor in a casing.
Feb 23, 2015 | KitchenAid Superba Architect KSCS25INSS...
Why is the refrigerator freezer working, but cooling area not cooling
Evaporator coils
Condenser
THE COMPRESSOR:
Jul 05, 2014 | Kenmore Refrigerators
I have two audiobahn aw1500 15" subowoofers and i was trying to figure out how to wire them so that they come to 2 ohms. I have a Kicker 400.1 amp that is 2 ohm stable.
What is their ohms at the moment. If they are 8 ohms the will become 4o hms in parallel, 4 ohms will become 2 ohms in parallel. Since your audiobahns are dual four ohms coils one speaker wired in parallel gives you 2 ohms and both wired together in parallel will give you 1 ohms. You will need to wire them in series parallel to to keep two ohms and that is a waste of power. Kickers are good amps, with a little extra cooling the amp should sustain the 1 ohm capability of your parallel connection or trade in for a 1ohm stable amp
Apr 02, 2011 | AudioBahn AW1500 Car Subwoofer
I have Wharfdale 4000 Xarus speakers connected to my Pioneer VSX 817, the last 6 months it keeps saying overload when i have the volume further than 40db. Never use to do it... and i have re wired the...
Testing your amp at max with the speakers disconnected will not play a factor because there is no power being drawn so the amp is not being used. Those speakers are rated 90db and really pound but also draw a ton of amps. The key thing here is to keep it cool, cool, cool. Put a fan on it and keep your receiver on a hard surface with nothing stacked on top or anywhere within a foot of it. Keeping it cool will help prevent overloads or (protection mode). Back it down every now and them and give the system a rest for a few minutes. Double check the negative and positive connection on the speakers to the receiver. We all have hooked them up backwards sometime and this will have the effect you are expressing. What is the phase set at on your receiver? Set it down to "0" and go up to where it sounds best without distortion. One more very important thing. What is the Ohm switch on your receiver set at? Put the switch on 8 Ohm even though your running 6 Ohm speakers. That switch only steps down your voltage feed to the power selections which will hamper the overall dynamics and fidelity of your receiver. This switch is really not even necessary. Putting that switch at 8 Ohms will give you more headway and aid in keeping your amp cool.
Regards, Tony
Mar 24, 2011 | Pioneer VSX-817-S
I HAVE A NORDYNE E2EB 015H
Sounds like the flame sensor is dirty or bad. This is a metal rod that sits on the flame telling the controls that the burners is lite and it is okay to keep the gas valve open. If there is no flame it tells the control no flame shuts the gas valve off to keep excess gas from building up in the furnace. It could also be a faulty limit switch which tells the control the furnace is to hot so shuts the furnace down till it cools off. This is easy to check with an ohm meter with the furnace off check for continuity through the switch(usually a round disc looking thing with two wires going to it) if it ohms out then it is okay then run the furnace and after it shuts off check the switch to see if it ohms out if not then you have found the problem if it is okay could be the flame sensor try to clean it with a lit grit sand paper or emry cloth works good.
Jan 13, 2010 | Heating & Cooling
No cooling
Call a service person--if this happened rather suddenly, it is likely a refrigerant gas leak. Unplug the unit for now to save the compressor. Buy some dry ice to keep things cold while waiting for repairs.
Aug 14, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Same thing
Doubtful sir, your problem mostly enlies in the fact that the Alpine amplifiers are stable at 2, 4, and 8 ohm loads more than likely you have it wired at something under a 2 ohm load. This makes your amplifier do many things including not work properly. A properly wired amplifier should stay cool, and never shut down. Go to www.the12volt.com and veiw their subwoofer wiring diagram section. choose your subwoofer impedence and how many as well as how many voice coils. enter that into the drop down menus and you will be presented with all your wiring options then wire accordingly
Jun 09, 2009 | Alpine MRV-F345 Car Audio Amplifier
AudioBahn A2300HCT Car Audio Amplifier Logo
Top AudioBahn Car Audio & Video Experts
Tygh Duval
Tygh Duval
Josh Whitehead
Josh Whitehead
Colin Stickland
Colin Stickland
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
