Question about Samsung B2100 Cell Phone
My Samsung B2100 will not turn on after charging battery to full. I have even tried a good fully charged battery from an identical Samsung B2100 and it failed to work - and worse - the phone from which I took the good battery has now failed to turn itself on. Can you help as we are now have two Samsung B2100 phones less than a year old and not working??
SOURCE: Samsung SCH-u340 Cellular Charging Problem
i have the same problem but i belive i broke the hole to the charger by constanly shoving it in and shoving it out might be the same with you
Posted on Apr 05, 2009
ipodslinger
  • 688 Answers
SOURCE: My Samsung SGH-t819 Phone turned itself off, won't come back on.
your battery in your phone is worn out.
go to your local cell phone shop and buy a new one..
charge it up and your set
Posted on May 23, 2009
SOURCE: Have a Samsung j700. When trying to activate
how do you take off the battery cover
Posted on Jun 26, 2009
  • 567 Answers
SOURCE: Samsung Jet Cell Phone is "dead"
under warranty will not count on liquid damage if you take the battery out you will see a red dot that tells you water damage i have dried out some mobiles take out battery and sim leave on warm radiator couple of days then try again if still the same then it spares cost way too much to put right needs mother board ,and connectors hope this helps
Posted on May 11, 2010
SOURCE: samsung flight will not power on - battery charged
did it wor because i have the same problem with my phone.. and how do you do it
Posted on Aug 17, 2010
When i plug charger samsung rv511 laptop its showing plugged in not charging .how to fix to fully charge
maybe the battery is full charged. run without plugging in that is best. pluging in and battery at full charge is not a good thing.
Mar 14, 2014 | Samsung Rv511
Hi ive got a samsung galaxy s2 and the battery life is really bad. I will charge the phone fully over night and ut wont even last half a day. Is this a commen problem or do u have a dodgy battery
How old is the phone/battery?
Has the battery been fully discharged (used until it will not power up the item) very many times?
This is very bad for Li/Po batteries. If the phone is less than 6-12 months old, I would contact my cell provider and ask for a replacement battery. In lieu of your provider replacing it, your only option will likely be to replace it yourself. Unlike the old-school Ni/Cad rechargeable batteries, Li/Po batteries lose their ability to hold a charge if they are drained fully too many times. Also a good tip with a new battery is to charge it longer than just until the battery power indicator is full (overnight is a good basic rule, but check your phone's user guide or google the specific battery model for recommended charge times) for the first few charges, and avoid letting it fully discharge. Try to get it on a charger with at least 1 or 2 bars left. This will increase the life of a cell phone battery dramatically.
hope this helps,
r
Sep 12, 2011 | Samsung Cell Phones
In my Samsung B2100 hand set whenever I press the Contacts it says "Entry Empty". Is there any settings should I do in the phone settings?
I just purchased 2 B2100 and both do the same thing. When I receive or place a call I can talk for a short time, less then a minute, then the phone shuts off and shows low battery. When I turn back on the battery is fully charged.This does not happen every time. Both phones have been fully charged
Oct 24, 2009 | Samsung B2100 Cell Phone
My camera wont turn on even with fully charged batteries
Make sure that you have the correct battery type installed, and that the batteries are fresh/fully charged. If the problem persists, you may have corrosion on the battery contacts inside that camera that is preventing full battery power from flowing to the camera. Remove the batteries and wipe the inside camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sand paper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and reinstall them in the camera. This cleaning solves the problem about 90% of the time, and I hope it works for you.
Sep 13, 2009 | Samsung Digimax D53 Digital Camera
Samsung u700 wont turn on at all battery fully charged
If the phone is unable to turn on, even if the battery is fully charged it really needs service.
Jun 28, 2009 | Samsung Cell Phones
Can't turn on the samsung eternity even though it is full charged
Considering your battery is fully charged, you should bring it to your local technician. It maybe the power IC that's defective or something is grounded inside.
May 09, 2009 | Samsung Eternity Cell Phone
Battery will not fully or will not charge
Whenever you first purchase a device you must charge the phone fully otherwise if you charge it partially an then use it it will never charge good. You may need new battery see if youe warranty covers it \. If you are within 30 days of purchase you can exchange it at no cost!
Sep 04, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Startup/charge issue
Sad motherboard sorry,
replace and start again
Jul 21, 2008 | HP Pavilion dv6000z Notebook
Won't turn on.
Try starting it up without the battery. Batteries can pickup a dead short which will cause a laptop not to start even though they show a full charge.
Jun 11, 2008 | MetroBook VL Plus C-266 Notebook
Samsung e900 - battery life
replace the mobile phone charer and then try
Sep 07, 2007 | Samsung SGH-E900 Cellular Phone
Samsung B2100 Cell Phone Logo
399 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
