Question about Hamilton Beach BrewStation 47214 Coffee Maker
Would like to get another Coffee Tank Filter Screen
  • Anonymous Nov 30, 2008
    Lost the screen water filter-need a replacement How do I get one?
  • Anonymous Jan 30, 2009
    I have the same problem. I would like to get a new one.
  • 515 Answers
Try to contact them on this link.
http://www.hamiltonbeach.com/contact-us/contact-us.php
Posted on Aug 08, 2008
It does not deliver a full cup of coffee
There is a filter screen under the machines tank you have to take the machine apart to clean that screen.
Apr 14, 2015 | Keurig Elite B40 Coffee Maker
Why dose my keurig coffee brewer make coffee with film and oil ontop
Your water tank is likely dirty....try removing it, then remove the water filter, and rinse the tank with dish soap and white vinegar until it's squeaky clean inside. Fill the tank halfway with vinegar and run it through on the small cup size until the water is gone, then replace the water filter and run through a tank of fresh water before brewing again.
Jan 04, 2015 | Coffee Makers & Espresso Machines
An error f 17 displayed on the screen
F17 means insufficient water supply. It could be the water tank is not seated correctly. But it may be the filter behind the tank is blocked. Does it come on all the time .. or just with coffee or Hot-water ? If it comes on with just one then it may be that the coffee or hot-water pump is defective. regards
Sep 28, 2014 | Miele CVA4070 Coffee Maker
NOT GETTING WATER FOR BREWING. I DON'T HAVE A SCREEN FILTER ON BOTTOM OF WATER TANK (LOST IN RECENT MOVE)
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101
Aug 19, 2011 | Keurig B60 Coffee Maker
The coffey is coming out very slowly. i don't know how to clean the water filter/valve. thanx.
try pulling the filter plug out of the water tank run viniger through it and clean the tank were the coffee is the o-ring under the little screen gets dirty and you will know because it will leak on your counter top.
Feb 10, 2011 | Hamilton Beach BrewStation 47214 Coffee...
We are trying to set up the hamiliton beach brew station 6 cup but do not have the manual. can you walk me threw it please?
Sure Thing :)
1) Open the lid
2) Take out the filter basket.
3) Take out the Coffee Tank and fill it with water to the appropriate mark at the back of it. (Should be a stepped type marker)
4) Pour the water from the Coffee Tank into the Water Reservoir in the coffee maker it's self. (This should be on the left side of the metal warming plate.
5) Place the Coffee Tank back on the brew station.
6) Place the Filter Basket back in the coffee maker
7) Add a coffee Filter and 5 Tablespoons of coffee
8) Close the lid
9) Press the Brew/Start button (The top left one)
Jan 08, 2011 | Hamilton Beach Microwave Ovens
Not brewing full pots of coffee
Check the in line water fliter. It may need to be changed.
You can try this also.
Put the brew basket in place with no coffee in it, put an empty decanter under the basket. take a full decanter and pour it in the water fill screen at the top of the unit. When the wtaer stops dripping and the unit is back up to temp, try a full brew cycle.
If it works OK, it just got low on water in the tank
Could be caused by a plugged up filter or lime scale build up.
Dec 28, 2009 | Bloomfield 8572 Coffee Maker
I have a Bunn model VPR, I can fill it up with water, plug it in, no water. turn it on, no water. it gets hot. I opened it up, there is no restriction. What coulf cause this?
This is a pour over unit.
You fill the tank with water, it heats the water in the tank.
When the water in the tank is at brewing temp, the lite should go out.
To brew coffee with this system, you put a filter in the brew funnel, put coffee in the filter. Place the brew funnel in the slide tabs to hold in place. put an empty decanter on the warming plate under the brew funnel. Then take one decanter of fresh water and pour it in the top of the brewer where it says "WATER ONLY" the coffee will begin brewing immediatly.
Oct 26, 2009 | Bunn VPR-Black (33200.0002) Coffee Maker
Hamilton beach brewstation
I found this site that calls it a "permanent dispencing filter" but the small print says that it is the small domed filter that sits on the bottom of the tank so I sounds like the same as the filter screen. FYI, there is a pricing conflict when you click on the part. The part link shows that it's $4.99 but when you select the part or try to order it, it comes up as $5.99. Here's the link http://abtecparts.com/hamilton_beach_brew_station_filters.htm
I will probably still call HB tomorrow and see what the want for it before I buy.
Jun 01, 2008 | Hamilton Beach BrewStation 47214 Coffee...
Hamilton Beach BrewStation 47214 Coffee Maker Logo
100 people viewed this question
Top Hamilton Beach Coffee Makers & Espresso Machines Experts
jason
Greg Cann
Greg Cann
Are you a Hamilton Beach Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
