Question about Refrigerators
I have a defy model f 640 dubble door fridge that gave me problems from day one . defy do not support you with any problems i also have a defy chess fridge defy oven defy extractor fan defy stainles microoven wich is not even 6months old and just do not stop after using.i think i must drop all the products on their front door an say keep your ****.
Rotu
  • 175 Answers
SOURCE: DRAIN BLOCKED WITH ICE
It sounds like you need to install a drain heater. Sometimes these are available as a kit from a parts dealer, and sometimes you can just take a piece of bare solid copper or aluminium wire and put it a little ways down the drain, then wrap the other end around the defrost heater, so that when the fridge goes into self defrost, it keeps the drain warm so it does not freeze. The better way to do this repair though is to see if a drain heater is available for you model as a direct fit part. The other way is only to be used as a last resort. Good Luck!
Posted on Oct 11, 2006
fridgetech
  • 473 Answers
SOURCE: refrigerator compartment not cooling
If you are sure the fan in the freezer is running and you don't feel any air flow out of the top middle vent inside the fridge section, then the damper motor must be bad. The damper motor is behind that vent cover inside the fridge section.
Posted on Nov 16, 2007
  • 21 Answers
SOURCE: makes very little ice, chg filter lite stays on-2 days old!
Take the deal!!! Let Sears install a new unit! Gregg
Posted on May 28, 2009
Sea Breeze
  • 4654 Answers
SOURCE: GE profile refrigerator line freezes, fan blows but no cold air?
OK, I think I understand. Thing is we need to do a few things to see if your control board is the problem or if the fan or a freon leak is the answer. You need to tell me if this began suddenly or if over a period of time. I have been having trouble lately from Fixya if the customer (YOU) responds to my solutions. Let me know if you want my help and I will see if I get a email letting me know of your response, Thanks, Sea Breeze
Posted on Jul 12, 2009
  • 30 Answers
SOURCE: Fisher Paykel Fridge. Access to fridge fan.
its quite simple remove all shelves inside refrigerator compartment, simply remove cover ( located underneath diplay panel (will unclip) and then remove the display panel and looking up towards the roof you will then see provisions compartment fan ...try this
Posted on Jun 08, 2010
My Defy Fridge is Running Non Stop , Please Advice
When you open the door, check the door seal. If it is hot then it means your door seal isn't working properly. This will be allowing warm air to enter the fridge and cause the motor to run constantly and 'burn out'.
Check for the part in your manual or go online.
Mar 16, 2017 | Refrigerators
My double door firge frezeer is not icing and the red alarm button is alarming all the time
Glori,
you mite need to replace your thermostat,...... the alarm button is
telling u that your fridge is not cold enough, there is also probably another prob but u need to b a electrician to sort it on the top of fridge there is a panel,.. under that there is a fusible link if one blows it will need to b replaced its soldered in no job for u unless ur a electrician hope this helps
Oct 24, 2013 | Red Defy Helmet Youth 2012
I have defy fridge/freezer combo c380, freezer gets cold at bottom but fridge above does not want to, what can be the problem?
Defrost cycle has problems. Could be defrost timer, heat element, or defrost stat. temporary solution, if you can see ice accumulated inside the fridge on the back wall, desconnect or turn it off, until this ice it's gone, can be use for couple days, until service could be done on it.
Dec 23, 2009 | Refrigerators
DEFY C361 Double door fridge that does'nt get cold
We solved this by replacing the thermostat with a new one.
Sep 11, 2009 | Freezers
Fridge has problems
sounds like the defrost clock may be going bad and or a door switch. Look for a hole that has whatr looks like a big screw that you can turn.
Oct 21, 2008 | Frigidaire FRS26R4A Side by Side...
Refrigerator part wont get cold
Yes sounds like the freezer fan isnt working. Do you hear it?
Dec 01, 2007 | Refrigerators
Refrigerators Logo
515 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
