Question about Measuring Tools & Sensors
Hi, I have a CLEVELAND CONVECTION STEAMER MODEL 36CEM48, it is 480 Volt 3 phase, how do I change this 480 Volt to 240 volt? thanks
Healeyman
  • 1198 Answers
SOURCE: Voltage 1phase or 3 phase 240 volts BTUs M# 585epo36o75
To determine three phase, there wil be three hot wires from the breaker, which will have three wires. 240 single phase will have two hot wires, and the breaker will have two hot wires. Besides the hot wires, there will be a white wire,called common, which is used to make 110volt single phase where necessary. There should also be a green wire, which is safety ground. The BTU rating should be on the name plate. As far as I know, 2000BTU=1 ton
Posted on May 09, 2009
  • 308 Answers
SOURCE: Is the AE9.5-RE model 208-240 Volts, single phase or tree phase?
That is a single phase hot water heater. Hope this helps
Posted on Dec 19, 2009
gotgeek2
  • 565 Answers
SOURCE: need to rewire from 480 to 240 need coolant pump
Assuming that the motor has 9 leads and the wire numbers are still on the wires, for 240 volt 3 phase connections:
Connect T1, T6, and T7 together with L1 (A phase)
Connect T2, T4, and T8 together with L2 (B phase)
Connect T3, T5, and T9 together with L3 (C phase)
If you're not sure which of the incoming wires from the supply are L1, L2, and L3, just pick one. If the rotation is wrong just swap any 2 (TWO) phase wires.
Posted on Jul 04, 2010
heatman101
  • 43501 Answers
SOURCE: I am working with a Dayton 2YU39. The name plates
Here's what I think but you will have to check it out...
The fan motor in the 39 heater is a 120V fan there fore it cannot be hooked to the 240 which potentially could have the high (wild) leg as one of the fan legs...
The 240V 36 unit probably has a 240v fan motor....
Now if you were to make sure that the leg that fed the motor was a 120V to ground leg then you will be okay...
Hope you understand where I was going with this...
heatman101
Posted on Oct 27, 2010
SOURCE: I need wiring diagram for a Broaster pressure fryer Model 1800E
I have a service manual for the 1600 and 1800 Broaster and it has wiring diagrams in it
Posted on Dec 18, 2010
I have a mecc alte Mr 1 generator I'm producing 240 volts but I can't find a neutral so I can use 120 volts.where does the neutral come from
as 240 volts is single phase , it will not be possible to reduce the power by cutting across a neutral wire ( 240 volt power out and 240 volt neutral return That is ac power ) to do what you want to do you will need a 3 phase generator so that you can jump across a phase to get lower power
May 04, 2016 | Electrical Supplies
Www eemaxinc com support
My limited research indicates this heater is designed for USA electrical systems. That would mean single phase, 240/208 volts, 60 Hz. The drawings I reviewed shows a 2 pole, 240 volt breaker feeding each heating circuit. That means no "neutral wire" goes to the heater and therefore no 120 volts is needed. This is good. Kenya's system is single phase, 240 volts, 50 Hz. The heater should work reasonably well on the African system. Connect the power just like you would in the US.
Jan 17, 2014 | Water Heaters
I purchased a generac 22 kw 3 phase 120/240 volt generator. I was surprised to find that it had a wild leg. Can i change the leads on the stator output to eliminate the high leg and get straight 120/208...
This unit is wired 120-240V 3 phase Delta. if you are using on it 120/208V 3 phase application it will need to be re-tapped. If you are using it in a home 120-240V single phase it will need re-tapping, Do NOT just use 2 legs, as this will cause rotor imbalance and wear out the rotor bearings, and odd ball currents to flow. If there are 12 leads coming off the stator it can be reconnected. If not you are stuck with it, except by using a transformer
Dec 15, 2013 | Generac Generator QT02224JNAX QuietSource...
Where can i find ac motor connection diagrams, specifically, single phase forward and reverse, and 415v motor to 240v power diagrams? thanks andy
there is no motor that is single phase with 415 volts only 240 volt or 120volt and you cannot use a 3 phase motor on single phase it will just fail to start buzz and burn it up .single phase motors have capacitors 3 phase motors do not
Jun 15, 2011 | Air Tools & Compressors
I am working with a Dayton 2YU39. The name plates states that it has to be powered by 208 volt system. There's a 3-phase panel and a single-phase panel. The 3-pahse panel L1 to ground is 118 volts. L2 is a...
heatman101
Oct 27, 2010 | Dayton 2YU44 Electric Heater
How to install a 208v outlet for a stove
if its a single phase panel you will only have 120/240 v.a.c. you can wire it for 240 volts and it will heat faster anyway the only way you could have 208 volts would be if you had 3 phase delta or open delta 3 phase or buy a special "dry-type" transformer for 240 volt to 208 volt step-down,otherwise it will be red-& black will be your 2 hot phases of 120 volts each/white-neutral/and green or green-yellow will be the case safety ground
Nov 14, 2009 | General Electric Profile PP945 30 in....
Looking at the model number, it appears to be a 3 ton. (36,000 btu) Most all residential units are single phase and most all commercial are 3 phase. One way to tell, look to see if the compressor has a capacitor. 3 phase never use capacitors on the compressors as they are not needed. Some residential units have a "Dual" capacitor. That is, it has 3 terminals, 1 common, 1 for condenser fan motor, and 1 for the compressor. Also, this info should be printed on the unit's lable.
Good Luck and hope this helps.
May 09, 2009 | Amana Comfort Zone 12M32PBEH Air...
New solenoid drain valve for cleveland steamer
The correct cleveland part # for your valve is 22221. If you have the correct valve there should be no extra ports. The steamer will flush itself when you turn it on, and periodically if there is the optional blow down timer installed. Hope this helps
Apr 02, 2009 | Cleveland Electric Powered Convection...
Measuring Tools & Sensors Logo
54 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
