Question about Watches
I need a wrist band for my Maum watch - Watches
  • 40 Answers
SOURCE: versace watch
call an authorized retailer in your area and they will be able to order a band for you. Here is a link for the website http://www.vertime.com
Posted on Feb 09, 2007
SOURCE: Invicta 2875 wrist watch band too large
take it to a jeweler and they will do it for a small cost. Usually less than $10
Posted on Dec 12, 2007
  • 3 Answers
SOURCE: Remove link form Relic Wrist band
For my relic ZR15372, all I did was take a thin, hard object (a thumbtack in my case) and carefully pushed out the connecting bar from the link.
If you look at the inside of the band of your watch, you may notice that on some of the links (the ones nearest the clasp for me) there is a little arrow pointing at the side - if you look at the side of the links, there should be a little hole, big enough to push a thumbtack into. If you apply enough pressure (again, carefully - no need to stab your thumb or any other part of your body), the connector pin should slide out a little on the other side. Then it's just a matter of pulling the pin out - perhaps a pair of tweezers would do the trick.
Hope this works for you!
Posted on Mar 04, 2008
SOURCE: how to adjust metal wrist band on casio watch?
Take it to walmart or any store with a jewelry section, they'll fix it
Posted on Sep 20, 2008
escapement
  • 2334 Answers
You may or may not have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Mar 01, 2009
I have bought citizen watch JR3080-51L , and I need some more links because I got a watch that is good for 7" wrist and I need 8.5" wrist. Thanks
I've had to get extra links before, especially for ladies SS and gold bands. Sometimes a local dealer will have spares that will fit your watch. But, the best source I've found is Ebay. Let me know if you have the stock band or something else. I'll try to help you locate some extra links, or another replacement band at a modest cost. Thanks, Bill
Sep 06, 2010 | Citizen Eco-Drive JR3080-51L Wrist Watch
Ia am looking to bay a watch wrist band
mcdevito75 here, Ebay is your best bet. They have a large selection of wrist bands for all watches. Or, you can visit a small watch repair shop in your area for a new band.
Aug 19, 2010 | Casio Sea Pathfinder SPF70-2V Wrist Watch
My watch band is ripted
I don't know this watch in particular, but I know there are two main types of bands. Coded and non-coded. The S120 uses non-coded. That means you can use possibly any band on the market. Bands I know are compatible: Sigma and Ciclosport. The Polar bands are sealed, so you can use them while swimming. That's not true of the other two I mentioned - but the upside is you can replace the battery yourself once it wears down. You can probably get a replacement band from Polar directly, or buy a cheap knockoff elsewhere.
Jun 05, 2009 | Polar S120 Wrist Watch
Broken wrist band
The easiest is to bring it to Wal-Mart, or another store with a watch section in their store, if you buy a new wrist band, they;ll put it on for free. If you're feeling DIY, pull the watch band to the side, untill the metal bar inside is ejected form the slot in the watch, from there, insert the new band's bar into the slot, and voila!
Nov 15, 2008 | Casio G-Shock GW300CA-1V Wrist Watch
Skagen 596XLTXM Titanium Mens Watch
good morning ! you need a puncher pin and anvil to remove the pin on your watch band punch or push the pin use the puncher pin according to the arrow sign,full the pin to remove,and fush to fix again,do it carefully,thank you ! god bless .
Aug 27, 2008 | Skagen 355LGSC Wrist Watch
Watch band
How can I remove a link from my watch band to fiit my wrist?
Dec 22, 2007 | Fossil AM 3688 Wrist Watch
Shortening the Length of a Metal Wrist Band
I just did this for my wife's new Kenneth Cole wrist watch rather easily. You don't need a screwdriver, but a short section of a paper clip will do. I just set the band on a raise surface to allow room for the pin to be pushed out using the paper clip. For this watch, one side of the pin resembles the slotted side of a small screw - but it is not a screw. This is the side that bulges up a bit to help the pin stay in place. I believe if you punch it out from the opposite side it will fall off quickly, but if you do from the bulged side it, too, will come out but with some resistance. To reattach the band you need to punch the pin into the slot in such a way that its bulged side is on top otherwise you may end up with a bent pin. You must also first line up the hole with the paper clip before reinserting the pin. Good luck.
Nov 06, 2007 | Kenneth Cole KC3289 Wrist Watch
Versace watch
Sep 22, 2006 | Versace 27473-008-00 Wrist Watch
Watches Logo
27 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
