I have a carrier A/C system controlled by a carrier TSTATCCBAC01-B non-programmable thermostat with 4 wires connected as follow: white-W, green-G, red-R and blue-Y which I want to replace with a Honeywell T8601D programmable thermostat that has the following terminals available; C, OT,OT,R,B,W,Y,O, and G. My problem is that when I connect the wires on the Honeywell to the same terminals as they were on the carrier the system seems to work but only the fan turns on while the commpressor stays off all the time. Someone told me that I needed a jumper wire so it'll give power to the compressor but couldn't tell me from what to where. What should I do or how do I need to make the connections? Thanks for your help.
  • Ajax6969 Aug 14, 2008
    same problem here the wizard says to jumper r to Rc but THERE IS NO Rc!
chillmaster
  • 104 Answers
SOURCE: Manual Thermostat replcaement with Programmable Digital unit.
Hopefully there are markings on the old t-stat as to what terminal is what.
on the honeywell 8000 use the heat pump labeling and then the standard wiring would be
R- red
AUX-white
Y- yellow
B- O/B
C- black
G- green
There should not be a bare wire, it probably just has the insulation stripped back way too far.
You should probably open the furnace and compare the terminal label in the furnace to the wire color. normally yellow and blue pass through the furnace and are wire nutted to wires going to the outdoor unit. In the furnace the white wire will connect to the w or w1 terminal. also, you will need to set the Honeywell stat to have the following parameters.
170-7
190-1
200-0
other parameters that I did not specify, you may read the manual and make your own decision but I recommend factory settings for the other parameters
Posted on Jun 18, 2008
  • 11 Answers
SOURCE: honeywell t8601d showing a square
There is a sensor that shuts the compressor down when the freon (refrigerant) is low. The tech probably "shorted" out this sensor. If the unit went on when he did this, the charge is low.
Posted on Jul 08, 2008
  • 306 Answers
SOURCE: I'm installing a Honeywell RTH7600B
Every thing the same except take your blue wire and replace the yellow for it. So when you hook it to t-stat goes like this
Red to R
White to W
Green to G
Blue to Y
Posted on Jan 16, 2009
pierre1811
  • 144 Answers
SOURCE: replacing thermostat: tstatccshp01 with th8320u1008
Hook up o to o/b, then in the installation programming set the change over valve to energize in cool. Then hook up w to aux. Good luck.
Posted on Jan 21, 2009
SOURCE: Carrier Infinity Control Thermostat SYSTXCCUID01-B
Your old stat is wired for a traditional thermostat and not a communication stat like the new infinity you have. There is a module plug on the furnace board that will need to be connected to the new thermostat for it to work. The wires that are wired now are from a terminal strip inside the furnace. Please contact your local Carrier dealer. They may be able to get that harness for you
Posted on Jan 10, 2010
Need help understanding how to wire a new programmeable thermostat. I currently have a White Rodgers 1F73 model (non-programmeable) connected. I am confused with the instructions on how to connect the...
the black wire is your common wire, you need to program your thermostat, in the advance mode, to tell the t-stat if your heat pump reversing valve is energized on cooling or heating, is the orange wire connected to your t-stat.= w2/o/b
Dec 20, 2014 | Honeywell Heating & Cooling
I bought a Hunter 44155C programmable thermostat to replace my Carrier non-programmable one. The wiring on the carrier is: W- white wire O- no wire G- green wire R- red wire C- blue wire Y- yellow...
Hello,You need RH/RCjumper together=red wire...C=blue wire...G=green wire...Y=yellow wire...W=white wire...O/B unused for reversing valve for heat pump.Hope that helps. : )
Nov 10, 2010 | Hunter Heating & Cooling
Carrier 6 wire, installed programmable hunter ther...
Is this a heat pump? Look in the thermostat. You should have something like the following.
Red wire to R terminal
Green wire to G terminal
Yellow wire to Y terminal
White wire to W or W1
Blue or Orange wire to the O or B terminal
Brown wire to C terminal.
Let me know what you have in the thermostat. The wire colors are not always the same.
May 21, 2010 | Carrier 38BRC048 Air Conditioner
Installing thermostat - extra wire?
you have to go down to your furnace and follow the thermostat wire ...it connects to a terminal strip or fan centre...the color doesn;t really matter...installers mix and match all the time....look at the furnace wiring and mark it down...Red on "R"...Green on "Y" whatever it is...and connect it accordingly upstairs...if you only have 4 thermostat wires downstairs you will need a jumper wire between RH and RC...if you have 5 wires you will see 2 wires on "R" at the furnace.,...and connect either to RH and RC at the thermostat
Nov 01, 2009 | Honeywell Electronic Programmable...
I bought new Honeywell non programmable,letters are different.
If you have a 5 wire thermostat then you have a two transformer system a cooling transformer and a heating transformer.
The cooling transformer wires to Rc - Y - G,
and the heating transformer wires to R - W the R terminal heating would be the #4 terminal from the old stat.
Aug 12, 2009 | Honeywell Electronic Programmable...
Upgrading Thermostat
Looks like your system is a heatpump system and that t-stat will not run a heatpump , you need a t-stat for 2heat and 1 cool systems
Jan 30, 2009 | Honeywell Programmable Thermostat Heater
Replacing a Williamson (White Rogers) Termostat
rh is power for cooling terminal and rh is power for heating terminal connect red wire to rc or rh and there should be a jumper between rc and rh if not install one all other wires are color coded correctly. now the blue wire is not used.
Jan 05, 2009 | Honeywell Electronic Programmable...
Hunter 44360 thermostat wiring
OMG! has anyone came up with a solution? I have the same problem as mlc3530b
Mar 08, 2008 | Hunter Fan Company 5/1/1 Programmable...
Dec 06, 2007 | Heating & Cooling
Heating & Cooling Logo
273 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
