Question about Garmin nuvi 255W GPS Receiver
I have lost all UK & Europe mapping - except for major roads. This was initially built in to unit. Have SD card for Australia & New Zealand - this works fine.
  • 1,940 Answers
The maps are stored in specific mapset files with *.img extension in the flash memory of the GPS unit. Each mapset file contains one or many maps in it. Beside that, the Garmin GPS navigator can also recognise and load up one additional mapset file from SD card residing in the "Garmin" folder and named as "gmapsupp.img".
Here are the mapset files supported by Garmin Nuvi 255w GPS navigator:
  • gmapbmap.img - the default base map
  • gmapprom.img - the primary mapset
  • gmapprom1.img - the secondary mapset
  • gmapoem.img - the OEM mapset that cannot be unselect by user (if it exist)
  • gmapsupp.img - the supplemental mapset which you can have one in the GPS flash memory and another one in the attached SD card.
Therefore, the Garmin Nuvi 255w GPS supports up to 6 mapset files, including 1 in SD card. Normally new maps installed by the user will be stored in gmapsupp.img.
You will lost all the maps in the previous mapset file if it is overwritten by a new file with same filename. If you want to keep the existing maps, ensure that you store the mapset file with an unused filename (from the 5 filenames above). Alternatively, you can make use of special tools to merge new maps into existing mapset file.
You can view the name of your base map in Tools > Settings > System > About > Basemap.
You can view the name of maps in the other mapset files in Tools > Settings > Map > Map Info. There, you can tell the GPS to load the map by checking on its name, or not to use the map by unchecking it.
In case there are 2 or more non-overlaping maps available for the same location, the map with the highest priority number (defined in the map itself) will be used by the GPS.
Note that certain map which are locked by vendor need a 25 bytes unlock key stored in a *.unl file in the same folder and with the same name as the mapset file where the locked map is stored in.
You might probably also interested to read:
Posted on Mar 13, 2011
Bought a VIA in California Used it for our trip Now back home in New Zealand an wish to use it here Says I have free lifetime maps Can I get free maps here Am I able to put an SD card in it
I didn't see an SD card in the specs. Maps are of US Canada & Mexico. I would contact TomTom to see about new Zealand. If not sell it on EBAY
Jan 05, 2018 | GPS
I have bought an S.D. Card loaded with Western Europe for my recent trip to England, but when I got there, and loaded the card, it loaded up and went to the front page, and no further, I sought advice from...
So it never work even on a different unit so the problem there can be with the SD card the data inside it might be corrupted, how about if y9ou check the content of that SD card to make sure data are still there...
Hope that helps.........
Sep 18, 2008 | Tomtom GPS
Magellan Exploris 200
you need to request for the maps and updates through mail to the company sir
Jul 31, 2008 | Magellan eXplorist 200 GPS Receiver
Garmin nuvi 1300 Query
Usually they come preloaded with some maps and you purchase additional ones. Check the manual that came with it or the box and that should tell you which ones it has. Generally speaking a basic unit bought in the UK will come with UK & Ireland preloaded, more expensive unit may have UK, Ireland & Europe and the most expensive may have all three plus USA. It's unlikely you will have 'lost' your USA map. The unit should have a 'drop down' menu which allows you to choose which map to load. Hope this helps!
Jul 26, 2010 | Garmin nuvi 1300 Car GPS Receiver
Need latest maps for new zealand
Here is a link to the SD card version. It is also available on DVD. SD card is the easiest to install and use. The SD card version can also be transfered to other Garmin units like the Oregon 450 if you plan to go hiking, boating, or geocaching!
http://www.gpscity.ca/garmin-microsd-australia-and-new-zealand-city-navigator-nt-2010.html
Cheers
Jul 12, 2010 | Garmin nuvi 250W GPS Receiver
I downloaded a new version of the Garmin Europe maps (2011.10 from 2010.10) but it is too large a document for my sat nav a nuvi 255. I have now only got central and eastern europe, which I want , but I...
Copy the new maps onto the SD card be sure that the card has enough space on it. ( you might need a SD Card reader ) copy the old maps onto your PC before deleting the SD card, copy all the data into the root folder of your sat nav. hope this helps
Apr 27, 2010 | Garmin Nuvi 255 GPS Receiver
I need help installing a map onto a gramin sat nav
No. They are refering to maps sent from the computer to the Garmin device. Maps are not transferred off the SD card to the unit. Simply insert the SD card into the device and the Garmin will read the maps from the card.
to double check follow these steps
  1. Power on the unit with the card in
  2. Press Tools
  3. Press Settings
  4. Press Map
  5. Press Info (or map info)
This page should list out both your UK and Ireland maps(old as dirt) and your new Benelux and France maps as well
Apr 20, 2017 | Garmin Nuvi 600 Car GPS Receiver
Does not have all the roads on the navman
only one solution really, up date your maps. Unfortunately you cannot just update maps for the UK, only Western Europe which include latest maps for UK (November, 2008) - go to 'navman.com/' the site \is 'Navman - beyond navigation' - click on 'UK' - when page comes up click on 'visit our online store' - on the left click on '2008 software and maps' - click on the SD card for Fseries - £39.95 inclusive
Mar 13, 2009 | Navman F20 GPS Receiver
Add Europe sd card to Garmin 660
No. When you plug in the SD card, the Nuvi will load the map from your SD card. Once you get to the main menu, select the wrench symbol, then the map symbol and then "map info". You should see both the US and Europe map. Make sure the Europe map is checked. You can uncheck the US map. This is how you switch between maps. The reason why you have to have the extra map on the SD card is because the Nuvi can only have one map on it's internal drive, one at a time.
However, backing up your US map is a good idea.
Good luck,
- Jim
Nov 21, 2008 | Garmin Nuvi 660 GPS Receiver
Changing maps already installed
Hi, Answers to your 2 questions 1 and 2 . ...... 1/ go into PREFERENCES , hit right arow key till you see MANAGE MAPS , Tap that MAP icon and in there will be all the maps you have on the SD card. Select the map you require by tapping the screen. ............................................. 2/ YES , backup the SD card to your PC first. ( you should save everything on the card as it is ) Then delete the Europe map off the SD card and replace it with the USA map . You will need the authorisation code for the USA map in order to activate it. When you return you can swap the maps back again.
Mar 15, 2008 | Tomtom One Europe v2 GPS Receiver
Garmin nuvi 255W GPS Receiver Logo
225 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
