The power filter board at the base of the dishwasher has gone faulty or you may have dislocated a connector on the filter board at the base of the dishwasher. This is the same board that has the flood switch on it.
The connector provides power to the drawers. If this is not the case then the filter board itself will have gone faulty with the water falling on it.
This part can be got from this site. The worst scenario is that you ran the heater on the lower drawer with no water causing the heater fuse to blow. This cuts the power to the drawer controller. This is very expensive to replace as the fuse is integral to the heater. Unfortunately you will not will be able to get rid of the F1 on top drawer until the power to bottom controller is restored.
The reason water spilt out is because you did not have the lid seal on when you ran the wash pump.
Make sure the mains plug is taken out when working on the dishwasher.
thanks for your help. I ordered the replacement part and have had it fitted but still the same problem exists ? (No power to the bottom drawer and F1 error on the top drawer). What could i have done wrong, is there something i shoulpd have reset when install the new part to clear the memory ?
Please confirm which parts have you changed and on which drawer.
Remove the top drawer controller and replace it on the bottom drawer and see if the bottom drawer is functional.
Water leaking out of front doors of dish washer
