Question about Vacuums
Brush will not turn,motor not spinning brush.
  • 1,940 Answers
Check and replace your belt from the motor to the brush. Remove any hair, etc. that may be tangled up as well.
Posted on Mar 13, 2011
The spin brushes on my hoover steam And vac don't
Either the pin on the brushes that attaches to the motor shaft is broken, or the motor is dead. Did you check the switch on the front of the unit to make sure it wasn't turned off?
May 16, 2012 | Hoover Vacuums
Miele brush bar not spinning
Either the touchpad is defective, or the motor is bad.
May 11, 2012 | Miele Vacuums
Brush roller not spinning. belt, spindle okay. roller taken out and cleaned, no thread. replaced but no dice. ???
Use only BISSELL Style 10 Replacement Belts (#32074) in your BISSELL PowerForce Bagless.
  1. Unplug cleaner from electrical outlet.
  2. With Rotating Floor Brush removed from vacuum cleaner, grasp old Drive Belt and remove from Motor Pulley. Discard old Drive Belt.
  3. Place new Drive Belt over Motor Pulley and stretch other end over Rotating Floor Brush in the space between the bristles.
  4. Place ends of Rotating Floor Brush down into slots on sides as shown.
  5. Turn Rotating Floor Brush by hand several times in the direction of Motor Pulley. If properly installed, Drive Belt will center itself on Rotating Brush.
  6. Reposition Brush Cover and snap back into place. Check to be sure all three latches are secured.
  7. When you turn on the vacuum, do you see the motor that spins the belt spinning at the bottom? If not, it sounds like you may have a burned out motor.
If suggested solutions do not correct the problem, call:
BISSELL Consumer Services 1-800-237-7691
Monday - Friday 8 a.m. - 10 p.m. ET
Saturday 9 a.m. - 8 p.m. ET
Jun 01, 2011 | Bissell 6594 PowerForce Bagless Upright...
The spinning brush isn't moving
Belt may be off the motor spindle, with the vacuum off try turning the brush by hand, does it turn freely or can you feel the resistance of the motor?
May 17, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Brush is not rolling. I have checked the belts
Unhook the belt see if the motor shaft turns by itself. If it doesn't then the motor is the issue. If it runs then its probably the belt or the brush roll.
Dec 01, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Hoover Agility F6215-900 brushes won't spin
first it has to be on carpet mode. the vibration of the motor could have shook a wire lose or the motor is either jammed of has fried.
Jul 31, 2009 | Vacuums
Spin brushes wont spin and the switch wont turn machine off. I have to unplug it.
for the spin brushes it is most likely the motor is fried if you smell something burning it could be jammed or the wires have be shaken off the motor terminals. for it not turning off you need a new switch.
Jul 29, 2009 | Hoover F7431-900 SteamVac Vacuum
4296 Robotic Vacuum _ Brush quit spinning
i had the same prob. i contacted i-robot and was told the motor that turns the brush is shot. there is no replacement part. they offered to replace my i-robot with a new one from the 400 series. at about 60% of a new one. that's the only option that i know of.
Apr 09, 2008 | iRobot 4296 Robotic Vacuum
Bissell Proheat 2x Series 8920 - Brush Belt Metal Shaft Sprocket won't turn
Most likely the brush motor is bad and not turning, part #2036757, would sell for around $23. To get to it, start taking out screws on the top cover, that motor is under the that top access cover.
Jan 22, 2008 | Bissell 8910 ProHeat Clear View Upright...
Vacuums Logo
26 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
