Question about Pool & Spa
My lay z spa leaks out the bottom when the pump is on after I left it out all winter, think water had frozen in it and cracked it inside. Any ideas?
  • 990 Answers
SOURCE: I have a Hayward 100 ID series spa heater. I did
Your by-pass assembly may have been damaged and is causing the water to overheat inside the heater causing the clanging. To fix this you will need to break down the water supply side of the heater and replace the bad parts. good luck and I hope this helps.
Posted on Apr 18, 2010
SOURCE: lay z spa water pump is faulty where can I get a
Hi Im Chris From BVL Elecric,
I cover Bournemouth and surrounding areas and supply solutions to most home electrical problems.
A lovely lady customer called me out today to diagnose faulty
LAY-Z-SPA
pump/heater that kept tripping the RCD.
After scouring the net and finding this same problem over and over again but no solution,I decided to get personal with the blighter!!!
RESULT:- problem solved,
Customer very happy,
no new parts fitted,
water heating fine now.
If you live in my coverage area,have a LAY-Z-SPA that is faulty,no or limited warranty then give me a ring and I will be only to happy to come on over and fix it for a small fee.
just think that dead spa/pool heater/pump could be heating your water again tomorrow and there is plenty of summer left to enjoy it.
You can find my details quite easily , just google BVL Electric Bournemouth
Posted on Jul 02, 2010
Coastsider
  • 331 Answers
SOURCE: water is pouring out the
It is possibly coming from the heat exchanger. Most heaters have a copper tube style exchanger, capped at each end by plastic or metal headers. If the tubing has been subjected to any corrosive water condition such as low PH, low calcium hardness or very high cyanuric acid levels, the tubing may have deteriorated and is leaking. You may have dismantle the heater further and check for leaking.
Posted on Sep 10, 2010
  • 111 Answers
SOURCE: leaking lay z spa pump
Firstly try some Fix-a-leak spa leak repair.
If the suspected leak is less than 1/8" that should fix it.
Or remove the paneling to find where it is coming from, there is no easy solution.
Posted on Jul 27, 2012
jonsnell4
  • 23148 Answers
SOURCE: Lay z spa miami. Pump leaking water out underneath. Just replaced water pump in it.
I would check the water seals.
Posted on Jan 20, 2017
Housing on bottom has developed cracks and water leaks out. What caused this steel housing to crack??
In winter when it has frozen and the pressure washer was in the shed you can assume that this may have been a cause.
Nov 07, 2015 | Garden
Model #FFLE2022MW0 Frigidaire washer leaking water at bottom
pump housing cracked by coins or wires leaking
or rubber somewhere
if you isolate the water and waste and mains
the lay it over on the side away from the soap drawer
it wont leak
and you can access under it
and investigate where the water is coming from
bet you its the pump plastics cracked ,..
i would do this now dont use it for now
and fix it
this type of error can cost you a controller board ...
you can save lots of time by checking round the door seal of rubber issues inside its folds etc
but i still think its the pump or some rubber hoze loose
see in being one of the intakes or perhaps the drum from drawer rubber ... so
lay it over and check
no chance of fload if you lay it over on the side away from the drawer with the door closed
Apr 28, 2015 | Frigidaire Washing Machines
Center pipe was cracked when we took it out to replace the sand what would cause this plus there was sand under the bottom cover
Typically, the cracking of internal filter tank components is due to freezing temperatures over the Winter season. You should always COMPLETELY drain all water from your filter and store it inside during the winter.
Another reason is over chlorination of your pool water and/or adding chemicals directly to your water thru the wall skimmer.
Aug 27, 2013 | Hayward SAND FILTER, PRO SERIES
Water leaking from bottom left of 350 engine
Sounds like a bad freeze plug but running the heat should not affect it. A cracked block is unlikely unless it has been frozen with not enough antifreeze. Does it only leak when running or does it also leak sitting still?
Sep 17, 2012 | 1995 GMC Sierra C1500
Leaking lay z spa pump
Jul 25, 2012 | Pool & Spa
Water leaking out of bottom of washer
It sounds like water was left in the pump and i froze over the winter and cracked the pump housing. You can try taking the gun hose off and blow compressed air where the hose hooks on to blow waterwater out of the pump and dry the bottom. Then put some apoxy on the crack to seal it.
Mar 18, 2011 | Karcher 2500 PSI Pressure Washer
I have a Hayward sand filter and its leaking from the bottom. I know this because water is collecting under the stand it sits on. I can't move because of the plumbing. What do I do.
Depending on how close the pump is to the filter, you may be getting tricked and the shaft seal in the pump is leaking. If the bottom of the filter is leaking, it's either the drain plug, which is obvious and you can see it. Or the tank is cracked because it wasn't winterized properly, depending on your situation. There is nothing else underneath that filter that will leak. You need to locate exactly where that water is coming from. If it is the shaft seal in the pump, it is hard to see but look underneath your pump where the plastic housing meets the motor, the shaft seal is in that area, although you can't see it because it is inside the pump, but if it is leaking, that is where you will see it. Need an update after you check that stuff out.
Jul 13, 2010 | Hayward SAND FILTER, PRO SERIES
Lay z spa water pump is faulty where can I get a
LAY-Z-SPA
Dec 27, 2009 | Pool & Spa
Brand new filter pump leaking
If it is brand new and leaking, it sounds like your pool filter has a connection problem. Check your connections to make sure that they are tight and sound and that you do not have any hairline cracks.
Jul 16, 2009 | Intex 2500 Gal Easy Set Swimming Pool...
Diagnostic Message: Ec ...
press the temp button, and then press the light button, that will change the mode of the tub.
Apr 15, 2009 | Qca Spas Jewel Series Topaz Plus Hot Tub
Pool & Spa Logo
278 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
