Question about Minolta EP1030/1030F CS/PRO Copier
Mu minolta is displaying c40 error - Minolta EP1030/1030F CS/PRO Copier
  • Minolta Master
  • 1,297 Answers
C40XX refer the exposure lamp,exposure lamp thermistor or thermofuse.Please read the correct error code:400,410,420.
Posted on Jan 04, 2012
Konica minolta c550 displaying a code C-B116, how can I solve this please?
Konica Minolta Ineo 223 Fax card Error C-B003 \ C-B116 ...
www.copytechnet.com > ... > Copier Technical Discussion > Konica Minolta
Feb 6, 2014 - 10 posts - ‎6 authors
The other errors that appear are C-B116 & C-B003, i've tried the below : 1. .... Also ensure you have the fax set to the correct country code. Error Code konicaminolta bizhub500 error code C-B003
7 Sep 2010
How Do I Access Techrep / Service Mode? - Page 4
18 Jul 2008
More results from www.copytechnet.com
Error code C-B116, what does it mean? - Fixya
www.fixya.com/support/t1535504-error_code_c_b116_mean Jan 13, 2009 - Touch the following code on the trouble code display screen. Stop ? 0 ? 7 ... 4 Answers. SOURCE: Konica Minolta Bizhub C352 error C-B116.
Bizhub c250 code c-b116 - Fixya
www.fixya.com/support/t11325427-bizhub_c250_code_c_b116 Jan 17, 2012 - bizhub c250 code c-b116 code c-b116 on the bizhub c250. ... on the display you'll see the Trouble reset button on the display, touch it and turn ...
Konica Minolta Bizhub C352 error C-B116 - Printer
www.allprintersmn.com/konica-minolta-bizhub.../q724088-konica_minolta_bizhub_c... fix Printers & Copiers - Konica Minolta Bizhub C352 error C-B116 about Printers & Copiers. ... Konica Minolta BizHub C550 Error Message ... ERROR CODE C11B2 ON DISPLAY - Konica Minolta bizhub C250 All-In-One Laser Printer. konica minolta c550 displaying code B116 Google Search
Mar 15, 2017 | Konica Minolta Office Equipment & Supplies
Minolta EP1031 C40
Exposure lamp is out. If you raise the top part and press the start button a very bright light should come on and move down the glass, the code indicates that lamp is out or the control board that controls it is out. There is also a fuse on the assy. that the lamps is on might see if that is out?
Dec 13, 2013 | Minolta EP4000/5000 CS/PRO Copier
Minolta error disply on ( pc )
What code show in the display and what you do clearely describe
Aug 18, 2013 | Minolta Di152 Laser Printer
Minolta EP2130-Error Message E-6
Read corect the error code you have two display ex.C 6XX
Feb 18, 2013 | Konica Minolta Minolta EP 2130 Laser...
My minolta photo copy is showing C40
change the fun cooling assembly,remove the rear parts,PWBa and change the fun.
Aug 08, 2010 | Minolta EP4000/5000 CS/PRO Copier
Error code c2152
good to
Imax Konica Minolta C451 Bizhub
I have a problem is the cod C2151 what to do Thanks
Sep 24, 2009 | Konica Minolta bizhub C450P Laser Printer
INstalled a aftermarket Berringer clutch.
G'day Garrison , C40 is an idle air control(IAC) valve problem.Check all hoses to the valve.Check the valve wiring to the valve and to the ECU. ..Cheers.
May 14, 2009 | 2007 Suzuki GSX-R 1000
Code c40
I believe a c40 is the trans port sucation fan.... It is under the trans port belts. Did you try to reset the code? The Trouble rest botton is behind the display pannel control for brightness. Inside left side above the fixing unit.
Feb 03, 2009 | Minolta EP4000/5000 CS/PRO Copier
LCD Display displays Error C0510 Can't do anything about it.
low temperature issue. There is a trouble reset procedure that should be performed by a Minolta tek
Oct 26, 2008 | Office Equipment & Supplies
PDT 6840
By definition the MU gets it's IP address from the DHCP server. If it's getting an address that's already in use, then it's the DHCP servers fault not the MU. I would look at the server and make sure it has enough available IP addresses to go around.
Dec 10, 2007 | Symbol PDT6842-NIS632EU Portable Data...
200 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
