Question about Tascam US-144 Sound Card
What cables for yamaha keyboard psr295 to connect with tascam 144
Excuse my ignorance i have a yamaha psr 295 how do i connect it to the tascam 144 , what cables do i need
i have the yamaha usb cable and the usb cable for tascam .but don't know how to attach the psr to tascam.
your help greatly appreciated
Alex
  • 3 Answers
There are different options depending on what you want to achieve. If you want to send only MIDI data to your PC (for example, to run a VST instrument), then you can use a standard MIDI cable to connect the "out" on your keyboard to the "in" on your Tascam. You should also be able to use the Yamaha USB cable to connect directly to your computer, which would then bypass the Tascam (still giving you the same outcome, but without the need to buy any extra cables.
However, if you want to send the audio data (i.e. the actual sound) of the keyboard to your PC, you would simply use a standard guitar lead from the line out of the keyboard into the line in (both, if your keyboard has stereo outs) of your Tascam. This will eliminate any need for VST instruments, as you will be recording the audio signal directly.
Posted on Sep 10, 2008
    Problem Solver:
  • 6 Answers
You need standard Midi cables - I think the end piece is called a "DIN" connector.  One for in and one for out.
Posted on Sep 06, 2008
My yamaha psre323 does not connect
I have a PSR-E323 and to connect it with my pc using a MIDI connector should i install driver from http://download.yamaha.com/usb_midi/ ??? I tried to install that.. An error msg popped up... error 25001 no device is connected. connect a device and try again. If the "found new hardware" wizard appears push the cancel button...What should I do?? Help me pls...
Apr 10, 2012 | Yamaha PSR-E323 Keyboard
Looking for manual for Yamaha PSR 295 keyboard
Hey there,
Here's a link to the manual you're looking for:
http://usa.yamaha.com/products/musical-instruments/keyboards/digitalkeyboards/portable_keyboards/psr-295/?mode=model
Click on the "support" tab. It's the second link down.
Hope this helps you out! If it did, feel free to rate me :)
Cheers
Mar 08, 2011 | Audio Players & Recorders
The keys are broken and some at no sound can I order the notes and sound kit. Yamaha PSR-295 . Regards Elias
Hi, i think you can. You can go to any of the Yamaha companies around you area and explain to them the problem of the keyboard. They will give you good and quality replacement part for your Keyboard.
Make sure you go to only Yamaha company to avoid getting a wrong part for your Keyboard.Avoid road siderepairsforissue like this,it's more complicated to handle
I guess that will do.
Thanks for using fixya...
Jan 12, 2011 | Yamaha PSR-295MS Portable 61-Key...
Do you have yamaha keyboard psr 2000 spare parts?
My keyboard yamaha psr2000,so I want parts silicone rubber keypad 61 and including electronic board,thank you.
Feb 12, 2010 | Yamaha Full-Size Keyboard
Yamaha PSR-280 : AC power instead of DC power
An answer, but likely not a solution. I believe all Yamaha PSR series keyboards use the same 12 VDC adaptor, so I looked at the electrical schematic for another model I have. There seems to be no fuse on the power input. There are two components shown on the positive and negative wires off the power socket, but the symbols do not look like anything I have seen for fuses - they may be resistors. Power goes directly to a 5 VDC voltage regulator, which powers all of the solid state componenents. Too much voltage of the wrong type could have easily ruined many of the sensitive components.
Your only hope is to check the power socket area for the possibility of having fuses. My drawing shows the power socket, voltage regulator, and audio power amplifier being on one circuit board. That may not actually be the way it is in your model.
(your English is fine)
Feb 23, 2009 | Yamaha Portable Keyboard with 61...
Hellp!
Are you hearing the sounds from your speakers on your computer only?...accordianman
Feb 03, 2008 | Tascam US-144 Sound Card
Tascam US-144 Sound Card Logo
681 people viewed this question
Top Tascam Computers & Internet Experts
Ben Armstrong
Electric Dime
Electric Dime
Chris Larocque
Are you a Tascam Computer and Internet Expert? Answer questions, earn points and help others
