Question about Casio EXILIM EXZ35 Digital Camera
My camera fell on the floor and a lens error appeared when i tried to open it
    Guru:
  • 441 Answers
Good day,
This tip will explain a few methods on how to try and fix your lens if it is stuck or you get a lens error on your screen.
Please note that all these methods are used at the users own risk and that I can not be held responsible for any damages or losses that occur while trying these methods.
1. If your camera is still under warranty, send your camera to the manufacturer to be replaced or fixed professionally.
2. If your camera is out of warranty try these methods.
  • Make sure your batteries are fully charged.
  • Remove the batteries for 10min. Replace the batteries and see if the problem persists.
  • Try compressed air. This method can be useful if there are any sand or any other object stuck in the lens motors. Use compressed air with a fine tip. Direct the air between the camera body and lens and move in a circular motion around the lens to complete a full rotation.
  • You can also try to tap the padded USB cover firmly on a flat surface like a table. This is sometimes a surprisingly effective method.
  • The last method is to try and force the lens. Turn of your camera and place it on its back on a flat surface. Look at the spacing between the lens and the body and see if the gap is consistent all the way around the lens. If the gap is not even it is likely that the camera fell while the lens was extended. Now VERY GENTLY push down on the lens were the gap is the biggest until you her a "click". This will indicate that the lens is back in place. Try powering back on.
  • If the lens does not extend or it extend and retracts turn of the camera. Hold the camera in your one hand and with the other hand turn the one part of the lens in a circular motion. Rotate both sections of the lens until you hear a "click". This will indicate that the lens popped back in place. Power the camera back on.
  • The last method you can use is to turn the lens while powering on the camera until you hear a "click". Power the camera of and back on to see if it works.
If any of the methods listed above failed to work for your lens problem it would be wise to take it on to a professional to get your camera repaired.
Thanks for taking the time to read my tip and feel free to let me know if it was of any help.
Regards
15073327
Posted on Apr 10, 2011
How do I fix lens error problem on the described camera?
hi,
lens error occur normally when it fell or the lens shaken, if so open the camera, take the lens unit out, disassemble the lens unit, then fix it again properly. example below:
(this is not the told model)
Dec 10, 2015 | Nikon Coolpix S3000 Digital Camera
Hi My Nikon D5100 camera giving a sin of Autoexposure error. Contact a Nikon authorized representative message after it's drooped from my tripod on the deck floor (Wooden Floor). The Nikon55-300mm
There is no way to really answer this question as the camera was dropped. If it was dropped with the lens, then the problem could be either in the body or the lens (or both). If you have another lens try it and see if you get the same result. Otherwise you are probably going to have to take it to the shop or send it to Nikon
Jun 09, 2013 | Nikon D5100 Digital Camera
Canon power shot sd 750 fell on the floor and is the lens are stuck open and keeps giving me a error for lens. the lens part fell so the lens now are uneven. is there any way i can fix this?
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Sep 11, 2011 | Cameras
My cam fell on the floor,and ive seen its lens misaligned.i cant use it anymore ....on screen,,,, it appears LENS ERROR....pls help me,,,im in laguna area,,,and i dont know where to find nikon repair...
Your camera lens is already misaligned, so that Lens Error occur, it will not disappear unless the lens is disassemble, aligned the mechanism of lens ( the proper synchronication of mechanical parts) and assemble.
If you cannot do it, send it to the your nearest camera service center, call them first if they can accept repair on your Nikon Coolpix S210, how much, if repaired how many months will be the warranty.
I hope my advice help you.
Jun 11, 2011 | Nikon Coolpix S210 Digital Camera
Good day! my camera unit is SONY DSC-W310 . my problem is about the lens of my camera which fell down on the floor and the lens is open and now it cannot function and it indicates on the LCD this quote...
A lens error can be caused by physical damage to the mechanism that controls the lens, or debris that is interfering with the operation of the lens.
This article may be able to help you with a "do it yourself" solution.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
In the event that your problem is due to physical damage and not just dirt or debris, you will need to take it to a local camera repair shop for troubleshooting-- though with most consumer digital cameras, labor and parts cost of a repair can easily exceed the value of the camera.
Mar 11, 2011 | Sony Cyber-shot DSC-W30 Digital Camera
The camera fell off a desk onto a carpeted floor while uploading pics to the computer. Now the lens will not close properly and I keep getting a "lens error" message. Nothing looks cracked. Can this be...
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Jul 30, 2009 | Canon PowerShot SD600 Digital Camera
Camera felled to floor lens tries but cannot retract camera turns on and off fine, error message "lens error, restart camera" it appears that until lens can function properly and error message is resolved...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Jun 29, 2009 | Canon PowerShot A630 Digital Camera
Lens error
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Mar 23, 2009 | Canon Digital SD900 / IXUS 900 Ti Digital...
Sanyo vpc-e760 digital camera
i have the same problem ..
it was error 16 AND 21 .
im not entirely sure about the error 27 or any other
numbers ;
but i do know for a fact its because there
is something like dirt ; hairspray ; make up etc.
in the lens .
idk how to take the camera apart ..
but your best luck is to kind of jar your camera with your
palm or a book or something .
mine fell on the floor at first and was fixed ,
but today i dropped it in a little bit of sand and hasnt gone
back down yet .
im hoping i can fix it :/
let me know if any of you have any luck .
Mar 02, 2008 | Cameras
Casio EXILIM EXZ35 Digital Camera Logo
154 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
mohamed salim shaikh
Are you a Casio Camera Expert? Answer questions, earn points and help others
