Question about ASUS P4S800-MX Motherboard
Asus Motherboard Constant High POST beep
Hello!
I just recently built my computer, and everything seems fine, except when I poser it up a get a constant high beep that doesn't stop until I turn the computer off. I've restarted the CMOS, unplugged everything and plugged everything back in, checked the CPU and RAM, and nothing works. Does anyone know how to fix this?
  • bahiramalika Aug 01, 2008
    What do you mean by short?
    Okay, I took out all the RAM, and I just got the very same thing.
    I figured it out. I had some stuff from my PSU plugged in wrong. Now when I startup, I get no sound at all, and no picture on my monitor. (I think there's something wrong with my Graphics Card, but I'm not sure).
  • ASUS Master
  • 13,433 Answers
Long beep - memory bank is not plugged well, or broken
continuous beep - no power, loose card, or short.
Posted on Aug 01, 2008
  • Ekse Aug 01, 2008
    remove all ram and try to start up, hear the beeps tell me what you hear and ones you have told me that, put the memory back in and hear the beeps again
  • Ekse Aug 01, 2008
    can you post me the details of the ram? do you get the same when you insert the ram bakc?
P5KPL-AM speaker beep
Hello, I am the technician that will be assisting you today. My name is Norman-Wynne Damstra.
Welcome to Fixya, Sadael.
Yes some-times the case/computer chassis does not have an internal BIOS/CMOS beep code speaker built in.
So what you will need to do is go to your local computer store and purchase a mainboard beep code speaker. You may even find it online at your favorite computer store.
The modern speaker is very small compared to the older mainboard beep code speakers.
Your computer will continue to work without the speaker, the beep code speaker is there to help diagnose/troubleshoot problems when they occur.
Take care!
Dec 16, 2011 | ASUS P5KPL-AM SE Motherboard
I have recently built a new PC with an Asus P8H61-M and upon turning the PC on I am recieving no Visual on either of my monitors
Hello
If this is the first time to turn you on your computer check first the power supply of your computer if connected to their proper connector. Check your memory if clip properly in there memory slot. If you are using Video Card check it if it is properly connected to the connector. Then connect your VGA connector at the back of your computer when you have video card connect the VGA Cable of you monitor to the video card VGA output if does not have connect it with the onboard VGA output. Then press the power switch if the unit is still no visual in monitor try to search or hear a beeping sound in your computer by its on board buzzer. Find which beep you hear from your computer.
No Beep- No Power, Loose Card, or Short.
One Short Beep- Normal Post,, Computer is OK.
2 Short Beep- POST error, review screen for error code
Continues Beep- No power, Loose Card, or Short
Repeating Short Beep- No Power Loose Card or Short
One Long And Short Beep- Motherboard Issue
One Long and Two Short Beep- Video (mono/CGA Display Circuitry) Issue.
One long and three short beep- Video (EGA) Display Circuitry
Three Long Beep- Keyboard/ Keyboard Card Error
One Beep, Blank or Incorrect Display -Video Display Circuitry
Hope this help with your problem. Keep on touch in fixya
Jul 19, 2011 | ASUS P8H61M Intel H61 TX Motherboard
My husband recently built a new computer (previously built 5 others successfully). Motherboard seems to be working properly. Green LED lit. Graphics card works in another computer. Power supply...
Hi, the thing to do here is to narrow down what could be causing the problem, initial suspects would be the RAM chips. If you have known working ones you can try in it, try these, if not, try without one, then swap them over, or even try without both.
Also, remove any components that aren't strictly necessary, i.e. hard drives & cables, cd-rom/dvd drives, extra PCI cards,network cards etc
Another suspect may be just a loose connection, try taking everything out, re-seating it. Again, pay particular attention to the RAM chips.
It could possibly even be a faulty processor, have you another you could try? Try taking it out and re-seating it.
Apr 12, 2011 | ASUS M4N75TD AM3 NVIDIA nForce 750a SLI...
No Signal, No Beep, No POST
Try Replacing CMOS Battery...If you get no power to the motherboard its your power supply. Try reseating everything, processor, ram, video card.
Hope this helps
Mar 19, 2010 | ASUS A8N-SLI Deluxe Motherboard
Cant get computer to
Disconnect everything from the motherboard except the power supply, CPU and power switch.
Turn on the computer. You should hear 3 beeps because you removed the memory.
If you don't hear any beeps, check the power supply. Check all the connections. Did you connect the 4 pin power? Did you skimp on it? A common mistake is to get a cheap, high-power supply. Just because the box says it's 1000 WATTs doesn't mean that will carry a steady load.
Still nothing...
It's either a bad motherboard or processor. If you have another processor that is supported on that board and you know it works, try it. If it boots return your CPU for a good one.
Unfortunatly, if it doesn't boot with a known-good processor that just proves the board is bad; it doesn't prove your CPU is good. You may have more issues.
Mar 08, 2010 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
ASUS P5GD2 Deluxe motherboard with no sound
This is a known isue and ASUS is working on a sound driver for the chipset. Keep checking their site for driver updates. The board should all install with Windows 7 except for the sound drivers. Some people say they can install the vista driver and run it in vist or xp compatibility mode. The other thing you can do is pick up a cheap $20 Win 7 compliant sound card till the chipset driver issue is resolved.
Jan 28, 2010 | ASUS P5GD2 Deluxe Motherboard
Motherboard live then 1 beep followed by 4 beeps then nothing.
The one beep is usually normal for most computers. Is your Video card seated correctly?
4 beeps Refresh error RAM is not refreshing correctly. Reset the refresh values in the BIOS or reset the BIOS.
Jan 14, 2009 | ASUS K8N-VM Motherboard
No display on GA 81G1000 mk motherboard
Some history would be appreciated.
Has this computer ever worked?
Have you recently added new hardware or software?
Has anything happened recently that may have caused this (lightning storm, etc.)?
If the computer was working fine and for no apparent reason now won't POST, first remove everything from the outside (keyboard, mouse, etc.) except monitor. If that works, one of the items you removed is causing a problem.
If not, unplug power, open case, remove all expansion cards except for video, then try again. If you have never worked inside a computer, some help from a knowledgeable friend would be advised. Be sure to touch the metal case before touching any circuit board inside the computer.
Also disconnect the cabling from all of the drives and then retry boot.
Let me know if this helps. If not, we can do more providing you are comfortable working inside the computer at my direction.
Honest1abe
Dec 30, 2008 | Intel Motherboard
This is a new install, no vga out
You Can Try By Cleaning Out The Memories And Checking The Processor Is Placed Right In The Socket
Dec 25, 2008 | ASUS P5P800-MX Motherboard
No sound from p5k3 motherboard
have you connected to the motherboard with correct plug(generally green in for audio out)try with another of speaker if the problem persists than you onboard sound card is having problem
May 15, 2008 | ASUS Computers & Internet
ASUS P4S800-MX Motherboard Logo
554 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
