Removed processor from compaq presario sr1901wm replaced now monitor says no image what is wrong?
  • mannu rawat Mar 13, 2011
    This Agreement does not create any agency, partnership, joint venture, employment or franchise relationship. Our failure to act in a particular circumstance does not waive our right to act with respect to that or other circumstances. We shall be excused for any problem due to a factor beyond our control. If any provision of this Agreement is held invalid or unenforceable by a court of competent jurisdiction, the remaining provisions of the Agreement will remain in full force and effect, and the provision affected will be construed so as to be enforceable to the maximum extent permissible by law. Any waiver of any provision of this Agreement will be effective only if in writing and signed by FixYa.
    Master:
  • 346 Answers
Hello Ron - The two most likely possibilities are that you either did not seat the CPU properly in it's socket (misaligned or bent pin) or that you did not fasten the heat sink properly, or remember to plug the heat sink power connection into the motherboard power connector.
With the heat produced by modern CPU's - without the proper cooling they would melt down almost instantly that's why both Intel and AMD have built in overheating protection which keeps them from even starting if not cooled correctly. When replacing the CPU it is always good practice to apply some new thermal paste after cleaning off the old.
I suggest you try starting the machine with the cover off and see if the heat sink fan is turning. If not that's at least part of your problem. If it is turning I would remove the CPU (careful of static!) and examine the bottom carefully to make sure nothing looks damaged. If it looks normal I would try reseating the CPU slowly and carefully.
In your question you did not say why you removed your CPU. Where you upgrading it to a new one? If so are you sure it is compatible with your motherboard?
Here is a link to HP's info page about your motherboard, including upgrades. Click Here.
It's also a good idea to clear the motherboards CMOS when removing and installing a CPU. The same page has a clear description on doing that.
Please follow the steps as I've presented them below:
1 - examine the info at the link I presented. 2 - make sure the fan is working - If so then - 3 - remove the CPU, examine and if it looks OK replace carefully (It should take hardly any pressure for a CPU to fit into it's socket.) Thermal paste would be nice but there's probably enough on the CPU (unless you've wiped it off) then you would need to get more paste before proceeding.
If that list doesn't help then it's time for a call to HP/Compaq tech support.
Good Luck,
Mikeywaf
Posted on Mar 13, 2011
Compaq presario a928ca laptop has overheating problem laptop overheats within a minute & we cant put it on table also we need to put some support below so that air can pass below it.
The first thing I would do is open the case and remove the fan and heat sink for the processor. You will probably find a little "radiator" looking device clogged with dust bunnies. Clean it out good with canned air and reinstall it. Be sure to clean the processor and heat sink then reapply heat sink compound. Clean all your fans and, with the case open, power up and look at all your fans. Are they all spinning at full power. If not, replace them. Reassemble the case. You should be good.
Mar 20, 2014 | Compaq Presario A928ca Laptop Lcd Screen...
Video wont show
This would be caused by several things.
1) bad power supply causing the computer not to start
2) bad video card
3) bad monitor (does the monitor light come on?)
4) other component bad--disconnect them all except the CPU, memory, and video card and see if you get an image.
Feb 28, 2012 | HP Compaq Presario SR5210NX Desktop PC...
Turned computer on and monitor instantly goes to sleep,also cant turn off the computer using button.have to use switch on power supply
Try this, unplug everything from the other board except the main hard drive, power connections, and monitor. if it does not come up, remove ram cards, leaving one stick. try again, if it is still bad swap ram sticks. If after all of this it still does not work you have a bad motherboard or processor
Nov 14, 2011 | HP Compaq Presario SR5210NX Desktop PC...
Electrical power outage and tried to turn on my Compaq Presario SR1901WM and green light turns on for a second and goes out. Computer will not start up. I reset the surge protector but it is still...
FIRST DISCONNECT THE PC FROM AC!!!! Try the next- disconnect ALL PERYPHERIALS- mouse, keyboard, monitor, pull out the RAM board(s) and switch on the PC. If still the same, pull out the PCI boards- video card, modem, audio, TV, whatever you have and try again. If it turns on, that means that one of the disconnected perypherials is damaged, put in one by one to detect which one is burned. If still no, change the thermo paste between the CPU and the cooler with a new one.
May 31, 2011 | Computers & Internet
I don't know any processors that would be compatible with my Compaq Presario SR1810NX and I'd like to upgrade it. Any help would be appreciated!
The mother board will support any Socket 939 AMD Athlon X2 Processor upto the 4800+ model.
However Socket 939 Processors were discontinued so you may have a hard time finding a "New" one.
Dec 20, 2010 | Compaq Presario SR1810NX Sempron 3200+ 1.8...
How to restore campaq sr1901wm with out a disk?/ i was told with a network key for this compaq i could use the restore disk from a gateway
You can use almost any restore disk to restore the operating system, but you must have a product key for that specific version of windows. Even then, it might not work if the manufacturer has coded that version of Windows to be one of their product keys. Also, even after you do restore the system, you will have to go to the HP (HP bought Compaq) website to download the drivers for your system.
Good Luck,
NOLA Tech
Jan 29, 2010 | HP Compaq Presario SR1902HM PC Desktop
Dark Screen
The back light is bad in your monitor. This is the light source that gives light to the image on your screen so that you can see it. This is a common thing to go wrong with a laptop. You can take it to someone to be repaired or if you are handy you can buy the part and replace it yourself.
Jan 18, 2009 | HP Compaq Presario 2200 Notebook
COMPAQ PRESARIO SR1010V!!!
If the hard drive is is not damage maybe you can save all important files on it.
Please do the step by step troubleshooting of your laptop.
REmove the following:
1. Memory
2. hard drive
3. processor:
4. Battery
try this;
1. Fix some other connection inside the laptop
2. Insert AC plug then start the system.
3. shutdown the system
4. Insert the processor
5. swittch on the laptop.
If beeping; continue
step 3;
6 insert the memory.
7. start the system
8. If display, connect the harddrive.
in step 5: if not beeping:
Either board or processor is dead.
IN step 8.
9. start the system.
10. if the hard drive is detected, and cannot continue booting
i recommend you to reinstall the windows.
Please notify me if problems arises. i will give you further instruction, melnavz.
Feb 04, 2008 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
Computers & Internet Logo
David Payne
David Payne
