Question about LG RC797T
When utilizing the DVD player to record from my cable's DVR, there's a response that says the episode or movie is copy-protected and canot be recorded. my previous DVD recorder copied every program from my DVR with no problems. what's wrong here?
  • LG Master
  • 11,800 Answers
The new recorder comes with security systems in it - when it encounters programs that have a "Do not Copy" signal on them it will refuse to work. This is how it's designed to work, there's nothing you can do to change that. BTW , even if you could do that it would have been illegal - recording a copy-protected program is considered by the lawyers of the channel in question as piracy .
The older one didn't do that because it didn't had the security system.
Posted on Mar 13, 2011
Since my comcast switched to digital I cant record !! Is this DVR compatiable with Comcast digital cable???
Yes,all DVR compatible with digital signal that included Comcast digital cable.U can't record because probally the program u tried to record it copy write protected.What did u tried to record?Just tried to record some plain show,If it is recordable than u know the deal.
Feb 02, 2011 | Panasonic DMR-EH55 DVD Recorder/HDD...
My DVD recorder LG RH1858 isn't recording properly. It shows the message "record blocking sidnal are detected". Please inform.
Unfortunately, your recorder is picking up a signal in the broadcast that copy-protects the show. The recorder is programmed to forbid copying of protected material. Depending on the source of the copy-protection, you may be able to block out the copy protection signal with a hardware filter. One example of these would be the Sima CT-2 that is placed between the S-out of the receiver and the S-in of the recorder.
I hope this helps.
(One common sources with this issue: a DVR that passes on the copy protection to an attached DVD recorder. Particularly some of the new Satellite/Cable receivers with built-in DVRs. The non-DVR models of the products usually filter out the copy-protection.)
Mar 29, 2010 | LG RH177 DVD Recorder/HDD Recorder
My dvd player won't read copied dvd movies but willl read store bought dvd movies in the device manage is says "unable to recover TOC error 0x13570001
one answer is to format the movies after you record them on dvd player. They would then be more likely to be read by the pioneer dvr.
Mar 01, 2010 | Pioneer DVR-107D DVD±RW Burner
Cannot record copy protected movie
yes this do cause a problem (most Disney tapes/dvd and HBO are copy protected)..you not doing anything wrong. but this little gadget helps http://www.amazon.com/Sima-CT-2-Digital-Enhancer-Duplicator/dp/B000AEFVVE get some movies (it do not work on HBO nor Disney products) and just good to have while recording
Jun 20, 2009 | Sony RDR-VX555
Cannot record from my DirectTV DVR, HR20-700
most dvr units froim cable and satellite companies use a type of copy protection that does not allow you to copy programs to a disc. the cable company wont tell you this but they do and there isnt any way to work around it
Mar 11, 2009 | Toshiba D-VR4 DVD Recorder/VCR
I have an error 25 on my dvd recorder
Technically, E25 is a copy-protection error, but I have some additional background on this issue. On the one hand, it could be a legitimate copy-protection error - you are trying to record from a copy-once or copy-protected source - this is especially true if you are trying to record from a Cable/Satellite Box that has a DVR box - since copying to the DVR is considered the first "copy," the Magnavox will not allow you to make a "second" copy.
On the other hand, Magnavox/Funai players see all programs recorded in V mode (as opposed to VR mode) as "copy-prohibited". It records all +R discs in VR mode automatically, so the solution in this case would be to record on a compatible -R disc (or vice versa).
There are two simple fixes for this issue in either case:
1) If you are using a +R disc, switch to a -R disc. If you are using a -R disc, switch to a +R disc. Simply switching the disc type will "fix" Magnavox recorders (long story).
2) If your TV has a "Video Out" or "Monitor Out" (most TV's don't), you can connect a yellow video cable from the OUT of the TV to the Video IN on the back of the Magnavox. This will permanently resolve your problem by fooling the recorder.
Here is additional info about the type of disc to get:
IDiscs that have been tested and are proven to be compatible with this recorder:
VERBATIM DVD+R 8x, VERBATIM DVD+RW 4x
VERBATIM DVD-R 8x, VERBATIM DVD-RW 2x, MAXELL DVD-R 16x, JVC DVD-RW 4x
IWe strongly recommend for good recording quality:
TDK DVD+R 4x/8x/16x, SONY DVD+R 4x/8x/16x, MAXELL DVD+R 4x/8x/16x, SONY DVD+RW 4x,
MAXELL DVD-R 8x/16x, MAXELL DVD-RW 4x
Good Luck!
-Tha Mp3 Doctor
Feb 01, 2009 | Philips Magnavox MWR10D6 DVD Recorder
DVD Menu selection not available from Setup Menu
I don't have movies from premium channels, but do have cable HD channels. When I got the message re not recording in +VR, I copied from DVR to HD in PhilipsDVD-R and then dubbed to DVD.
Dec 05, 2008 | Televison & Video
Cyberhome DVR 1600 DVD
What format are you recording in?If the recorder is set for DVD +R, and your playback machine won't read the disc, you may need to record on a DVD-R, or a DVD +-R. Or vice-versa. Some DVDRW discs will record on one machine and won't play on another. The media are incompatible. Another problem - if you are copying a copy-protected disc, it might not play back either. Are you sure you are finalizing the disc? This process takes 4-5 minutes and requires two or three responses sometime.
Dec 03, 2008 | Cyberhome DVR 1600 DVD Recorder
Recording from DVR.
There is a firmware update posted on the Sony support web site. It takes care of the copy protect error. However, i have encountered an error where the recorder doesn't identify the input signal. It posts the message "waiting for input signal." I have no solution for this one yet.
Dec 17, 2007 | Sony DVDirect VRD-MC3 DVD Recorder
LG RC797T Logo
Computer Repairing
Computer Repairing
