Question about Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
Have a model 665.17602301
Dishwasher starts with normal wash light on and sening light on. It just fills and runs and runs and doesnt stop washing. cked to see if heater was working and it didnt heat. it will pump out if u put it on short rinse. ran diagnostic and all the lights came on and ran through, should i replace board?
  • Jim Owens Aug 04, 2008
    Board was the problem. Replaced it and all is well.
    Sergeant:
  • 225 Answers
On my own dishwasher the cycles are controlled by the temperature - the machine washes until the water reaches a certain temp and then it pumps out and goes on to the next bit of the program. If yours is based on the same principle and isn't heating the water that would explain things.
I wouldn't replace the board yet - I would first try to find out why it isn't heating. It could be the heating element, the relay or the temp sensor (if fitted) at fault.
If you are technically inclined and know enough to delve into the machine safely you could check the heater connections, resistance voltage etc and hope to spot the fault. Let me know what you or the engineer find. D
Posted on Aug 01, 2008
  • Richard Raynor Aug 04, 2008
    Glad you got it working again. D.
How do I reset my KitchenAid Model KUDS35FXSS1
The unit normally has a 1:20 to 1:30 fill cycle with pauses in between while the wash motor starts and stops without running a diagnostic mode this normally happens when the control outputs power to the wash pump motor but the pump doesn't start
Sep 13, 2014 | KitchenAid Dishwashers
Kenmore elite dishwasher model 630 Smart Wash light is flashing
You may want to try:
Press a series of four buttons in quick succession. Press "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore dishwasher to run a short diagnostic test.
Wait for two minutes while your Kenmore dishwasher runs its diagnostic test.
Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel.
Check to make sure that there's no standing water in the bottom of your dishwasher. Standing water in your dishwasher may indicate that your dishwasher has stopped mid-cycle. You will need to press the "Cancel/Drain" button before you can reset your dishwasher control panel.
Dec 18, 2013 | Dishwashers
My dishwasher is sticks in between washing cycles
These mechanical timer machines have to follow a series of logical steps to complete the program - ie, empty. fill to level 1. wash. heat to temp. etc etc
My guess is the machine is not heating, as you say it works for part of the program - or possibly it is not emptying correctly? check water heating element and drain pump.
Program 4 eco is a separate program from 3, using low temperature washing - the machine does stop between 3 and 4 normally and doesnt carry on through.
Jan 30, 2018 | Siemens 24 in. SE64A630GB Built-In...
Kenmore Dishwasher 5871525 stops running after a few minutes
sounds like a stuck key pad since you said the normal wash button flashed.. the other thing is try holding the door shut while you run it.. to see of it is maybe not latching properly..
Apr 10, 2009 | Kenmore 15762 Dishwasher
Whirlpool Quiet Partner II not washing or sensing.
I have a whirlpool quiet partner II and for some reason it does not drain the water out any more and I cannot figure out why....people say that it is the filter but that is unbelievably hard to get to and I cannot find any instructions online or paper work that tells how to break it down. If anyone has any insight please let me know
Nov 16, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher lights blinking
QuietGuard3: Clean light flashing 7 times? Press Heated Dry, press Normal Wash, then press Heated Dry again and press Normal Wash again (that's 4 button-presses) and that should fix it.
May 11, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
I can't get my dishwasher to start
try pressing normal wash, then heat dry normal wash then heat dry normal wash then heat dry. do it 3 times
Jan 27, 2007 | Maytag MDB9600A Jetclean II Built-in...
Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher Logo
135 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
