Question about Sherwood Audio Players & Recorders
I get sound through headphones but not through speakers. I do not have a remote. Do I need one to switch to speaker output. Sherwood RV6010R.
    Brigadier General:
  • 8,546 Answers
You don't say if this new or old equipment, new or old problem.
Usually you just unplug the headphones to enable the speakers.
The speaker switches are plainly visible...
http://www.eassetsolutions.com/GREEN/2011-01-12_0115.jpg
You need those jumpers or something active to replace them...
http://www.eassetsolutions.com/GREEN/2011-01-12_0122.jpg
Posted on Mar 13, 2011
Sherwood CDC-5506 5-Disc CD Player - does it need Amp ?
Yes you need and amp Look at the disc player there is no volume control or speaker outputs.
Nov 21, 2013 | Audio Players & Recorders
Denon receiver problems
Check sound from headphones. These models have been known to have bad headphone jacks that make the unit think there are headphones plugged in even when there isn't. Sometimes just plugging in headphones and unplugging them will fix it for a while.
Apr 26, 2013 | Denon AVR-689 7.1 Channel Home Theater AV...
No sound from tv when connected to sherwood 7505
try pressing the aux button on the front of the reciever while the reciever is linked up to the tv ,if that dont work connect a red and black banana plugs into your aux on the back of the reciever and on the other end of the lead must be a head phone pin check size of headphone socket. to plug in to your tv head phone volune then u can control the recievers volume through the tv using the remote.go to menu then tv set up then scroll to the sound note icon press enter scroll down click on head phone and turn it up then you should have sound through the speakers from the tv.
Jan 27, 2013 | Sherwood Rd-7505 Home Theater Receivers
I would like to connect my powered subwoofer (Atlantic Technology model 212 SB) to my Sherwood RX5502 receiver. Unfortunately, the receiver has no subwoofer outputs, only speaker outputs, and the...
Cables between sources and compatible units rarely need to be physically modified.
Register and download the manuals for free at retrevo.com
http://www.retrevo.com/support/Sherwood-RX-5502-Receivers-manual/id/3124dj384/t/2/
http://www.retrevo.com/support/Atlantic-Technology-212-SB-Subwoofers-manual/id/866dj197/t/2/
Splicing headphone outputs designed for nominal 8-ohm impedance speakers to a 47K-ohm (typical) RCA load is not a good idea but it might work on the Sherwood because this receiver does not automatically silence your other speakers when the headphone jack is installed.
There is NO other volume-controlled output to choose. Try it.
Mar 25, 2011 | Sherwood RX-5502 Receiver
Sherwood RX-4109 receiver has no sound. Right speaker had no sound, and I tried to see if switching speaker connections in back receiver would help, but now neither speaker works, and there is not...
Maybe a shorted right speaker took out the other channel. Does it turn on now?
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
You can test the speaker for open or short by touching a small battery to the speaker wires. It should make static or click sounds. If not, it's dead. If it sparks and akes no sound it's shorted and dangerous to any amp.
Mar 24, 2011 | Sherwood RX-4109
No sound
Hello
First you check the speaker of your Daewoo Tv. To check the whether the speaker is good or damaged, place your year very close to the speaker side of your TV, and switch the TV by its front panel power switch, not by the remote control. If you can hear a "Thumb" sound from the speaker, as the TV is switched on, the speaker is good and you have to to further. If not speaker has got damaged and have to be replaced.
If your TV is provided with an earphone or headphone socket at its fron panel, insert a earphone or headphone pin into it and listen whether there is sound coming from it or not. If ther comes the sound, it doesnot comes to the speaker, means that the headphone or earphone socket is faulty. Replacing it will solve the problem.
If there is AV OUT from your TV, connect it to an amplifier or so to get the sound. If there is sound and no output from speaker, means the Audio Output IC inside your TV is faulty.
Just locate the audio output Ic, and replace it with same type and number. Audio Output IC can be easly located ans speaker wire goes to that section, and follow the speaker wire. locate it. If you need any more assistance, feel free to contact me through Fixya. OK.
Dec 07, 2010 | Daewoo DTQ-20U9SC TV
No sound
Hello
If picture is OK and there is no sound output from your tv, means either its speaker or the Sound output Ic is not working. The case of speaker fault can be easly detected without opening the TV. You just place your ear very near to the speaker side and switch on the TV by AC mains [not with remote control]. You may hear a "thumb" SOUND OR A "HUM" sound from it. If any one is there the internal speaker is working fine. The fault lies in audio output Ic stage. If there is no sound said above, speaker can be suspected. Befor confirming that the speaker is faulty, if your TV has an earphone or headphone jack in front, insert the earphone or headphone socket into it, and check whether there is any sound heard from it. If there is sound from headphone, means that the headphone socket is faulty, it does not bypass the sound to the speaker. When head phone is connected, the connection to the speaker will automatically cut of. When it is pulled out from the socket, the speaker connection will resume. If the changeover switch inside the earphone socket also show this kind of trouble. If the speaker inside is found faulty, unscrew it out of place after opening the TV, go for a same type and number, impedence and shape.
If there comes the above said "HUM" sound from the speaker, surely the Sound Output Ic is faulty. Replacing it will solve the probelm. Before replacing it, check it soldering points for any loose contact. It is best to resolder all suspected point is sound section before replacing the ic.
Note: In modern TVs there will be any trace of sound, without a video signal. Without video, sound is muted. ok.
Nov 07, 2010 | Toshiba CF19H25 TV
The picture is fine but the sound is not working. I push the volume and you can see where the volume level is going up. Have tried turning it off and unplugging it to try to reset it but nothing has...
Hello
Picture being Ok, and no sound output, means there is some problem inside the sound output circuit of your TV. It may be due to a speaker fault or an IC fault. You have to find out which of these has fault.
You just place your ear very close to the speaker side, and switch on your TV with its AC mains On-Off switch, not by remote control handset. Listen carefully, whether there is any sound output of any form comes out of it or not. If there is no sound at all you can determine that the speaker may be out, not in all cases. If you have the habit of listening your TVs audio by using a headphone, continious in-out action could damage your TVs headphone socket. If the headphone sockets' contact got damaged, no sound output will come from it to the speakers. Suppose you can hear the sound through your headphones but not throuhg speaker, means that its change over contact has some trouble. You just do this first. Insert a headphone pin into your TVs headphone socket, if provided, al listen to it for sound. If there is no sound from headphone also, Sound output Ic iside your TV has damaged, or not getting proper voltage to it. If there is sound through the headphone, and not from TVs speaker, trouble is related either speaker or the above said socket.
If all the above has no effect, that is no sound either from headphone, of from the speaker, you should go into the circuit board of your tv to get the fault.
Open your TVs back cover, and trace for the sound output section. There will be an Ic used as sound output. Check whether it getting heated some time after switch on the TV. If it overheats without any sound output, it is damaged Desolder it out from the circuit board, go for a same type and number, replacing it will solve the problem. If it doesn't overheat, or no heat at all, check its input voltage. In some cases, loose soldering points on the legs of Ic may also the cause. Check it too. Ok.
If you need any more clarification, ask me through Fixya. Give
a brief explanation about what you have done so far also.
Nov 04, 2010 | Symphonic ST419E TV
I am trying to use Centry wireless headphones, I can get sound in the headphones, but sound is still coming out of the TV
With this TV, you can turn the TV speakers off with the remote. This will not turn off the headphone output port.
Press menu, go to AUDIO, then go to TV speakers. You have the option to turn the speaker OFF there.
The speakers should have turn OFF automatically when you plug the headset into the headphone port. But, going over the manual for this TV; the option is to turn the speakers off manually with the remote.
Jun 03, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
385 people viewed this question
Top Sherwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
