I cant connect the wire in my power supply - Computers & Internet
    Problem Solver:
  • 9 Answers
There are two types of power supply connectors, there are 20 pin and 24 pin. are you short pins or do you extra?
Posted on Mar 13, 2011
Compaq computer power supply model HP-U250XC3 how to turn it on
what PC? none stated, just PSU.
what are you doing with that PSU
bench testing, it or what>>>??? we cant guess USAGE ever.
to bench test it use a jumper wire.
the 24 pin cable ATX2, jump pin 15 to 16, PS_on to ground.
that turns it on, so you can use a voltmeter to check each power rail pin.
http://www.pcdied.com/power.html
in inside PC, it must be connect to the MOBO
and then the MOBO power switch connected or it cant be turned on.
May 23, 2017 | Compaq Computers & Internet
Cant turn it on hp mini
First check-up your power supply parts. if it is blower fan working, if not.
Try disconnect your power supply unit also all wire connected into motherboard disconnect.
And then check-up your power power alone. just short color Gray and Green. see your blower fan for
Working. if it is not your power supply defective need to replacement same watts and specification.
Just let me known if not yet working your PC.
Thanks for using Fixya
Aug 21, 2011 | Computers & Internet
In have a spst 12v lighted toggle switch that i use in my hobby i cant keep it lighted i use it to shut off the power to sideing tracks on my ho model train. new to wireing it hase 3 blades pos acc neg ....
Hi Gi Joe. I am assuming that you are wiring this on the DC side of the train power supply. So, the negative from the power supply goes to one of the rail connections. From this run a wire to the negative of the switch. The positive of the power supply runs to the positive of the switch. The ACC of the switch runs to the positive connection of the rail. The switch breaks and makes the positive connection to the rail. The power supply is 12 volts I also assume. The light should now go on when the switch is set to ON and suppling power to the rails. The negative of the power supply provides a return so that the light goes on and the train can run.
Please leave a comment if this helps.
Joe
Jan 26, 2011 | RTO Spst Toggle Switch
My power windows do not work. The Haynes Repair Manual mentions that it could be that a circuit breaker was tripped and might need to be resetted manually. Where and how do I manually reset the circuit...
i have diagram for accord 1993, i cant see the breaker you mentioned, if your relay is ok, its mean that fuse #15 have power 12V and when the ignition is on, the relay have supply 12V to fuse #33, if all this ok, the problm is on your power window main switch, connect a wire supply by 12V to white/yellow wire at power window main switch or test this wire if already have 12V when ignition is on
Jun 26, 2010 | 1993 Honda Accord
How to connect power supply to intel desktop board of d845wn
hmm strange question but you cant really get it wrong you plug the 20 pin conector from the power supply into the board then plug the little 4pin block which is on a diffrent cable into the little 4 pin block on the motherboard there all shaped to fit the conections so you cant get them wrong
Sep 24, 2009 | Intel Desktop Board D845WN Motherboard
Dell NPS-210AB power supply starts up then shuts off
hello bob, try putting a phanton loa on the other bars of the power supply, it seems tha the power supply is not starting, some switchin power supply require an apropiate load to start.
Jun 29, 2009 | Dell Power Supply 330 Watts nps-330cb...
Test power supply
you can say powersupply is woking or not by changaing other new samps/power supply ,its wire is connect on bord/HD /o d/ .if it cant flow regular and require amount of ac/dc electry. then it creat many problem as hangs.shutting down computer in one peirode .no sign of HDD/optical drive in computer and no power in computer
Jun 13, 2009 | Dell Dimension 4600 PC Desktop
When i turn my car on my cd player is full blast i cant find where to fix it
I want to know if you still can volume it down. If don't then your volume button sw for down was damaged.If still can, your cd player's memory is not functioning. Check the wiring of batt. memory back-up wire from the player, this must be connected to unswitch power supply. ( the power supply is always "ON")
May 10, 2009 | Car Audio & Video
My laptop is a toshiba satellite P25-S526. I cant seem to get the power supply to charge the battery. I have replaced both the battery and power supply and those were not the problem. why wont my...
If you have a volt meter measure the power coming out of the power supply and make sure the outlet is good that you are plugging it into.
Try resoldering the connection on the circuit board where the power supply plugs into it. There may be a loose connection or a crack in the board that you could jumper around using a short piece of wire soldered around the break.
Aug 26, 2008 | Toshiba Computers & Internet
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
