Question about Canon Pixma MP500 All-In-One InkJet Printer
My cat knocked the paper feeding trays out of my printer. There are three plastic pieces, two short, one long piece that fit at the top back of the printer. do you have a drawing show how they go back together and fit back into the printer, It is a PIXMA mp500. Thank you
  • 1,940 Answers
Here is a front and back diagram of the Canon Pixma MP500:
http://www.4shared.com/document/xkdPHEzG/Canon_Pixma_MP500_Diagram.html
The diagram is in PDF format, and can be Zoomed In and Out.
Posted on Mar 13, 2011
(hp 4000 printer) A piece of paper is stuck between tray 2 and under just before the toner cartridge. I can lift the flap on top of the paper after removing the toner cartridge, but cannot dislodge the...
Probably the way to go is to remove the toner and tray 2.
lay down a bunch of newspapers on the floor (not a rug). The printer is unplugged at this point.
Turn the printer over and lay it down. Take a sheet of paper and fold it lengthwise in quarters.
Manually feed the folded paper into the paper path from the bottom. Push and pull the paper thru
the paper path. The object is to push the small piece out where you can reach it.
It's not the easiest thing to explain. You always want to go in the direction that the paper moves thru the printer. This is why you start feeding from the bottom.
You know that there is a piece of plastic that is above the feed roller for tray 1 that you can pull out to give you more room.
Feb 18, 2011 | HP LaserJet 4000tn Printer
I HAVE A SPRING THAT CAME OUT OF THE TOP. WHERE DOES IT GO?
The spring you are referring to is probably from the paper pickup assembly at the manual feed tray. You can pry it up and remove it and then place the spring back under it and re insert the piece. (It will look like a grey strip of rubber on top of a black piece of plastic and can be seen when you open the fron manual feed door)
Feb 07, 2011 | HP LaserJet 6p Printer
Sharp AL-1631 bottom paper feed will not pick up paper.
A few things could be the problem.
  1. The paper in tray could be damaged
  2. The drawer separator pawls (metal taps on the right side of tray where paper touches)
  3. Paper backstop not in or in wrong spot (green plastic piece at back of paper)
  4. Feed tires are worn or dirty
Does the copier try and feed from tray 2? If it tries but the paper doesn't leave the try look and see if there is a dark mark on the page (top middle towards the right). If so then most likely the feed tire is worn.
Oct 12, 2009 | Sharp AL 1631 Copier
Print fragmented documnts
Step1
If you're setting up the printer or changing the toner or ink cartridge for the first time, double-check the instructions to make sure that you installed the cartridge correctly and, for new printers, that you have removed all the pieces of cardboard or plastic packing material.
Step
Check to see whether paper is feeding from the paper tray. If it's not leaving the tray at all, try feeding a page manually (if that's an option) or using a different paper tray. Sometimes a problem with the tray can be traced to a broken spring or a piece of plastic.
Step
If paper is feeding from the tray but jamming in the printer, examine where the jam is occurring and then inspect the printer carefully to see if you can find what is causing the problem. A piece of paper, for instance, might be blocking the paper path.
Step
If paper is feeding through the printer but coming out blank, check to see whether the printer is out of toner or ink. A defective toner or ink cartridge could be the problem.
Aug 14, 2008 | OKI MICROLINE ML-395 Matrix Printer
Printer stuck on Perfoming Self Test
Step1
Step
Step
Step
Jun 02, 2008 | IBM Infoprint 1120 Laser Printer
Light blinking
Step1
Step
Step
Step
Jun 02, 2008 | Epson FX 1170 Matrix Printer
Print out very light
Step1
Step
Step
Step
Apr 17, 2008 | HP LaserJet P3005dn Printer
Printer powers up, then down
Step1
Step
Step
Step
Dec 28, 2007 | Tally Line Matrix T6090 Printer
Paper feed
Feed roller is dirty or worn thin, wipe rubber roller with damp cloth.
Nov 03, 2007 | Kodak EASYSHARE Printer Dock Thermal Photo
HP PSC 2210 All-In-One InkJet Printer Start Up Problem
Step1
Step
Step
Step
Oct 22, 2007 | HP PSC 2210 All-In-One InkJet Printer
Canon Pixma MP500 All-In-One InkJet Printer Logo
24 people viewed this question
old marine
old marine
