Question about Yamaha CDX-390 CD Player
In play it stutters and skips in the first 2 tracks
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 92 Answers
Get a cd cleaner an clean it a few times
Posted on Mar 16, 2011
ALL DISKS SKIP ON MY SONY CDP - CX53...SOLUTION?
If you have access to the lased head, gently wipe the lens with a stick with cotton moistened with isopropyl alcohol, or regular sanitary alcohol. Use circular movement. Then, gently shine the lens with dry cotton. DO NOT PRESS THE LENS !!!! If the issue persists, it's more complicated. You need to have access to the tiny trimmer below or near the laser head. Using a plastic screwdriver, rotate the trimmer clockwise about 2-3 degrees. Test playing. If track doesn't skip, hit the CD player's case with the finger, to check if track skips because of shock. If skips, rotate trimmer again 1-2 degr. Check again. If it doesn't work, try rotating counterclockwise. You need patience. Hope it is useful.
Mar 11, 2015 | Sony Audio Players & Recorders
The CD will not advance to the next track. One track is played and then it stops and waits until I program it to play the next track.
try when u turn it on. check all your bottons 2 make sure they r not stuck and than put a cd n and check 2 c if it will read the hole disc. or push play with a cd in there an try 2 skip songs 2 play
May 10, 2011 | Audio Players & Recorders
Alpine CDM 7874 won't play rest of CD after track 1.
It could be a bad burn or an issue with the receiver. Try re-burning the CD and see if that helps.
Jan 14, 2010 | Alpine CDM-7874 CD Player
Cd player showing error 43
Still under warranty?... check that.
Mar 24, 2009 | 2008 Hyundai Elantra
Cd's always skip
You have done well for 10 years laser changes are in order
When a cd skips it is due to laser diode becoming weak over time not producing an original beam causing focus prolbems ,hence skipping discs
Dec 29, 2008 | Sony CDP-CX220 200-Disc CD Changer
Player 2 skips and plays a different track
May need manual cleaning or Cd Mechanical assembly may need to be replaced
Dec 03, 2008 | Nu Mark Numark Cdn36 Dual CD Player CD...
My SA6025 damaging mp3 files!
Make a note of skipping tracks & check these tracks play ok on the PC - this will rule out corrupted tracks.
Skipping of entire tracks can be due to DRM copy protected tracks (purchased on-line). Some players will not play DRM tracks.
You can check for protected tracks.
  • In Windows Explorer, go to the folder where the tracks are stored on your PC.
  • Click on View -----> Details
  • Right click on the header bar in the right hand window and select protected. (If protected is not listed click on More)
  • Tracks will be listed with No or Yes under protected. Check your skipping tracks are listed as No, under protected.
If none of this helps, install and run the Philips Device Manager. Select the repair / restore option and follow the on-screen prompts. This will format the player, ruling out a corrupt file system on the player, and re-load the firmware.
Mar 02, 2008 | Philips SA6025 Digital Media Player
My rio ce2100 keeps stuttering or skipping
I would recommend wiping your player - (if this doesn't work then it is probably the tracks/audio you are playing and not the player):
Windows only.... Please post if you are not using windows...
Open My Computer with your Rio plugged in.
Right click on your Rio carbon and click on format.
Leave the default values - if it asks you something then use your initiative.
Then click on format.
Then when it has finished formatting go to your firmware (can be downloaded from: http://www.digitalnetworksna.com/support/rio/product.asp?prodID=235).
Follow the instructions and then it should load the firmware onto your player.
When it has done then your player should (in theory!) work properly.
Hope this helps
Mowcius
Dec 08, 2006 | Rio CE2100 MP3 Player
Yamaha CDX-390 CD Player Logo
78 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
