Question about GIMP GNU Image Manipulation Program
Trying to make some decals with text on it but need the back ground trasparent then save as tga or dds file cany any one help
  • 115 Answers
You can accomplish this by creating a new layer and making it transparent and putting it at the bottom, then using another transparent layer above that one make your text and decals or import them.
Posted on Mar 13, 2011
Right side windows does not work from drivers door or pass.and rear door 2007 Silverado new body
What's with the 1994 C/K 2500 above an 2007 Silverado ? 07 on 94 frame ? New body have all the 07 electronics ?
Power Window System Controls (RPO A31/AN3/DL3)
The power window system will operate anytime the Retained Accessory Power (RAP) system is active or when the ignition switch is in the ACCY or ON position.
The driver master control switches are integrated into the DDS. When a power window switch is activated in the up or down positions the DDS supplies power and ground to the window motor control circuits to drive the window motor in the required direction. Prior to activating a power window motor the DDS will supply the control circuit with a low current bias voltage in order to determine that a short to ground condition does not exist and during window motor operation the DDS continues to monitor the motor current to verify proper window motor operation.
The DDS controls the passenger window through a GMLAN message to the PDS. When a power window switch is activated in the up or down positions the PDS supplies power and ground to the window motor control circuits to drive the window motor in the required direction. Prior to activating a power window motor the PDS will supply the control circuit with a low current bias voltage in order to determine that a short to ground condition does not exist, and during window motor operation the PDS continues to monitor the motor current to verify proper window motor operation. (Scan tool support is available for this system)
Do you know what GMLAN is ? serial data communication network
How to Diagnose Controller Area Network CAN GMLAN is general motors C.A.N
Passenger Power Window Inoperative
  1. Ignition OFF, disconnect the C1 harness connector at the PDS.
  2. Test for less than 1 ohm between the ground circuit terminal 6 and ground.
  3. ?‡'
    If greater than the specified range, test the ground circuit for an open/high resistance.
  4. Ignition ON, verify that a test lamp illuminates between the B+ circuit terminal 2 and ground.
  5. ?‡'
    If the test lamp does not illuminate, test the B+ circuit for a short to ground or an open/high resistance.
  6. Ignition OFF, reconnect the harness connector at the PDS.
  7. Ignition ON, observe the scan tool Passenger Window Switch parameters while using the passenger power window switch. The reading should change between Off/Up/Down/Express Down.
  8. ?‡'
    If the parameter does not change, replace the PDS.
  9. Ignition OFF, disconnect the harness connector at the passenger window motor.
  10. Connect a test lamp between control circuit terminal A and control circuit terminal B.
  11. Ignition ON, command the passenger window UP and DOWN by using the passenger window switch. The test lamp should illuminate when commanding the UP and DOWN states.
  12. ?‡'
    If the test lamp is always OFF during either of the commands, test for a short to ground or open/high resistance on either control circuit. If the circuits test normal, replace the PDS.
    If the test lamp is always ON, test for a short to voltage on either control circuit. If the circuits test normal, replace the DDS.
  13. If all circuits test normal, test or replace the passenger window motor.
Sep 08, 2016 | 1994 Chevrolet C/K 2500
Power windows dont work
There is a circuit breaker for power windows .
Power Window System Components
The power window system consists of the following components:
Driver Door Switch (DDS)
Passenger Door Switch (PDS)
Body Control Module (BCM)
Rear door power window switches
Power window motors in each of the doors
PWR WDO Circuit Breaker
The DDS controls the passenger window by a serial message to the PDS. When a power window switch is activated in the up or down positions the PDS supplies power and ground to the window motor control circuits to drive the window motor in the required direction. Prior to activating a power window motor the PDS will supply the control circuit with a low current bias voltage in order to determine that a short to ground condition does not exist, and during window motor operation the PDS continues to monitor the motor current to verify proper window motor operation. (Scan tool support is available for this system
Check this circuit breaker
RETAINED ACCSRY PRW BRKR 30 amp. located in the left instrument panel fuse box . if the breaker is good check power B+ at the drivers door switch . connector 1 terminal b yellow wire . Sometimes the wires inside the rubber boot coming from body to door break .
Oct 29, 2015 | 2005 Chevrolet Impala
I cant recover my deleted text messages
Try GT Recovery for Windows,which can recover deleted messages without root your phone! Can you recover deleted text messages on Android? Yeah, this video will show you the full guide for Android text message recovery. Don't hesitate and restore deleted text messages from Android 4.0, 4.1, 4.2, 4.4, 5.0, 5.1 and more versions right now!
Not only can you recover SMS messages from Android backup but also can recover Android SMS messages without backup. This video is showing you how to recover deleted sms messages on Android without root your phone.
Some common situations that lost text messages you can recover from:
1. accidentally deleted texts on your android phone
2. lost text messages after Android 5.0 updated or other Android upgrade.
3. save text messages from water damaged, crashed, broken or smashed Android phone
4. Android deleted text messages randomly by itself
5. Factory restore Android phone.
And more...
Watch this video and share it with your friends too so that they can also get their precious lost data back.
Twitter:https://twitter.com/GtRecoveryapp
Download Link : http://www.gtrecovery.net/
Aug 08, 2015 | Cell Phones
OpenPIMipmapChain:unable to locate a valid DDS , JPG or TGA file for Solid colors
if this is a problem when you try to load the game i would suggest saving any local game content (eg. important save files, if you have any) and then reinstalling, most programs these days also have a repair function, this can be accesses through control panel > programs > uninstall a program, if the option is available it will become apparent after you click the program in the list. sorry if i wasnt able to assist your properly
May 27, 2011 | Take 2 Interactive Shattered Union for...
I have deleted my texts that really important that i need for a court case.
For someone who has little knowledge on computer like me, I usually prefer to getting help with some pro programs, such as this data recovery program.
or u can visit http://www.asoftech.com/recover/ where I find many guides in detail there.
Hope it can help u. Good luck.
May 12, 2011 | Computers & Internet
My Dell Inspiron freezes up when I open up an application. What could be the problem?
Most likely overheating. The Cpu is running fine with no load, but when asked to load a program, it starts working harder and gets hot. It sounds like a good heat exchanger and fan cleaning is in order.
If this information was helpful, please rate it high. thanks.
May 07, 2011 | Dell Inspiron 1525 Notebook
Can i upgrade my e machine etower 500is desktop to connect with my dsl system
as long as you have a place to put an ethernet card I would say yes.
You an get them most anywhere...even Walmart.
Good luck
Oct 16, 2010 | E-Machines etower 500is PC Desktop
Converting wma files to wav files on olympus DDS player version 7
When using the DSS Player v7 software the program is unable to convert WMA to WAV. The option you see there only works when it is a .dss file that needs to be converted to .wav. In order to convert WMA to WAV you will need to locate a third party software program that does this type of conversion.
Go to google and search on WMA to WAV conversion editors.
Oct 07, 2008 | Olympus DS-30 Digital Voice Recorder
Back up current settings
Try right-clicking on the link and choose save-as
Then you can save that "text" to a file. That will backup the config...
G'luck
Aug 15, 2008 | Belkin (F5D7230-4) Router (587009)
Open Questions:
See all GIMP GNU Image Manipulation Program Questions
GIMP GNU Image Manipulation Program Logo
55 people viewed this question
Top GIMP Computers & Internet Experts
Rick Moore
Rick Moore
Michael Vincent Cruz
Are you a GIMP Computer and Internet Expert? Answer questions, earn points and help others
