Question about Teac W-865R Single Cassette Deck
RUBBER DRIVE BELT FOR A360 FOR TEAC CASSETTE DECK
  • Teac Master
  • 5,126 Answers
Drive belts on tape decks are mostly universal. You only need to measure the diameter of each belt in mm and then enter the result in Google as "Cassette drive belt ??mm".
Posted on Apr 22, 2011
How do I get fast forward & rewinds to work on my Teac W450-R dual cassette deck..?
Check the belts, inside the unit you should see a rubber belt which is what pulls the tape fast forward or rewind. Some belts with time get loose and slip, they can also break and fall off which will not let you fast forward or rewind.
Open your cassette player and look where the plastic pulleys are located and check for the belts, they might not be broken at all but very loose and slip on the plastic pulley.
Jun 07, 2015 | Teac Audio Players & Recorders
MY CASSETTE DECK BROKE THE RUBBER BELT CAN THIS BE REAIRED
Yes, a new belt can be installed. That might not be the only problem. The belt may have broken because there is an issue with that transport.
Mar 05, 2015 | Teac W-600R Single Cassette Deck
How to replace the belt on a Teac W-750r cassette deck
In all the years I have been in tape decks repair I have never seen one. You either have to work with an experienced Technician or do it yourself using common sense. Going to college gives you a degree and knowledge of parts it dos not tell you how to fix anything. That may be why I work on some Nasa Engineers tape decks.
Jan 06, 2014 | Teac DUAL CASSETTE A/R 110/220 Single Dual...
Getting belts for TEAC W-890R. I'm currently sitting here a home with a DEAD TEAC A-350 Cassette Deck -- DEAD because I was told you can get belts for it (I have since found out that is is NOT true and...
That is the state of conditions at Teac and they don't care about tape customer anymore. If you need belts for any unit it is simple to find the belt kit at Marrs Communications. They do not have he cheapest prices bu the you don't know what size you need and Fred took time to find his out. If you want to do it the other way you download a copy of the PRB cross reference manual and look up the belt type that goes into your deck. The you go to Ken's Electronics and order the belts online. This does not come with instruction of how to put them in. In my many years as a Technician working on all kinds of tape decks I have never seen an instruction to put belts in a machine- it is assumed that if you can not figure this out that you probably do not belong in the machine. In cases where belts are not in place sometimes the parts layout diagram can help you determine how they go in.
I am an ex Teac Lead Technician from Chicago.
Aug 25, 2013 | Teac W-865R Single Cassette Deck
Repair manual for TEAC R-H500 Cassette Deck?
I think I got mine from owner-manuals.com for about $5.00
http://www.owner-manuals.com/index.php?main_page=index
Jun 08, 2013 | Teac R-H500 Dual Cassette Deck
Looking for rubber belts replacement for teac v8030s
Look on the Marrs Comunications web site and order the kit for the unit.
Apr 12, 2013 | Teac V-8030 Dual Cassette Deck
Thaks for helping. My tape deck door has suddenly stopped working. the tape is inside and when i turn on the wpower there is a clicking sound. it is a TEAC AD-500 CD player/reverse cassete deck
Without physically looking at the cassette deck myself, I cannot be 100% sure the tape is wrapped around the pinch roller and capstan. The capstan is the chrome rod which the rubber pinch roller pushes to regulate the speed of the tape moving across the head. However it is approximately a 90% chance the take up reel for the tape stopped working from a bad tape or a loose belt which drives the tape take up reel. The clicking sounds like it could be the auto reverse solenoid because it thinks the tape has reached the end of play. The fun part is to remove the tape which you may have to disassemble the front panel if you cannot gain access to the tape from the top or bottom. You will need to cut the tape and remove it from the capstan and pinch roller to open the cassette door. Sometimes you can remove the capstan to free the tape. Once you have cleaned all the tape out of the unit make sure the belt for the take-up is good. If it is glazed, cracked, loose or broken order a belt. Clean all the pulleys and capstan and replace the belt. Your unit should be functional after the above procedure.
Jul 14, 2011 | Teac R-H300 Dual Cassette Deck
My Nakamishi Cassette Deck 2 is eating tape. It switches off when it does, but how can I fix this? From the look of it this cassette deck has the same cassette drive as the DR-8. Is that correct?
It could be the take up spindle does not have enough torque causing the tape to bunch up after the capstan. If you open up the unit you will notice ether belts or rollers for the tape drive. If it has belts you can replace the belt after cleaning the pulleys. If it has rollers you may be able to clean them with a rubber cleaner (not alcohol which will dry the rubber and cause glazing). Make sure the capstan and the pinch roller is clean using a rubber revitalizing cleaner on the pinch roller. "Goof off" from a hardware store is great for the capstan if it has a lot of metal oxide on it.
Feb 24, 2011 | Nakamichi DR 8 Single Dual Cassette Deck
TEAC CX-370 Cassete Deck
Could be a worn out belt? The cassette loads it the drive down too much. Hence why it turns with no tape.
Jul 04, 2008 | Teac DUAL CASSETTE A/R 110/220 Single Dual...
Teac A-21 Stereo Cassette Tape Deck turns un, but won't play cassette tapes...
very likely that the drive belt has broken. I have fixed a TEAC myself using a large O-Ring from a hardware store (I know I was lucky to find a very close match). Open the unit and find the broken belt and take it to a hardware store to "size up" a replacement. Use the opportunity to oil the gear shafts and clean the rubber pinch roller.
Jun 22, 2007 | Teac DUAL CASSETTE A/R 110/220 Single Dual...
Teac W-865R Single Cassette Deck Logo
319 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
