Question about Stanley Piston Driver Assy Bostitch N60fn Finish Nailer
GUN DOES NOT FIRE FOR SEVERAL ATTEMPTS--even though gun is pressed firm against work---just had unit serviced and trigger valve replaced-----any suggestions? thanks joel
    President:
  • Stanley Master
  • 1,388 Answers
Remove nails and remove trigger to expose trigger valve pin. Place nose of gun against rubber pad or old coiled up air hose to absorb impact of driver and with very quick and deliberate motion press in trigger pin. If gun fires, then problem is with safety foot not pushing trigger pin all the way in (or worn trigger). Make adjustment as needed or replace faulty parts. If gun still does not fire, then likely problem is with headvalve. If headvalve orings are leaking, gun will not fire. Test for leaking orings as follows. Remove head and remove headvalve, apply silicone paste lube (plenty) to all orings and where orings contact. Assemble and do test above. If gun fires then surface where orings contact is allowing air to leak(smooth with very fine sandpaper if scratched).
Posted on Mar 14, 2011
Keeps repeating itself
Most nailers have a two position setting on the trigger to allow for single fire or bump fire. If set on bump fire, the gun will work better when you bump fire the gun instead of placing the gun on the work then depress trigger. Bump fire works best when safety spring has good tension. Easy test. Make sure that the safety spring is in place (with air hose removed, contact foot should spring back quickly when pushed against work). With air connected, hold trigger and quickly bounce the gun against the work. If the gun does not fire when you bump, the trigger is most likely set to single fire. With trigger set to single fire, you must place the gun against the work, then depress trigger. If the gun shoots two nails while set to single fire, most likely worn trigger or worn out trigger valve. These parts are not expensive and are easy to replace. Good luck
Apr 12, 2013 | Dewalt D51321 3/4" 1 3/4" Heavy Duty Coil...
My new porter cable RN175B nail gun won't discharge a nail
If the trigger is set to single fire, you will need to place the gun against the work then pull trigger as you have done. Try setting the trigger to bump fire and try again. If hear a thump inside the gun, remove the head and check that the head valve in not stuck from lack of lubrication. Easy test, remove the nails, remove trigger pin, remove trigger and manually push trigger firing valve. If the gun fires then suspect faulty trigger or safety arm not lifting enought to activate the trigger valve. Good luck
Nov 21, 2012 | Air Tools & Compressors
Pull the trigger, no nail, only continuos air until I release tyhe trigger. not jammed, gun is clean, very new. acted that way right out of the box then it worked and then not and so on, worked...
Safety foot and lever inside of trigger are not pushing the trigger pin all the way in. To verifty that the gun will fire, remove the nails to allow for dry fire. Remove the trigger to reveal the trigger valve. Hold the gun against old coiled rubber hose or soft wood. Very quickly depress the trigger pin all the way in. If the gun fires, adjust safety foot and trigger so that the trigger pin is fully depressed when your bump fire. If the gun will not fire after adjustment, remove the head and lube headvalve/orings with silicone paste lube.
Sep 03, 2011 | Stanley Bostitch Mcn150 Strapshot Metal...
Gun will not shoot nails completely;no matter what wood,thickness,etc.they drive all but 1/2"
May be due to broken tip. Easy to check. Remove nails and leave door open. With door open, lightly tap the nose of the gun against coiled rubber hose or soft wood. The driver should stay at top position. If driver falls to bottom of the cylinder, replace piston oring. Now press nose of the gun against old coiled up air hose or soft wood and squeeze and hold trigger. The gun will fire and the driver should stay in the down position untill you release the trigger (if not single fire trigger, if single fire trigger remove trigger and press the trigger pin with finger). While the driver is down, make sure that the tip extends past the nose about 1/4 inch (if air leaks past the nose in this position, replace lower bumper). If the driver does not extend past the nose, replace driver. Good luck
Jun 24, 2011 | Stanley Bostitch N75c1 Coil Sheathing...
Hi there, bostitch framing gun f33 pt leaks air around trigger when i try to shoot nails.only when i use the trigger air escapes,otherwise it is sealed .just want to make sure what is your advice , before...
There are about three issues with this gun that could cause your problem. The safety contact arm not depressing the trigger pin fully, worn trigger valve (tva6), or leaking orings in the headvalve. Easy tests. Remove the nails, and remove the trigger to expose the tva6 valve. Reconnect air and with very quick and firm action, depress trigger pin all the way in. If the gun fires, adjust safety foot and trigger so that the trigger pin is depressed all the way in each time that you fire the gun. If the gun does not fire, remove the head and remove the headvalve. Examine the surface/s where Orings make contact with magnify glass looking for fine scratches. Sand with 400 grit paper. Orings must make good contact here or gun will not fire. Lube orings and surface with silicone paste lube (sold at Lowes in the plumbing department or swimming pool supply store). If no fine scratches and surface looks smooth, replace Orings in head and the tva6 valve. Good luck with your repair/
May 29, 2011 | Stanley Bostitch F33PT 33Degree Paper Tape...
Bostitch RN46 will not fire nail, only releases air when trigger is held and firing tip is touched to surface of material. Any ideas on what is wrong?
Gun will not fire if air is leaking past orings in head /headvalve or safety /trigger is not pushing trigger pin all the way into trigger valve. Test: Remove trigger to expose trigger valve pin. Remove nails. Place nose of gun against thick rubber mat or coiled rubber hose to absorb blow of driver. Very quickly and deliberately press trigger pin all the way in. If gun fires, safety foo or trigger is not pushing trigger pin all the way in. Make adjustments or replace worn parts. If gun still does not fire, remove head and pull out headvalve. Apply lots of silicone paste lube on the orings and the surface of the head where orings make contact. Reinstall head and test as above. If the gun fires then orings were leaking. Replace orings and sand any scratches on body of cap with very fine sand paper. Parts are at www.toolpartsdirect.com Good luck
Mar 06, 2011 | Stanley Factory Reconditioned Bostitch...
Nail gun shoots 2-3 nails, not one. last week 2 of them hit me in the thumb. has been doing this for years. I have put up with it because I did not know what to do about it.
Most nailers work better by bump firing the gun. Less likely to double fire. This is a common problem amoung brands. If you place nailer on work then trigger, you may/will have problems as you describe. There is usually an option of triggers or builtin method of single firing the gun. With single fire trigger, you can place gun on work and fire. The will not reset for next round untill you let go of trigger and lift gun off the work. If your gun is double firing even with bump method, then replace the trigger valve.
Nov 16, 2010 | Nailers 3 12" Pneumatic Air Round Head...
Replaced the trigger valve and i cannot get the the trigger to activate the piston
Thy this simple test. Remove nails and remove the trigger exposing the trigger valve. Connect air to gun and place the nose of gun against hard rubber or wood and push in the trigger valve pin all the way very quickly with finger. If the gun fires then the safety and trigger mech. are not pushing the trigger valve pin all the way in. Look for other worn parts or adjust safety to allow for more travel into trigger pin. If the gun will not fire then problem most likely in headvalve orings. Look for fine scratches on surface where orings contact. Remove fine scratches with 400 grit paper, lube with silicone paste and re-test. Good Luck!
Oct 17, 2009 | Stanley Bostitch Coil Framing Nailer
Air escapeing through triger assembly
The problem that you are describing usually occurs when fine scratches in the head allow air pressure to bypass the orings. Here are a couple of simple tests. Remove the trigger from the gun to give access to the trigger valve plunger. Remove the nails from the gun. While pointing the gun away from you, connect the air supply. There should be no air leaks. Now quickly depress the trigger pin all the way in. This must be done with a very rapidly movement. If the gun fires, then the safety foot is not pushing the trigger pin all the way in. Check for worn trigger or safety mech. When the safety foot is depressed against the work, the trigger pin should be depressed all the way into the trigger valve for the gun to fire. Hold the trigger closed tightly and very firmly depress the gun against the work, the gun should fire. If it does not fire try next test. Remove the head from the gun. Hold it in your hand and depress the headvalve all the way into the head with you thumb. While holding the headvalve in, place a finger over the small venthole on the mating surface of the head and release the headvalve. Vacuum should hold the headvalve in the head for a moment until you release the vent hole. If the headvalve springs back with finger over venthole you must remove the headvalve and inspect the surfaces with maginfing lens for fine scratches. Remove scratches with very fine paper to obtain smooth polished surface. Lube surface with silicone lube (looks like vaseline, sold in small container at Lowes plumbing department used for lubing faucet orings ) re-assemble gun and make sure that you tighten headbolts firmly. You should be ready to work. Good Luck!
Jan 01, 2009 | Air Tools & Compressors
Stanley Piston Driver Assy Bostitch N60fn Finish Nailer Logo
412 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Mike
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
