Question about LG Refrigerators
My LG ref. control has something wrong! it is elctornc setting, with 5 levels! suddenly 5 levels will become on! but the cooling is very less, almost it is not cooling! Freezer is manually controlled, by a weal from 1 to 7. freezer is ok, the ref, only has a problem. thank you
  • LG Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 19, 2011
Temperature controller of the LG GLD 292 RPJL is off, what can I do?
MAY HAVE a bad cold control thermostat, however the setting should never both be set to high. 5 may be a bit to high they should be set at medium. otherwise I suspect u may have a bad control board issue not communicating with the cold control all can be checked with a multi meter
Mar 13, 2015 | LG Refrigerators
What does abated mean
(of something unpleasant or severe) become less intense or widespread. "the storm suddenly abated "synonyms,subside, die down/away/out, drop off/away, lessen, ease (off), let up, decrease, diminish, moderate, decline, fade, dwindle, slacken, recede, cool off, tail off, peter out, taper off, wane, ebb, relent, desist, weaken, become weaker, come to an end
Nov 30, 2013 | Microwave Ovens
My LG fridge freezer has a problem with temperature control. Essentially, it seems that the thermostat is not working. If I switch it off and on at the plug then the cooling kicks in until the fridge...
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
The cold control needs replacing. Thats the knob with the numbers that turn the Ref OFF and ON.
What I do is call my local Appliance Parts Store with my model no. They are extremely helpful .
Get freezer and ref thermometer. Ref is probably too cold.
Freezer should be 0 to 10 degrees. Ref 33 to 35
If you need more help, Go here:
http://www.applianceaid.com/procedures.html
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Sep 04, 2011 | LG LRB-P1031 Bottom Freezer Refrigerator
Lg air con not cooling
To get proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Checkindoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3degrees less than room temp.6.Check compressor is working with correctpressure.
Thanks. Helpful?
Jan 24, 2011 | LG Heating & Cooling
My screen has suddenly become too dark to see
Click start control panel,display,appearance color scheme you can change your colour scheme there also you can change other settings
settings you can make adjustments for more or less pixels or from the drop down list pick the appropriate level of color range
hope this helps
Jan 17, 2011 | Acer Computers & Internet
Error codes 000070-001 and 00020-081 for iRC3180i
E020 Drum/Developer-related error
XX=01:Y XX=02:M XX=03:C XX=04:K XX=00:Any color
XX10 In INIT control of the initial setting,
SGNL is less than 62. Clean the ATR sensor window, Check on attachment of the developing unit, Check on a break
in the ATR sensor, Replace the ATR sensor
XX11 In INIT control of the initial setting,
REF is less than 62. Check on a break in the ATR sensor, Replace the ATR sensor
XX12 In INIT control of the initial setting,
SGNL is 960 or more. Check on a break in the ATR sensor, Check on operation of the shutter, Replace the ATR sensor
XX13 In INIT control of the initial setting,
REF is 960 or more. Check on a break in the ATR sensor, Replace the ATR sensor
XX50 When density data is computed using
SGNL value and REF value in ATR
control, REF becomes 0 due to backup
data corruption.
in the ATR sensor, Replace the ATR sensor,
Replace the DC controller PCB
XX51 When density data is computed using
control, the sensitivity coefficient
becomes 0 due to backup data
corruption.
XX81 P-SENS-P is less than 255 when a base
(drum face) of patch detection is read
out.
Clean the patch image reading sensor window
XX90 A computation result of patch reading in
patch detection is less than 16. Check on attachment of the developing unit, Replace the patch image reading sensor, Replace
the developing unit
XX91 A computation result of patch reading in
patch detection is 1008 or more. Check on toner leak from toner buffer in the developing unit, Replace the patch image reading
sensor
XX92 A computation result of patch reading in
patch detection is less than 42 for Y/M/
C and less than 73 for Bk 3 times in
succession.
the developing unit
X93 A computation result of patch reading in
patch detection is 522 or more for Y/M/
C and 543 or more for Bk 3 times in
succession.
sensor
XXA0 In ATR control, SGNL is less than 62. Clean the ATR sensor window, Check on
XXA1 In ATR control, REF is less than 62. Check on a break in the ATR sensor, Replace the
ATR sensor
XXA2 In ATR control, SGNL is 960 or more. Check on a break in the ATR sensor, Check on
XXA3 In ATR control, REF is 960 or more. Check on a break in the ATR sensor, Replace the
ATR sensor
XXA8 In ATR control, the detected T/D ratio is
upper than its upper limit (13%) 10
times in succession.
developing unit, Replace the ATR sensor
XXA9 In ATR control, the detected T/D ratio is
lower than its lower limit (3%) 3 times
in succession.
and,
E070 ITB HP detection error
0001 HP of the ITB fails to be detected even
after the specific period of time.
Abnormality of the HP sensor,
Deviation of the belt from its position to
either edge, or soiling of the seal
Clean the HP detection seal, Clean/Replace the HP
sensor
...so, I pressume that something is broken, because you are getting these two error codes... call service, or write on emma.servis@gmail.com for service manual.
Hope that helps!
Aug 10, 2010 | Canon Office Equipment & Supplies
Canon3100 with code e000020-01a9 and -02a9 and -03a9, turned off. checked drum, fuser seems ok help
data corruption.
corruption.
out.
the developing unit
sensor
succession.
the developing unit
XX93 A computation result of patch reading in
succession.
sensor
ATR sensor
ATR sensor
in succession.
BUT FIRST: Check the ATR SENSOR, left from the developing rotor you have an "rail" with atr sensor - vacume it!!!!! Vacum all dev units, and copier
Apr 20, 2010 | Canon imageRUNNER C3200 Copier
The ref/freezer temp control goes from 1 to 5. Is one or 5 the coldest?
Yes, the highest number would be the highest level of cooling. Normally you would set the controls to mid-range and adjust from that point to your satisfaction.
Jun 29, 2008 | LG Refrigerators
JVC AV-27530 Sudden changes in brightness
This sudden changes in brightness are caused by the change in voltage inside the tv,not in the outlet in the wall but inside the set,The changes are an indication something is going wrong and it needs to be corrected,the set does have a brightness limiter but it only works when the set wants to get brighter than normal,You need the assitance of a servicer to correct this problem.
Oct 04, 2006 | JVC AV-27530 27" TV
Refrigerators Logo
78 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
