Don't know how to set jumpers for master and slave
    Problem Solver:
  • 14 Answers
These jumpers you're referring to normally are spoken of when dealing with a CD/DVD Drive or a hard drive. Usually it's an older one too. They look like this...
You'll need to look on the device itself. There it will have labeled which pin set is for slave or master. Just move the jumper to the correct pins.
Posted on Mar 13, 2011
    Problem Solver:
  • 15 Answers
This is hard drive specific. It is not possible to give an accurate response to this question without knowing the make and model of your hard drive.
Generally, the following should apply.
For WD: http://www.drivejumper.com/westerndigitaljumperchart.gif
For Seagate: http://www.drivejumper.com/seagatejumperchart.gif
For Hitachi: http://www.drivejumper.com/HitachiIBMjumperchart.gif
Samsung: http://www.samsung.com/global/system/business/hdd/faq/2007/6/28/48851120060316152454_20050427_JUMPER-EN.doc
  • 93 Answers
Follow this article. It will help you understand.
Maxtor n256 60 gb HDD jumper settings
Here take a look at this pdf:
eshop.macsales.com/Tech/manuals/idehdsettings/Maxtor72.pdf
So If this is layout " : : : . : "
then...
slave -----------
master -------- " [:]: : . : "
cable select -- " :[:]: . : "
Jun 04, 2012 | Maxtor Computers & Internet
Jumper settings for master drive
if its a SATA hard driveyou dont need to set master slave the biggest capacity hard drive will set as master
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to IDE-1 means Pri slave escape then press f10 to save to cmos to restart
you will have to have master with slave set up
you can find the jumper location next to the power on a hard drive and the settings for plastic jumper location is usually printed on the top of a hard drive
IDE-0 means Pri master
IDE-2 means Sec master
IDE-3 means Sec slave
single or master :::::
master with slave ::'::
slave :::':
black line between dots is plastic jumper
note the plastic jumper is ' located at the rear of the hard drive between the EIDE and electrical lead/s
Oct 03, 2011 | Dell Computers & Internet
Slave Harddrive I have an extra harddrive that I wish to install as a slave, unfortunately I cannot at the moment, due to some problems. First, the current harddrive I have is a Maxtor I believe, and it...
Dear soviet guy
these are the jumper settting for both the drives
please check that they are on the right place before if you want to use seagate as a slave try placing the jumpers as mentioned.
Maxtor Jumper Settings
Seagate Jumper Settings
Thanks
GAGAN GUPTA
Mar 17, 2011 | Microsoft Windows XP Professional SP3 Full...
What happen if i dont put jumper in a hard a hard drive?
If you don't put jumper in harddrive is detects it as cable select means if you connect your harddrive to middle socket of ide cable and then it detects it as slave but if you connect it at the end of ide cable it detects as slave.But make sure that otehr device is not set as master only 1 device is set as master or slave .
Let me know if you need further assistance.
Thanks for using FixYa.
Jun 01, 2010 | Seagate U6 (ST340810A) 40 GB Hard Drive
Need IDE jumber settings.
There is a little jumper block on the rear of a DVD. by IDE connector. on the case above there will be a Table marked . Master: Slave: CS. Now, you must set the jumper as to your drive's position. IE: Master or Slave, Master is on the plug at the END of the ribbon, the Slave is on the "Other" one. Accordingly the Master has the Master Jumper ON, the Slave the Slave Jumper ON. CS is Cable Select. It isn't all that used.
Feb 11, 2010 | Plextor 52x32x52 PX-230A Internal CD-RW...
I want to add another hard drive and need to know how to set the jumpers on my maxtor 90645d3 please help.ty
if you want to boot from this drive, please set the jumper to the master position.
if this drive is for additional storage, please set the jumper to slave. and make sure 1st hard drive is set to master.
if this is the only drive in the system, please set the jumper to single or remove the jumper.
there will be a chart telling you which pins are for which setting in the jumper area, which is between the data plug and the power plug on the back of your HDD.
main thing that will cause drives to not work is 2 jumpers on the same cable and they both are set to the same thng.. i.e. master/master or slave/slave. also, if one is set to single drive it will likely bypass the slave drive.
Jan 25, 2010 | Maxtor Hard Drive
Sir When i connect cd rom & hard disk together on my computer then the does not work.Kindly give me a solution.
There is a jumper in HDD and CDrom
  • Set the hard disk jumper to Master Connect the drive using the Master connector on the primary IDE cable.
  • Set the CDD jumper to Slave Connect the drive using the Slave connector on the primary IDE cable.
To know about jumper settings verify this link
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph03792&lc=en&dlc=en&cc=us&product=3872037
Aug 28, 2009 | Computers & Internet
Diamond max 20 hard drive won't install - jumper problems - want as slave, my old one as master
on the back of the drive there should be a black, white or yellow jumper. If you look very carfully at the back of the harddrive where the jumper is, it will tell you which position you need to have the jumper in for slave and which position you need to have it in for master. If it is already in the master position, carefully pull it out then push it back into the correct position to act as slave. Some hardrives simpley have a M for master and a S for slave while other harddrive will actually have the words. I hope this helps.
Oct 23, 2008 | Maxtor Hard Drive
Slave harddrive jumper settings
usualy its just one jumper if no jumper on maxtors becomes slave. jumper on 50 is master. if u use cable select.. on same ide another device must also be cable select.
if one is master other is slave on same ide.
Jul 15, 2008 | Maxtor Hard Drive
Hard drive not detected
Rickyrudy, I suspect one of the following may work: -The problem drive is set as the slave on the secondary IDE channel. If it?s the only drive change it to the master. -Try checking the drive setup setting in the BIOS, make sure both drives are set to auto detect in the BIOS. If this works don?t forget to try setting the unused drive setting to none to speed up the boot process. -If you are using jumpers to define the master and slave double check the settings against the chart on the drive in question. -If you?re using cable select to define master/slave drives try using the jumpers instead. Let us know if this works and please don?t forget to rate this posting.
Feb 25, 2007 | Tekram P6 B40-A4X Motherboard
Computers & Internet Logo
125 people viewed this question
David Payne
David Payne
