Question about Acer Aspire 4520-5582 Notebook
Missing CD ROM icon - Acer Aspire 4520-5582 Notebook
    Novelist:
    Champion:
  • Acer Expert
  • 239 Answers
It happens if the upper and lower filters are corrupted. By removing both or anyone of the files will resolve the issue. To do so, please follow the below steps (Note: Please delete the excat entry in the steps below. If you do not find the entries ignore it. Do not delete any other files that will screwup your computer):
1. From the Windows Vista default Start menu, point to All Programs, Accessories, and then click Run.
2. In the Run dialog box, type: Regedit and Click OK.
3. In the User Account Control dialog box, click Continue.
4. In the Registry Editor window, locate and then click to select the following registry subkey: HKEY_LOCAL_MACHINE/System/CurrentControlSet/Control/Class/{4d36e965-e325-11ce-bfc1-08002be10318}
5. From the File menu, click Export.
6. In the File name dialog box, type: Savedkey, and then click Save.
7. Click the REG_MULTI_SZ data type UpperFilters file, and then from the Edit menu, click Delete. When you are prompted to confirm the deletion, click Yes.
8. Click the REG_MULTI_SZ data type LowerFilters file, and then from the Edit menu, click Delete. When you are prompted to confirm the deletion, click Yes.
9. In the Registry Editor window, from the File menu, click Exit.
10. Shut down Windows® and restart the computer
Thanks and regards,
Jitha
Posted on Apr 02, 2011
My CD-ROM is not recognising any CD/DVD And CD-ROM icon is also missing in my computer menu
Go to Control Panel/System/Hardware, delete the CD-ROM, and reboot so the system can find it again. If it doesn't come back after the reboot, then try physically detaching and reattaching the drive (with the power off, of course).
Oct 25, 2009 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
CD-ROM icon missing from My Computer. I have this problem now. Originally there was no problem. The drive is okay. It's a software problem.
Indeed it is a software problem. This was a known issue with Microsoft, and you can follow this link to download the patch that will rectify the problem.
May 15, 2009 | Samsung (SC-152) Internal 52x CD-ROM Drive
CD html presentation-hyperlinks don't work with other pc's
To create an Autorun-enabled CD-ROM, proceed as follows:
  • Create an Autorun.inf File
    Autorun.inf is a text file that is located in the root folder of your application CD-ROM. It provides to the computer the name and the location of the startup program for your application that is installed when the CD-ROM is inserted. The Autorun.inf file can also contain optional information including the following:
  • The name of a file that contains an icon that represents your application's CD-ROM drive. This icon appears in Windows Explorer instead of the standard drive icon.
  • Additional commands for the shortcut menu that appears when the user right-clicks the CD-ROM icon. You can also specify the default command that runs when the user double-clicks the icon. Autorun.inf files are similar to .ini files.
  • The [autorun] section contains the default Autorun commands. All Autorun.inf files must have an [autorun] section.
  • icon: Specifies the path and the file name of an application-specific icon for the CD-ROM drive.
  • open: Specifies the path and the file name of the startup application.
Autorun.infThe following is an example of a simple Autorun.inf file. It specifies Filename.exe as the startup application. The second icon represents the CD-ROM drive instead of the standard drive icon.
[autorun]
open=Filename.exe
icon=Filename.ico
May 07, 2009 | Dell Dimension 4600 PC Desktop
Dvd/cd rom drivers
try dell.com for driver downloads for your drive.
or uninstall it from your device manager and reboot and it might fix itself
Apr 04, 2009 | Dell (313-1220) CD-RW/DVD-ROM Combo Drive
VMware Tools Installation Problem
Use Ultra ISO or other VCD-ROM to mount the cd iso image on your hdd and map it in VMware F
Jan 04, 2009 | VMware Fusion Full Version for Mac
Missing cdrom drive
The triggers determining the slave was set to master with the CD rom drive as well...so I had two master drives...kind've stupid. Everything is now working properly!
Dec 30, 2008 | Memorex (278010300003) Internal DVD Drive
CD ROM won't play
Check the Hardare manager is there any question mark at the icons of the CD drive? If the auto play does'nt work then the CD-rom is not reading the CD, either the CD format is different or the CD-rom lens is faulty. Note: don't remove Hardware when PC is running, you might cause damage to your Hardware devices.
Nov 29, 2008 | Computers & Internet
Dvd-rom icon missing
(1) Check bios for detection if detected continue the following steps else DVD is gone or you can remove test it in other system.
(2) You can manually DVD from control panel by clicking add new hardware wizard, continue the step.
(3) last option try install your operating system agin.
Apr 19, 2008 | Panasonic Matshita- | CW-8124-B | USB 2.0...
Missing cdrom drive
Is the LED of your CD ROM blinking? If yes then go to device manager by right clicking the My Computer icon and then click the Properties command. In the Properties window select the Hardware tab and then click the device manager. Is the CD ROM entery there! yes> right click and enable the device. If no then reformat your hard disc and reinstall.
In case your CD ROM's LED is not blinking (Rarest case) then simply check all the cables connected to it, atleast the power cable. if it is still not working, your CD ROM got damaged and there is a time to change it.
Feb 04, 2008 | Computers & Internet
CD-ROM icon missing on screen
Hedge,
Can you see it in your device manager? if you can't then its a physical problem which means you will need to double check your physical connections between the cdrom and your motherboard as well as the power connections.
Another way to double check is go to your bios and see if the biois detects your cdrom. If it doesnt then i think you cdrom is dead.
smeags.
Jan 07, 2008 | Samsung (SC-152) Internal 52x CD-ROM Drive
Acer Aspire 4520-5582 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
