Hi, Sir, Vizio plasma tv P42HDE, no picture and have sound, opened the back cover, found the green led that on the power board was blinking, no vs, no vo and no 5v to Y sustain and X sustain, after disconnected between Y sustain and power board, the vs, vo and 5v recovered, the green led stable lignt. My question: May the problem be on the power board or on the Y sustain board or on other place? How to confirm it? Thanks Wei Qi Zhang
  • 4 Answers
SOURCE: plasma tv has no picture but green led is on
Try unplugging the TV for a few minutes (discharges the ballast/ps) then plug in and attempt to power on. I have the 42P Vizio over two years old and ran into the same problem a few times. First thought was a power supply issue, but the unplugging trick worked. Good luck.
Posted on Apr 17, 2009
  • 7 Answers
SOURCE: Vizio P42HDe Plasma TV - Audio, but no picture
check the backlight inverter and the Y-sus board the one to your left. if those are fine check the bottom right buffer board
Posted on Apr 20, 2009
  • 267 Answers
SOURCE: 42 inch DO42746 no picture or sound
It is still possible the z sustain board is bad. or an x driver board.
Posted on Jun 26, 2009
romsky79
  • 822 Answers
SOURCE: Phillips 42pf5321d/37 No picture Error code D3V3
pls. check the power inverter.
Posted on Jun 28, 2009
  • 8457 Answers
SOURCE: I have a Philips 42PF9630A/32 Plasma TV, red led blinks 7 times
No,body can cofirm u have to troubleshoot change the boards to know the problem.
Posted on Oct 22, 2009
LG 42PC!R Plasma TV turns on and then green led blinking with no ppicture and sound !
Your problem is most likely a fried circuit board. I always connect my good electronic to a back up battery. but your problem might have been storm or surge related, I would take it to a repair center and get an estimate.
Sep 19, 2014 | LG 42PC1R 42 in. Plasma HDTV
Vizio p50hdtv10a led light blinks 10 times when powered off
If the problem is same with different input devices and you have ensured the are no loose contacts in power outlet, RC jack, cable and sockets, the TV needs servicing.
Aug 16, 2012 | Vizio P50HDTV10A 50 in. Plasma HDTV
I have vp50HDTV20A HDTV PLASMA TELEVISION The
Good day sir Thor!!!!
I already encounter that kind of problem many times..It looks like all normal even the green power light is not blinks or change to red or amber color but still no sounds or picture on TV..
Sometimes it will happen to plasma TV in all brands and model..It cause of faulty main board..
This is the sample picture of main board of your unit..Part # (3850-0142-0150)
You can order this parts here:
http://premiertvparts.com/index.php?main_page=product_info&cPath=1&products_id=797
http://www.ebay.com/itm/NEW-VIZIO-VP50-HDTV20A-MAIN-UNIT-3850-0142-0150-2A-/320737894046
http://tvpartsfast.ecrater.com/p/12695612/vizio-3850-0142-0150-main-board-for-vp50hdtv20a
http://modulesrus.ecrater.com/p/11497716/vizio-main-a-v-3850-0142-0150
Just replace the board to fix your TV and it works again..
Note: When you install the board make it sure that the static energy on your body discharge to ground to avoid corrupt of main board IC..
EXAMPLE: open the cover then find the main board..before you do that make it sure you hold the metal portion of your TV to discharge static after that you can now freely replace the board and also make it sure to memorized the connector to avoid damage to make it sure take a picture on it before unplug connector for future reference in case..
again discharge static please!!!..Only few tech or other people know this that's why when they install new boards its not works even it is new..I discover this base on my experience and study..
Hope it helps..
Please don't forget to rate!!!!
Thank you using fixya..
Feb 28, 2012 | Vizio P50HDTV10A 50 in. Plasma HDTV
My 50inch vizio p50hdtv20a that was bought in 2008 is no longer working. It has no picture, but does have sound and obviously still has power. I need to know how i can fix this myself. If its a fuse thats...
how much time does it blink?it can be your video model.i am not too familiar with that set.but the module is on the right side of the set as you open the back.the whole of the module has to be replaced.
Mar 06, 2011 | Vizio P50HDTV20A 50 in. Plasma HDTV
No picture or sound
Does it have power LED on/blinking? Any clicking sounds from inside when you connecting TV's power cord to the wall outlet? If it's completely dead - check power outlet in the wall, check power cord with multimeter, than open up rear cover and check fuses with multimeter. If they are OK - you need professionals diagnose it. Repair will start with power board replacement.
Mar 10, 2010 | Vizio VP422 42 in. Plasma TV
Sanyo DP50747 Replaced Power Supply still not working
I have same problem. Walmart is selling Sanyo junk You are not alone lots of web chatter about these lasting 2 years or less, Mine lased 19 months, Trash it & buy a different brand. I originally was going to buy a Samsung & now I will.
Sep 22, 2009 | Sanyo DP50747 50 in. Plasma TV
Plasma tv has no picture but green led is on
If you are not able to bring up the TV's onscreen menu while the picture is blank, then you have a problem with a video board.  If the menu does come up then usually the problem is with the device connected or its related input jack or cable that is in use. You may have to try another input or cable to be sure, but only if you are not able to see the menu.
Mar 26, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Mar 03, 2009 | Vizio P42HD Television
Hi, I have a Vizio P50HDM
For your Zenith P42W34D TV. The problem cause the a bad Y drive board. Replace the board will fix it.
Hope this will help.
Jan 29, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
TV does not turn on/red led flashes 7 times in front
this is common issue with this model and through your troubleshooting is tied to y main board. blinking led on logic main in normal operation. when replacing y main always good idea to replace y upper and lowe buffer boards as they complete a circuit and sometimes replacing one without other could cause additional failure on remaining boards
Aug 10, 2008 | Philips 42PF7320 42 in. EDTV-Ready Plasma...
Televison & Video Logo
Top Televison & Video Experts
