Question about Fisher and Paykel Washing Machines
Top loader just stopped cycle. and wont switch back on
    Top Expert:
  • Fisher and P... Master
  • 9,472 Answers
It sounds like the motor control module has failed. Check for power to the input of the control. The line cord feeds right into the controller.
If you determine that there is indeed power to the controller, you need to figure out what caused it to fail, making sure there isn't a secondary condition which caused this control to fail.
A leaky, wet or shorted water pump can cause the control to fail. Inspect the water pump for signs of leakage and corrosion.
Check also to make sure the controller isn't sitting in a pool of water. The thermistor seal on the water mixing chamber can leak and allow water to seep into the pan where the control is located.
A shorted water inlet valve or shorted diverter valve can also cause control failure.
If you do not check these things, and replace the control, it will fail in short order if any of the above mentioned conditions are present.
Posted on Mar 13, 2011
I have a Samsung WA13G7Q1 top loader giving me a DE on LCD when spin cycle starts then just stops.
DE is an error relating to the lid switch/lock not working, if it cant sense the lids shut it wont spin, it could be as simple as the magnet in the lid has moved or the more likely cause is the lid switch has died, it will require further inspection or you could just order the lid switch and see how it goes
Jan 28, 2017 | Samsung Washing Machines
My washing machine door is not opening at the end of a cycle. I put it onto another and it still won't at the end of that one. I've turned it off as well for 10 mins or so, and still nothing. Please help!
you didn't state whether it's a top or front loader. either way, there's a switch activated when the door is closed and washer is in cycle mode- so you can't open the door when a. the front loader has water in it, or b. the top loader is in agitate, or spin cycle. if top loader- there's a tab on the end opposite the hinge side that activates a switch that latches the cover closed when in 'dangerous' cycles (don't want to get your hand caught in the spin cycle!!). either a loose wire or a failed switch! prob. need to gently pop the top (should hinge back) to access the switch. UNPLUG THE WASHER!! if a a loose wire, re-attach-if not, replace switch! easy! good luck!
Apr 17, 2010 | Washing Machines
HELP
ww.repairclinic.com/RepairHelp/RepairHelp.aspx
www.acmehowto.com/howto/appliance/washer/washer.php
home.howstuffworks.com/how-to-repair-a-washing-machine.htm
http://www.managemyhome.com/mmh/Troubleshooting_Guides/TopLoadWasher.pdf
Nov 16, 2009 | Washing Machines
Doesnt spin or drain
Sounds like its a pump problem if pump dosent work the rest of the cycle wont either maybe pump belt has come off or has broken hope this helps
Sep 06, 2009 | Kenmore Washing Machines
Maytag top loader stopped during spin and now won't start.
ok check the lid switch,,did it knock it out of place,,unplug and take back off ,,,
Jan 05, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag top loader washing machine
i believe i can help you,,but washers dont agitate in the spin cycle,,i believe you ment it wont wring or spin in the spin cycle..your lid switch is defective,,replace,,if need be i can talk you though,,onthejob
Dec 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Frigidaire top loader
hi thanks for your question. it would appear to me that the problem is with your lid switch would check that first try it and let me know thanks THE APPLIANCE DOC.
Aug 04, 2008 | Frigidaire CWS3600AS Top Load Washer
Cycle stops...
replace the lid switch, or check the connections it might even be your pusing rod for activating the switch
Jun 17, 2008 | Kenmore 24032\24036 Top Load Washer
Washer filled with water & then stopped & will not work in any cycle.
could be a bad pressure switch did it fill all the way is it a top loader or front loader any noise or nothing
Dec 31, 2007 | Kenmore 24622 Top Load Washer
Open Questions:
Washing Machines Logo
41 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
