Colors won't a line - Televison & Video
  • 8,617 Answers
You need convergence Ics. post your model number and I will post the correct IC numbers for your model and post a link where you can get replacements with free instructions. Please reply to this same post when responding
Posted on Aug 01, 2008
Grounded out wires and it won't crank over
A/T or M/T transmission, they are wired diffr.!
I guess, you know flashing is bad wiring , right?
but this no crank page solves this.
takes only $20 voltmeter to be , effective.
to crank takes but 1 wire. (starter good)
the ST line or start line.
suzuki calls this 1 wire the Start line, (amazing fact)
at the key switch a black-red wire.
then after passing through the (clutch/ or A/T park switch)
the color changes, 1 time to blk-yell, then lands on the starter.
its very simple and fully show here, in details.
http://www.fixkick.com/nocrank.html
Mar 31, 2013 | 1994 Geo Tracker
Tip
How to reset nokia mobiles life timer to ''0''
Nokia life timer is a counter that keeps track of the Total call time of your phone. It will show how much the phone has been used, and it?s the best thing to check if you?re planning to buy a used Nokia Mobile.
To see the Total Call Time or the life timer counter, On the standby screen type the following code *#92702689# (Easy way to remember this is ? *#war0anty#). And it will pop up a message that shows the life timer in hours and minutes.
Here is a detailed procedure to make this life timer zero.
REQUIREMENTS:
The following files are required to reset the life timer:
  1. Nemesis service suite link: Download from Here
  2. lifetimer.pm file: Download Here
PROCEDURE:
1. Download and Extract the lifetimer.pm file, and Download Nemesis Service Suite.
2. Install Nemesis Service Suite on your Computer, It won?t take much time.(select the first option)
3. Install Nokia Cable Drivers (No need to install, if you have Nokia PC Suite already installed)
4. Connect The Phone in ?PC Suite? Mode to the PC
5. Open Nemesis Service Software
6. Click on ?Scan for new Device? Button on Top right Corner
7. It Will take a few seconds to scan, and it will load up the software interface after communicating with the Phone.
8. Click the ?Phone Info? Button.
9. On the Bottom, Select and open the ?Permanent Memory? Tab, which is next to the Fbus info.
10. Click the ?Write? button on Below right, and open the Extracted lifetimer.pm file on your PC.
11. After the lifetimer.pm file is opened , it will immediately start writing it to the Phone?s EEPROM Area.
12. The Procedure will end when the progress bar reaches 20%. This is normal , and on the bottom right side, it will display its done.
13. Unplug the Phone, and Restart it.
14. After boot up, Check the life timer .
Note: This method has been tested on following devices: Nokia 6630, 6670, 6680, 5500 sport, 5700XM, 6110 Navigator, 6120 Classic, N70, N72, N73,N76, E50, E51, E61i, E65, N80, N91, N95, N95 8GB, 5800XM Mobile devices. If you want to try it on other S60v3 or S60v5 mobiles, do it at your own risk.
Caution:
  • Power Failure During Writing will cause damage to the Phone, And there is a chance that it might brick the phone as well.
  • Loose, worn out Data Cables Might fail the Writing process, and there are chances of damage to the EEPROM area of the phone.
  • Do not attempt this with phones that are not included in the confirmed list.
By:- Mohammed Abdulhadi
on Jun 21, 2010 | Cell Phones
Tip
How to setup your EPSON FAX
1. Connect the supplied phone cord with one end to a phone jack and the other end to the LINE port of the unit. Make sure that the phone jack has a dial tone.
Note: Nowadays a lot of people are using a VOIP Service, keep in mind that the FAX was invented to work on an analog phone system (yeah the regular phone) and this new phone system might result in FAX transmission failures.
2. Default FAX settings works fine. The only time you need to configure it is if you have a phone or an answering machine connected to the unit.
3. To test if you can receive fax, go to http://www.faxzero.com (a free fax service) and send yourself a fax message.
4. To test if you can send fax, a friend's fax number is recommended.
on Nov 06, 2008 | Epson Stylus Multifunction Printer/...
HP C6280 will not print self test diagnostic
Do you have an Anti-Virus program installed on your PC? If so, can you try and disable it before you print.
for more help visit CBR Tech Solutions
Mar 13, 2013 | HP C6280 All-in-One Printer
The sensor light are different colors
The sensors are seeing something directly in line with the beam between the 2 sensors, or your sensors are not aligned so they point directly at each other.
Jan 12, 2013 | Craftsman Sears Liftmaster Garage Door...
I have a moniter that the cord is cut. how do i find out what wires go where on a plug
Without having even a brand name or a schematic we can't even guess what you have. IF THE iwres have color codes it is likely if red green and blue wires are present, that they are the red green and blue lines. Search Google for: vga pinout This will bring up images of the VGA connector pinouts. Just get the shield in the correct place and you really won't damage anything by a wrong connection... it might take a while by experiment to get it to work... The color lines will likely have the return wire with a "tracer" color that might be like a red wire with white stripe which would be the return for the red... etc.
Nov 12, 2012 | Computers & Internet
I have a Sony Bravia KDL-52XBR4 LCD TV.
Sure, but not at minimal cost - it's a sony! Probably the t con board.
Sep 17, 2017 | Sony BRAVIA KDL-52XBR4 LCD TV
Hp 5510 io keeps stating to check color cartridge/3 lights blinking/won t print/installed new color'' Let our Experts solve your ''hp 5510 io keeps stating to check color cartridge/3 lights blinking/won t...
hi..
try to install and reinstall the printer cartridge...and also clean the tab circuit of the cartridge and tab circuit of the printer carrier..
if the problem still exist..
rebreak the printer by full-out the power supply...to reset the settings and then turn it back...
Apr 01, 2009 | HP Officejet 5510xi Printer
Canon PIXMA iP4000 Will not print red Deep clean won t work Other colors OK
remove print head assembly. clean off.
print head not on cartridge.
Jun 04, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Red and green colors won't allign....
There is one way. Get way to go in to service menu and set conversions manualy. Remember to save. Tv will be ok
Dec 25, 2007 | Toshiba 46HM95 46" HDTV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
