Question about IBM ThinkPad T21 2648 Notebook
Laptop ibm t21 works for 2hrs and doesn't start for another 2-3 months. total power supply stop after 2hrs and removing and replacing battery again power supply start but laptop doesn't work
    Habit-Forming:
  • 88 Answers
If you need parts for this laptop contact me.. Your best option is to replace motherboard, the power supply..
Posted on Mar 13, 2011
IBM Thinkpad T21
This is a common problem with the T20 series Thinkpad. The problem is with the power management chip. Unfortunately, you will have to replace the motherboard to fix it. Since these are a bit on the older side, you can get a motherboard off Ebay at a reasonable price.
Aug 04, 2008 | IBM ThinkPad T21 Notebook
IBM T21 doesn't start
try to start it with the battery out by pluging it straight, the battery is dead and its causing problems
Mar 13, 2008 | IBM ThinkPad T21 2647 Notebook
IBM Thinkpad T21
T21
Input Voltage: AC 100-240V, 50-60Hz Output Voltage: DC 16V, 4.5A, 72W Max
You can get one on EBAY for cheap.
http://cgi.ebay.com/Laptop-AC-Adapter-Charger-for-IBM-Thinkpad-T21-2648_W0QQitemZ300173112123QQcmdZViewItem
Nov 19, 2007 | IBM ThinkPad T21 2648 Notebook
IBM T21 Thinkpad
Here are the solutions ive gathered for this problem:
IBM has finally given me a fix for the T21 I am working on for a
customer. I asked them "What if it doesn't work, then what. Their
response was "GAURENTEED to work". Here it is:
1.) Unplug the power cord and the battery.
2.) Press the 'Power' Button 10 times repeatedly.
3.) Then hold the 'Power' Button down for 25 seconds.
4.) Put the battery back in and plug the power cord back in.
5.) Should power up right away.
This did work THIS time on the machine I have in front of me. I hope
this works for all of you. If you have any other questions, please
feel free to email me and ask any questions
Oh and just one more thing to help you out.
This problem is caused by an overcharged capacitor (supposedly) and
the error ONLY occurs IF you leave the laptop plugged in too long with
the battery in. If you ONLY plug it in when you are using it, then it
should not overcharge. And actually I would suggest that you unplug it
about 20 min or so before you are done using the system.
I have been a IBM Thinkpad T20 user for last 3+ years and I think it
is an very sturdy system that it's been working non-stop for such a
long time with not a single problem even after so much of abuse it
went thru in my baby's hands......until last week when it just wont
boot up. Then I found this post online....I tried the refrigerator
option also to no avail. Finally I just removed the battery and AC and
let the system sit for a 2 days in a cool place near window. Third day
I plugged in battery, plugged in the AC, and voila, it comes up fine.
Right now I am backing up all my files and I'll keep you posted if it
experiences a boot problem again. If I don't post again, assume it's
all working good again !!
Bottom line is that it could be the overcharged capacitor in my case
and letting it sit alone discharged it completely.
Good luck to you!
I have the same problem, and i fix it. Well no fix but now in few
seconds i can start notepad when i want to. My battery dead. Without
the battery, you can start if you hold down the power botton while you
get in/get out quickly the ac connector several times .Try it!!!!
I think the intelligent battery or same cheap condensator in the power
module is the problem (so when you connect the ac power connector you
can hear the charge of it).
you can restart without problem but if you switch off you will need to
repeat the process to start the notepad.
I have a T22 that won't power on. After removing the AC power cord, I had to repeatedly (as fast as you can press it) press the power button until it powers on. I was not able to do a normal shut down, it would just hang. So with the battery removed and the AC plugged in pull the AC power cord.(Try to do it when the hard drive light is out!)I have cycled thru several power ups with no problems after doing this.
Hope this might help somebody else.
I would love to know which capacitor is being affected on the motherboard. this way you could install a momentary switch with resistor to ground to drain the capacitor.
Thanx to all the authors of these solutions
Nov 08, 2007 | IBM ThinkPad T21 Notebook
IBM thinkpad T21
I had a similar problem after My pc got damp in a bag in the rain. I contacted IBM and was given this fix which I am supprised worked but it did so here it is cannot hurt to try. Remove the main battery and the mains power supply press the power on button for 17 seconds. This I think is to drain all the power from the laptop altogether. Replace the mains lead and turn on. Once the laptop has openen up into windows turn it off and replace the mains battery then power on again. In my case this worked I hope this helps.
Oct 17, 2007 | IBM ThinkPad T21 Notebook
Ibm t21 2647
It sounds like your system board is gone. It will need to be replaced. A used board goes between 150 -300 dollars. For someone to check it will still need to be disassembled.
Oct 03, 2007 | Lenovo ThinkPad T21 2647 Notebook
IBM T21
i have the same problem. actually its a common problem for many T21 and other old IBM laptops.
i searched that you have to take all power (batery, adaptor)
press the power 10 times and press it for 30 secs then reinsert the battery or adaptor and try to power it on.
they say its done to discharge a certain capacitor that got overcharged after overcharging the battery.
that worked for me before but now my T21 wont start any more with this process.
May 20, 2007 | IBM ThinkPad T21 Notebook
IBM ThinkPad T21 2648 Notebook Logo
70 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
