Question about MSI K8MM-V Motherboard
MB MSI K8MM-V, Unable to detect 80 GB primary HDD. What need to be done ? Update Bios ? Which one ? Ravi
  • MSI Master
  • 32,281 Answers
If the BIOS cannot detect the 80Gb hard disk then it is probably faulty.
Make sure the jumper on the hard drive is set to MA (master), if this doesn't work set it to CS (cable select) If it still isn't detected by the BIOS then the hard disk is faulty and you need a new hard disk.
Posted on Mar 13, 2011
Sata
First, try a different sata cable...
If that doesn't work then flash your Bios to the latest version. You can get it here:
http://www.msi.com/product/mb/K8MM-V.html#/?div=BIOS
Aug 29, 2012 | MSI K8MM-V Motherboard
My windows time is getting slow gradually. What should i do ?
There could be two reasons for the same,
1. The coin cell battery is drained and need a replacement
2. The motherboard software (BIOS) has gone bad , would require an update .
The following link is the BIOS update link for the motherboard. Before update make sure , all external peripherals except the keyboard and mouse has to be disconnected . Also verify the the existing version of the BIOS
If the above steps donot help, Then the motherboard needs to be replaced.
Thanks for using Fixya
Proton
Aug 27, 2011 | MSI K8MM-V Motherboard
I have MSI K8MM-V MOBO w/VT8237R Chipset. WIN XP 2 gig ram I have a WD7501AALS HDD to replace a WD1600JS-22N HDD Both are SATA drives Problem: The BIOS nor the POST will recognize the WD750. I have...
Hello, You need to right click on to my computer>Manage>choose disk management, you should format the new SATA HDD there.
If that will work for you that is good but if not, i thing you should updated the BIOS and you have to make sure that you get that update to MSI website. if you are not familiar w/ that asked some one who know how to flash BIOS. it is risky if you are not familiar doing BIOS update!!!
Mar 04, 2011 | MSI K8MM-V Motherboard
Hdd and cd/dvd
One thing you can do is to reset the bios setting by clearing the bios. You will need to revothe battery and remove the jumper CMOS battery cc1 .
Note the setting before removing.Usullay ithe default is pin one and pin two.
One oher thing that you can do is to update the bios version
This is sure it will correct the problem oc cd/dvd.
Here are two links below for bios update try this
http://drivers.softpedia.com/get/BIOS/Msi/MSI-K8MM-V-Bios-18.shtml
http://drivers.softpedia.com/progDownload/MSI-K8MM-V-Bios-18-Download-45381.html
ok
Jun 24, 2010 | MSI K8MM-V Motherboard
500 Gb sata hdd not detected on k8mm-v motherboard
Find in your BIOS if you have an option that says configure SATA as IDE, AHCI and raid. Set it at IDE and try again to install the OS. After intaling do not switch back because it will not work.
Apr 06, 2010 | Computers & Internet
Msi k8mm-v board not detecting SATA 320 GB HDD
peets, is this drive a slave drive? if so, make sure you have the jumper ******** the hdd set for "slave" , the instructions that came with it and on top of the hdd itself shows you where that is. You should have it set up for this anyways so you can format it to your liking(i.e. if your going to partition it out or use the whole 320GB for your data). after doing this you will need to go to you bios screen when you boot up your computer(setup). Go to standard or advanced bios settings and see if the new hdd is there, your bios should recognize it, if not, make sure you write down all the info for your hdd (size, cylinders, heads, type) and input the info for a correct installation and when you are finished, make sure you save the info (F10) and (Y) computer will restart and it should see the new hdd. Also, I take it you have CD/DVD driveconnected to your primary SATA or IDE port, this should not be a problem, if so send a msg back.
Dec 14, 2009 | MSI K8MM-V Motherboard
Drive SATA 3.0 Gb not detected by msi 7060
3GB Sata driver? i dident know there existed so smal drivers
Anyway, if your bios dosent detect the driver u probably need to update the bios drivers.
Go to MSI site:
http://global.msi.com.tw/index.php?func=proddesc&maincat_no=1&cat2_no=&cat3_no=&prod_no=158
Instal LIVE UPDATE and let msi check you computer for laterst drivers u need to instal
Nov 20, 2008 | MSI 661FM2-LSR Motherboard
Sata drive not detected
just no other solution except upgrading BIOS properly
Sep 24, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Problems Installing my 160 GB Seagate SATA HDD
Check the SATA/RAID controller setting. It could have been set to [Disabled] Refer to your user?s manual for a detailed description on how to enable the onboard SATA/RAID controller by adjusting the jumper or BIOS settings. Regards SparkGap
Sep 24, 2007 | ASUS P5RD1-VM Motherboard
MSI K8MM-V Motherboard Logo
90 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
