I HAVE TEAC a-360 CASSETTE DECK WHICH THE RUBBER BELT HAVE BEEN DAMAGE AND NEEDS A NEW ONE. MY QUESTION IS. WHAT ARE THE SIZES OF THE RUBBER BELTS I I HAVE TO BUY IN A ELECTRONIC SHOP. PLEASE JUST EMAIL ME THE SIZES. THANKS, JACK GONZALEZ
  • 8 Answers
SOURCE: Source For Replacement Belts
http://www.studiosoundelectronics.com/cassette.htm
http://www.turntableneedles.com/index.asp
Posted on Oct 27, 2007
SOURCE: teac a 303 cassette deck
Posted on Dec 05, 2008
Grubhead
  • 5126 Answers
SOURCE: repair cassette deck, rubber band changeing-for
Knowing cassette makers I doubt there will be a simple way to do it. You could look for the service manual, but I wouldn't hold out hope for a trick!
All you need to do with the belt is measure the diameter in MM and search for it on Google as "Cassette Drive Belt ??MM". The measurement does not have to be spot on!
They are not maker specific mostly. And don't worry about the colour.
PS make notes about how it fits together or take pictures! Before you dissmantle it.
Posted on Oct 28, 2010
  • 4234 Answers
SOURCE: akai cs=f11 stereo cassette deck needs spare
Parts for these are no longer available from the manufacturer and I don't have a specific cross reference for the rollers for this model. The best bet at this point, is to go to a repair shop that handles audio repair. They should be able to remove the rollers and measure them. Rubber parts are available from generic suppliers. The roller itself will remain. The rubber should be available. Unfortunately, having access to the actual unit is required to provide more information.
Dan
Posted on May 29, 2011
SOURCE: Change the rubber belts of the RS-TR373
This video might help: http://www.youtube.com/watch?v=gVWjgEMOufo
Elias
Posted on Aug 15, 2012
How do I get fast forward & rewinds to work on my Teac W450-R dual cassette deck..?
Check the belts, inside the unit you should see a rubber belt which is what pulls the tape fast forward or rewind. Some belts with time get loose and slip, they can also break and fall off which will not let you fast forward or rewind.
Open your cassette player and look where the plastic pulleys are located and check for the belts, they might not be broken at all but very loose and slip on the plastic pulley.
Jun 07, 2015 | Teac Audio Players & Recorders
MY CASSETTE DECK BROKE THE RUBBER BELT CAN THIS BE REAIRED
Yes, a new belt can be installed. That might not be the only problem. The belt may have broken because there is an issue with that transport.
Mar 05, 2015 | Teac W-600R Single Cassette Deck
Teac w-750r double cassette deck stuck
The mechanism needs new belts and maybe grease cleaning and new applied. The dual cassette decks are not usually worth the charges a Technician will charge to fix them.
Apr 22, 2014 | Audio Players & Recorders
How to replace the belt on a Teac W-750r cassette deck
In all the years I have been in tape decks repair I have never seen one. You either have to work with an experienced Technician or do it yourself using common sense. Going to college gives you a degree and knowledge of parts it dos not tell you how to fix anything. That may be why I work on some Nasa Engineers tape decks.
Jan 06, 2014 | Teac DUAL CASSETTE A/R 110/220 Single Dual...
Getting belts for TEAC W-890R. I'm currently sitting here a home with a DEAD TEAC A-350 Cassette Deck -- DEAD because I was told you can get belts for it (I have since found out that is is NOT true and...
That is the state of conditions at Teac and they don't care about tape customer anymore. If you need belts for any unit it is simple to find the belt kit at Marrs Communications. They do not have he cheapest prices bu the you don't know what size you need and Fred took time to find his out. If you want to do it the other way you download a copy of the PRB cross reference manual and look up the belt type that goes into your deck. The you go to Ken's Electronics and order the belts online. This does not come with instruction of how to put them in. In my many years as a Technician working on all kinds of tape decks I have never seen an instruction to put belts in a machine- it is assumed that if you can not figure this out that you probably do not belong in the machine. In cases where belts are not in place sometimes the parts layout diagram can help you determine how they go in.
I am an ex Teac Lead Technician from Chicago.
Aug 25, 2013 | Teac W-865R Single Cassette Deck
I have a TEAC A-350 Cassette Deck, and has been dead for years. It needs belts. I was told that belts were not available for it. I have since found some belts meant for the A-350, but have not got a clue...
The belt installation is not often indicated in the service manual but comes from years of experience of working on these. I worked on a few of these at Chicago Factory Service (Teac) but it has bee such a long ime I can not describe it from memory. You need to go to Hi Fi Engine and see if you can get a free Pdf servioce manual that might help you otherwise it needs to be seen by a Technician who will clean other parts, lubricate and do the necessary things to get it going again. I have new heads for it as well. The record/play switch will need cleaning I am sure as well as other switches.
Aug 25, 2013 | Teac V377 Single Dual Cassette Deck
How to replace the belts in a Teac A300 cassette deck
The mechanism needs to be taken apart sufficient to get to the flywheel and capstan motor- this usually entails taking the metal motor bracket off the back. It is not that difficult once you have done one. I may have replaced 50 to 100 of them at Teac in Chicago. Also oil the capstan bearing when changing a belt.
Aug 08, 2013 | Teac Audio Players & Recorders
Looking for rubber belts replacement for teac v8030s
Look on the Marrs Comunications web site and order the kit for the unit.
Apr 12, 2013 | Teac V-8030 Dual Cassette Deck
RUBBER DRIVE BELT FOR A360 FOR TEAC CASSETTE DECK
Drive belts on tape decks are mostly universal. You only need to measure the diameter of each belt in mm and then enter the result in Google as "Cassette drive belt ??mm".
Mar 13, 2011 | Teac W-865R Single Cassette Deck
Sony TC-K690 3Head Cassette Deck - no playback
It needs a new rubber belt for the mechanism control.
It is a smallest of th 3 rubber belts.
Mar 14, 2010 | Sony Audio Players & Recorders
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
