Question about Video Game Consoles & Games
My right analog keeps pointing down but im not touching it at all
  • 44 Answers
Im not sure what console your having this on... but I used to have it happen on my gamecube and n64 all the time. Try unplugging your controller and plugging it back in (or off then back on if it's wireless)
this often happens if your accidentally holding the thumb-stick down when you start your console/game
if this doesn't help you may need to either A: clean the controller or B: replace it
hope it helps
~good luck!
Posted on Mar 13, 2011
Sansui AU-D33 Lh speaker channel not working.
As the channels are identical you can use the good channel has a guide to the bad one. First thing is to look around see if anything does not look the same as the right channel.
If nothing obvious stands out, with the power on, using an insulated screwdriver touch the two channels one at a time. Keep away from the power supply and anything that is common to both channels. The channel will buzz once touched. Depending which points you touch them. The right channel will tell you if it should buzz at that point. Work backwards from the speaker outputs if you can. If you hear a buzz on the left channel then it is working at that point, if it produces the same sound on the right.
Using this method you should track down the part that has gone.
Dec 11, 2015 | Audio Players & Recorders
Hi! Suddenly, the left analog stick of my controller stopped working when i push it down or to the right. Do you think that it's a simple problem that i can solve it alone, by opening the controll
Depending on how old the controller is you may have simply overused it to the point that the connections are worn out. You would need to have some idea of what the soldered connections were supposed to look like inside after you opened it up. But be warned some of these controllers can be quite difficult to put back together. When you open it up make sure its face down (Buttons down) and keep it that way or all the buttons will fall out and it can be a pain to get them all back in where they need to be.
Mar 25, 2013 | Intec PlayStation 3 Turbo Shock III...
Im on the level where its the second time that you go to rexus prime and im trying to pull in the imperial star destroyer and im using the force to put it in the correct position to start pulling it in and...
When they're all dead, do as Kota says and use your Force Grip. The camera will shift and two images representing your analog sticks will appear on the screen. Hold the left stick in the direction indicated. This will start turning the Star Destroyer's pointy nose to face you. This is one of the goals. The other goals are to tilt the nose upward or downward with the right analog stick. This part is pretty twitchy, so pay attention to with direction the game wants you to put it in. Also, be aware that the directions for the right analog stick are UP and NEUTRAL, not UP and DOWN. Once the Star Destroyer's nose is pointing the right way, the lights behind the sticks will turn green and it'll tell you to push the sticks up and then pull them both downward. Do it and HOLD them both down. Do not push them back up, despite what the image shows. Keep them hold down until the Ties get close and begin firing on you. Then let go and kill them again.
Feb 19, 2011 | Star Wars: The Force Unleashed for Xbox...
Ipod Touch Map Loacation(WPS) Not Accurate!
It is using commonly known Wifi access points from a database. Chances are you have wifi access point names near you that are close to what it knows in Michigan, but it doesn't know them in SC. This is why I want a real GPS in the touch. :-)
Apr 29, 2009 | Apple iPod touch
Mlb 09 the show glitch,always like im pushing up
turn off the system, and put the controller down then restart the system without touching the controller, sometimes the analog stick it in the up position that will remain the default position untill you reset the system
Apr 20, 2009 | Sony Playstation 3 (PS3) Console
When you barely tap my analog it gets stuck.
as a sony certified technician, i can tell you that these types of problems are caused be what we call a "false Contact". When the psp's analog stick does not touch the motherboard component, the analog stick auto scrolls down. If it auto scolls up then is just dirt biuld up. But if it scrolls down, make sure the screws on the back of the psp are FULLY tightened so that way the analog sticks makes contact with the motherboard. I fix psp's for fun so if you have a question that need to be answered right away, please just call my cell phone Number (773) 351-2426 (USA, ILLINOIS NUMBER) hope that works
Dec 31, 2008 | Sony PlayStation Portable (PSP) Console
The touch screen and the pen do not pair to function
my i9 phone does not apply the touch screen anymore and the pen calibration i cant click on screen . when i try to calibrate it keeps on the same infomation of "touch where the point is , left, center and right.
Dec 24, 2008 | Dual Electronics CECT P168 Cellular Phone
Lara moves awkwardly
This problem usually occurs with analog controllers when the analog controls are held down while the machine is turned on and the game starts up.
Run the game without touching the controler until the menu pops up.
If the problem still occurs, try the same step with another controller as the one you are using may have a damaged analog stick.
After trying these steps and the problem continues to occur then I suggest to check the disc for scratchs and smudges and give the game a good cleaning.
If you beleive it is a damaged disc then I suggest having the disc rebuffered at a local game shop.
Oct 21, 2008 | Eidos Interactive Tomb Raider: Last...
Analog Stick Help
The analog stick is damaged, send it to repair.
Jul 09, 2007 | Sony PlayStation Portable (PSP) Console
Fisher cd-rw1000
ah..yes..mi friend, i was in that spot one time. one suggestion i have is-make sure the blank cd you are trying to record on is a "compact disc DIGITAL audio"...or try hitting the "input select" button.
Feb 08, 2007 | Fisher CD-RW1000 2-Disc CD Recorder
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
