Question about Kelvinator ktm4200wb
Freezer defrosting & fridge not getting cold has power as light inside fridge is on and can hear motor running. Fridge is only 1 week old
  • Kelvinator Master
  • 43,501 Answers
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 13, 2011
Problem, fridge over a period of a few weeks or less goes from really cold to not so cold with ice buildup on the ceiling of the fridge section beneath the freezer compartment which itself does not ke
Hi, This will happen if you have a faulty defrost timer or the the heater is not working when it goes into defrost. The reason its not so cold after a week or so because the ice builds up & doesnt run efficently which is why when you switch it off & defrost it works great.
Nov 23, 2014 | Refrigerators
Samsung sr-l3426bs fridge not getting cold
you would need your fridge defrost sensor replace, check for ice build up within the vents of fridge section,
best to a tec to come and replace it for you,you would need the sensor to be reset on your fridge computer board
cheers
Nov 04, 2012 | Frigidaire FRS26R4A Side by Side...
A week ago the stuff in the bottom 'veg keeper' was getting too cold so I cut back both the fridge/freezer problem to 'orig settings.) I did put a ton of food in the refrig for Easter (maybe it held the...
it is not defrosting . coil is icing over it will slowly get warmer in fridge then freezer. will be defrost timer needs replacing or defrost element. also listen if fan motor is running when door closed.
Apr 05, 2010 | GE GSS20IEP Side by Side Refrigerator
Fridge and freezer not staying cold - Got home last night and my whirlpool (frost free) fridge/freezer was switched on (power running to it - light etc working) but was not chilling properly. Everything in...
This can happen if the fan motor in the freezer compartment is bad. Causes the freezer section to freeze up and you will not get air circulating, so no cooling. Check the fanmotor
Nov 06, 2009 | Cars & Trucks
Freezer works, fridge doesn't cool
Probably excessive ice in the condensor. Likely defrost thermostat or defrost heater problem.
What happens is excessive ice keeps airflow from the refrigerator part of the unit.
Jul 08, 2009 | Refrigerators
Side by side fridge not cooling, not making ice
if it seems like the evaporator is getting cold then your sealed system should appear to be ok. you need the evap fan to transfer cold air into fresh food section. if not turning u need to replace fan motor. make sure your not getting to much frost build up on the evap.
Jun 24, 2009 | Frigidaire Freezer Refrigeration White...
SERVIS MO262S FROST FREE FRIDGE/FREEZER, FRIDGE NOT WORKING
servis frostfree fridge freezer not working after 2weeks holiday returned it had completely defrosted fridge & freezer power supply still connected. warning light on. done all the trouble shooting in the srvice manual still want go cold or freeze. light on in the fridge, no water in the rear tray & cleaned the overflow pipe??. Model No M0330-ALU 5yrs old. think it has 2 seperate thermostats, surely they wont both have gone at the same time???????
Mar 30, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Fridge heller model fdh21has motor running but does not get cold
i have just purchased a float with a kitchen in it the fridge is a heller bar fridge not sure on model and for the 2nd use it is running but not getting cold or icing up the freezer what do i do to fix it it wouldnt be 10 weeks old
Mar 27, 2009 | Refrigerators
Fridge running but not staying cold
you have a defrost problem, if SxS ref. most likely bad defrost heaters. They are behind interior back wall. Sounds like you have a GE.
Jan 05, 2008 | Refrigerators
Kelvinator ktm4200wb Logo
181 people viewed this question
Top Kelvinator Refrigerators Experts
Charles T Nevin
Charles T Nevin
richie46
Are you a Kelvinator Refrigerator Expert? Answer questions, earn points and help others
