Wd-1049c vibrates and moves all over the floor like a earth quake
    Brigadier General:
  • 6,277 Answers
Hi from retired Englishman in SW France
It is necessary to ensure absolutely that the machine, even when empty, has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine (sorry about my UK spelling!) and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has not cured the problem it is possible that the internal drum suspension is malfunctioning.
Good luck,
Posted on Mar 13, 2011
Do you supply replacement parts or are these thru away tools.i can not find a clutch housing for replacement. 3/4 earth quake
fixya doesn't have any spares for anything
and to make matters worse , you have to explain what a 3/4 earth quake is , what it does , what sort of equipment it is to get answers as to where you might go to get spares
post it all again as posts are not linked
Dec 23, 2016 | Cars & Trucks
Suzuki swift dashboard rattle
finding noises is hard work and is ART.
get help.
1;: is it the dash it self, press on it, doe that stop of change pitch of sound.
no?
2: i must be something inside. use a cheap rubber hose to your ear.
and move hose all over dash underneath to find the true source.
you never said under what conditions, it rattles.
parked (rats/mice....), idling,, moving, or only bumps in road.
or only during earth quakes, (LOL)
Mar 24, 2013 | 2006 Suzuki Swift
I have a WD 1049c. It wont stop filling up with water, once machine is full it starts emptying while it is still filling up and then I get an "FE" message. I try to turn it off but it turns...
This sounds like the drain hose is too low resulting in a Syphon effect, lift the drain hose to around 2ft above floor level to cure .Good luck..Gerry
Feb 22, 2011 | LG Washing Machines
LG WD-1049C is beeping and shows fault dE. What is this please?
It is a "door error". Can be fixed by pushing on the door to make sure it is closed properly.
Nov 22, 2010 | LG Washing Machines
How do i fix the error code OE on the LG WD 1049c washing machine model?
Clean the drain trap. OE suggests it's not draining properly. Rich
Sep 26, 2010 | Washing Machines
How do you get the gasket our of an lg wd-1049c
You will find this link helpful
We have a Free full video library on appliance repair video’s
and here is a link to our door seal section
and here is a video on door seal changes
Jan 13, 2010 | LG Washing Machines
Operating instructions for a wd 1049c washer
go to lg's website and put in your model # and you can download the manual
Jun 21, 2009 | LG WD-1041WFH Front Load Washer
LG WD-1049C Front Load Washing Machine Pump impeller sloppy
probably better change the pump if you feel any up and down slack in the impellor. you may have an ingress of water through the seal.
Mar 13, 2009 | LG WD-1045FH Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
